Author: wmb Date: 2009-12-11 14:54:04 +0100 (Fri, 11 Dec 2009) New Revision: 1581
Modified: cpu/x86/pc/olpc/security.fth Log: OLPC trac 9868 - Reinstated "Signature [in]valid" messages that inadvertently got lost when support for delegated signatures was added.
Modified: cpu/x86/pc/olpc/security.fth =================================================================== --- cpu/x86/pc/olpc/security.fth 2009-12-11 09:33:46 UTC (rev 1580) +++ cpu/x86/pc/olpc/security.fth 2009-12-11 13:54:04 UTC (rev 1581) @@ -441,50 +441,6 @@ true ;
-0 [if] -\ parse-sig parses a "sig01:" format signature string, returning its -\ hashname and signature substrings. It converts the signature -\ substring from ASCII hex to binary bytes. - -: parse-sig ( sig01$ -- true | hashname$ sig$ false ) - dup d# 89 < if 2drop true exit then - bl left-parse-string " sig01:" $= 0= if 2drop true exit then ( rem$ ) - bl left-parse-string dup d# 6 <> if 4drop true exit then 2swap ( hash$ rem$ ) - bl left-parse-string nip d# 64 <> if 4drop true exit then ( hash$ rem$ ) - newline left-parse-string 2swap nip 0<> if 4drop true exit then ( hash$ data$ ) - dup /sig 2* <> if ( ." Bad signature length" cr ) 2drop true exit then ( hash$ data$ ) - - hex-decode if 2drop true else false then -; - -\ signature-invalid? checks the validity of data$ against the ASCII signature -\ record sig0N$, using the public key that thiskey$ points to. -\ It also verifies that the hashname contained in sig01$ is the -\ expected one. - -: signature-invalid? ( data$ sig0N$ exp-hashname$ -- error? ) - 2>r - parse-sig if - ." Bad signature format" cr - 2r> 2drop true exit - then ( data$ hashname$ sig$ r: exp$ ) - - \ Check for duplicate hashname attacks - 2swap 2dup 2r> $= 0= if ( data$ sig$ hashname$ ) - ." Wrong hash name" cr - 4drop 2drop true exit - then ( data$ sig$ hashname$ ) - - 2>r 2>r 2>r 0 2r> 2r> 2r> ( 0 data$ sig$ hashname$ ) - pubkey$ 2swap signature-bad? ( error? ) - dup if - " Signature invalid" ?lease-error-cr - else - " Signature valid" ?lease-debug-cr - then -; -[then] - \ exp-hashname$ remembers the most recently used hashname to guard against \ attacks based on reuse of the same (presumably compromized) hash.
@@ -623,10 +579,12 @@ newline left-parse-string ( rem$' line$ )
this-sig-line-good? if ( rem$ ) + " Signature valid" ?lease-debug-cr 2drop true exit then ( rem$ )
repeat ( rem$ ) + " Signature invalid" ?lease-error-cr 2drop false ( good? ) ;
