Author: wmb Date: 2009-12-14 23:40:31 +0100 (Mon, 14 Dec 2009) New Revision: 1600
Modified: cpu/x86/pc/olpc/via/runin.fth Log: Via manufacturing tests - the NTP/RTC comparison code was horribly broken. Also changed the IP address in the ka-dir$ value.
Modified: cpu/x86/pc/olpc/via/runin.fth =================================================================== --- cpu/x86/pc/olpc/via/runin.fth 2009-12-14 16:05:50 UTC (rev 1599) +++ cpu/x86/pc/olpc/via/runin.fth 2009-12-14 22:40:31 UTC (rev 1600) @@ -3,8 +3,13 @@ visible
\ Location of the files containing KA tag data -: ka-dir$ ( -- adr len ) " http:\10.0.0.1\ka" ; +: ka-dir$ ( -- adr len ) " http:\10.1.0.1\ka" ;
+: mfg-ntp-server ( -- name$ ) + " NT" find-tag if ?-null else " 10.1.0.1" then +; +' mfg-ntp-server to ntp-servers + \ The Linux-based runin selftests put this file at int:\runin\olpc.fth \ after they have finished. On the next reboot, OFW thus boots this \ script instead of int:\boot\olpc.fth . This script either displays @@ -177,31 +182,33 @@ kbc-on ;
-: mfg-ntp-server ( -- name$ ) - " NT" find-tag if ?-null else " 10.60.0.2" then +d# 4 constant rtc-threshold +: .clocks ( -- ) + ntp>time&date time&date + ." RTC: " .clock ." NTP: " .clock ; -' mfg-ntp-server to ntp-servers - -d# 4 constant rtc-threshold : verify-rtc-date ( -- ) \ XXX check RTC power lost bit - ." Getting time from NTP server " + ." Getting time from NTP server .. " begin ntp-timestamp while ." Retry " repeat ( d.timestamp ) - cr - ntp>time&date unix-seconds> ( ntp-seconds ) - today unix-seconds> ( ntp-seconds rtc-seconds ) - - ( difference ) - dup rtc-threshold > if ( difference ) - page show-fail - ." Clock lost " .d ." seconds since SMT" cr - begin halt again - else - abs rtc-threshold > if - page show-fail - ." Clock gained " .d ." seconds since SMT" cr - begin halt again - then + + ntp>time&date >unix-seconds ( ntp-seconds ) + time&date >unix-seconds ( ntp-seconds rtc-seconds ) + - ( lost-seconds ) + dup rtc-threshold > if ( lost-seconds ) + page show-fail ( lost-seconds ) + ." Clock lost " .d ." seconds since SMT" cr ( ) + .clocks + stall + then ( lost-seconds ) + + abs dup rtc-threshold > if ( gained-seconds ) + page show-fail ( gained-seconds ) + ." Clock gained " .d ." seconds since SMT" cr ( ) + .clocks + stall then + ." NTP and RTC clocks agree." cr ;
: put-key:value ( value$ key$ -- ) " %s:%s" sprintf put-key-line ;
