Author: wmb Date: 2010-01-26 04:35:01 +0100 (Tue, 26 Jan 2010) New Revision: 1701
Added: cpu/x86/pc/olpc/via/blockfifo.fth Log: Checked in blockfifo.fth
Added: cpu/x86/pc/olpc/via/blockfifo.fth =================================================================== --- cpu/x86/pc/olpc/via/blockfifo.fth (rev 0) +++ cpu/x86/pc/olpc/via/blockfifo.fth 2010-01-26 03:35:01 UTC (rev 1701) @@ -0,0 +1,148 @@ +\ See license at end of file +purpose: Non-blocking writes to fsdisk for NANDblaster + +support-package: block-fifo +d# 10000 constant #queue +h# 4000 value /chunk +0 instance value chunks +0 instance value block#s +0 instance value this-#blocks +0 instance value read-index +0 instance value write-index +0 instance value max-depth +false instance value synchronous? + +: #queued ( -- n ) + write-index read-index - + dup 0< if #queue + then +; +: update-max ( -- ) + #queued max-depth max to max-depth +; + +: blocks/chunk ( -- n ) /chunk 9 rshift ; + +: >chunk ( i -- adr ) /chunk * chunks + ; +: +index ( i -- i' ) 1+ dup #queue = if drop 0 then ; + +: full? ( -- flag ) + write-index read-index = this-#blocks 0<> and +; +: empty? ( -- flag ) + write-index read-index = this-#blocks 0= and +; + +: ?write-error ( -- ) + if ( ) + ." disk-fifo: Write error at block " ( ) + block#s read-index na+ @ . cr ( ) + abort ( ) + then ( ) +; + +: ?start-write ( -- ) + empty? if exit then ( ) + + \ Start a new write + read-index >chunk ( adr ) + block#s read-index na+ @ ( adr block# ) + blocks/chunk ( adr block# #blocks ) + " write-blocks-start" $call-parent ?write-error ( ) + blocks/chunk to this-#blocks ( ) +; + +: open ( -- flag ) +\ #queue /chunk * alloc-mem to chunks + h# 200.0000 to chunks \ 32 M + #queue /n* alloc-mem to block#s + 0 to read-index + 0 to write-index + 0 to this-#blocks + true +; + +: size ( -- d.size ) " size" $call-parent ; + +: poll ( -- ) + this-#blocks if ( ) + " write-blocks-end?" $call-parent 0= if ( ) + exit \ Write still in progress ( -- ) + then ( error? ) + ?write-error ( ) + read-index +index to read-index ( ) + 0 to this-#blocks ( ) + then ( ) + + ?start-write +; + +: wait-available ( -- ) + full? if + ." WARNING: disk-fifo queue full" cr + begin poll full? 0= until + then +; + +: write-blocks ( adr block# #blocks -- actual ) + synchronous? if + " write-blocks" $call-parent + exit + then + + dup blocks/chunk <> if ( adr block# #blocks ) + ." disk-fifo: bad write length " dup . cr + 2drop + 0 exit + then ( adr block# #blocks ) + drop ( adr block# ) + wait-available ( adr block# ) + block#s write-index na+ ! ( adr ) + write-index >chunk /chunk move ( ) + write-index +index to write-index ( ) + update-max ( ) + poll ( ) + blocks/chunk ( actual ) +; + +: drain-queue ( -- ) + synchronous? 0= if + ." Max queue depth was " max-depth .d ." , current is " #queued .d cr + true to synchronous? + then + begin empty? 0= while poll repeat +; + +: close ( -- ) + drain-queue + block#s #queue /l* free-mem +; + +: read-blocks ( adr block# #blocks -- actual ) + drain-queue + " read-blocks" $call-parent +; +end-support-package + +\ LICENSE_BEGIN +\ Copyright (c) 2010 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
