Author: wmb Date: Mon Jan 16 22:04:50 2012 New Revision: 2821 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2821
Log: Debugger - added \ command to display return stack and X command to force hex stack display.
Modified: forth/lib/debug.fth
Modified: forth/lib/debug.fth ============================================================================== --- forth/lib/debug.fth Mon Jan 16 22:04:46 2012 (r2820) +++ forth/lib/debug.fth Mon Jan 16 22:04:50 2012 (r2821) @@ -109,6 +109,7 @@ ." R RSTrace: Show contents of Forth return stack" cr ." S See: Decompile definition being debugged" cr ." $ Display top of stack as adr,len text string" cr + ." \ Display Forth return stack as numbers (like the data stack)" cr ." Q Quit: abandon execution of the debugged word" cr ; d# 24 constant cmd-column @@ -133,20 +134,38 @@ d# 72 constant /#buf /#buf buffer: #buf-save variable hld-save +variable show-rstack \ Show the return stack along with the data stack? +variable hex-stack \ Show the data stack in hex? : save# ( -- ) #-buf /#buf - #buf-save d# 72 move hld @ hld-save ! ; : restore# ( -- ) #buf-save #-buf /#buf - d# 72 move hld-save @ hld ! ; +: (.rs ( -- ) + show-rstack @ 0= if exit then + ." return-stack: " + push-hex + rp0 @ rp@ - /n / + 6 do \ It appears that skipping the first 6 entries on the stack skips the debug goo on the rs + rp@ i /n * + @ . + loop + pop-base +; : (trace ( -- ) first-time? if ??cr ip@ <ip @ = if ." : " else ." Inside " then <ip @ find-cfa .name + 0 show-rstack ! false is first-time? rp@ is rp-mark then begin step? @ if to-debug-window then save# - cmd-column 2+ to-column ." ( " .s ." )" cr \ Show stack + cmd-column 2+ to-column + hex-stack @ if push-hex then + ." ( " .s \ Show data stack + hex-stack @ if pop-base then + show-rstack @ if (.rs then \ Show return stack + ." )" cr restore#
['] noop is indent @@ -178,6 +197,8 @@ ascii < of ip@ ta1+ set-<ip 1 cnt ! false endof ascii ) of ip@ ip> ! 1 cnt ! false endof ascii * of ip@ find-cfa dup <ip ! 'unnest ip> ! false endof + ascii \ of show-rstack @ 0= show-rstack ! false endof + ascii X of hex-stack @ 0= hex-stack ! false endof ( default ) true swap endcase else
