Author: wmb Date: Mon Jul 30 09:34:51 2012 New Revision: 3096 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3096
Log: OLPC CL4 - Skip some steps in the startup process that are not working yet. Ifdefs in common files need to be deleted as these steps are made to work.
Modified: cpu/arm/olpc/banner.fth cpu/arm/olpc/build-fw.fth cpu/arm/olpc/usb.fth
Modified: cpu/arm/olpc/banner.fth ============================================================================== --- cpu/arm/olpc/banner.fth Mon Jul 30 09:30:34 2012 (r3095) +++ cpu/arm/olpc/banner.fth Mon Jul 30 09:34:51 2012 (r3096) @@ -65,6 +65,9 @@ ;
: .storage ( -- ) +[ifdef] olpc-cl4 +." olpc/banner.fth: Skipping .storage" cr exit +[then] internal-disk-present? 0= if ( ) get-internal-disk-info ( ) then
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Mon Jul 30 09:30:34 2012 (r3095) +++ cpu/arm/olpc/build-fw.fth Mon Jul 30 09:34:51 2012 (r3096) @@ -312,6 +312,9 @@ warning @ warning off : stand-init stand-init +[ifdef] olpc-cl4 +." build-fw.fth: Skipping root node properties" cr exit +[then] root-device model-version$ 2dup model ( name$ ) " OLPC " encode-bytes 2swap encode-string encode+ " banner-name" property @@ -837,7 +840,11 @@ + use-screen-kbd open-hotspot
install-alarm +[ifdef] olpc-clr + ." build-fw.fth: not sounding" cr +[else] ?sound +[then]
?games
@@ -845,7 +852,11 @@ + use-screen-kbd ?text-on [ifdef] probe-usb factory-test? if d# 1000 ms then \ Extra USB probe delay in the factory +[ifdef] olpc-cl4 + ." build-fw.fth: not probing usb" cr +[else] probe-usb +[then] report-disk report-keyboard [then] @@ -867,6 +878,9 @@ auto-banner? if banner then
+ use-screen-kbd ?text-on +[ifdef] olpc-cl4 + ." Quitting before auto-boot" cr quit +[then] auto-boot + use-screen-kbd close-hotspot
Modified: cpu/arm/olpc/usb.fth ============================================================================== --- cpu/arm/olpc/usb.fth Mon Jul 30 09:30:34 2012 (r3095) +++ cpu/arm/olpc/usb.fth Mon Jul 30 09:34:51 2012 (r3096) @@ -29,6 +29,9 @@ : init-usb ( -- ) h# 9 h# 5c pmua! \ Enable clock to USB block reset-usb-hub +[ifdef] olpc-cl4 + ." olpc/usb.fth: Skipping USB phy init!" cr exit +[then] init-usb-phy ;
