Author: quozl Date: Fri Apr 20 09:07:04 2012 New Revision: 2947 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2947
Log: ext2fs - fix inode reference count for directories on filesystems without DIR_NLINK, and maintain directory count in group descriptor, #11787
Modified: ofw/fs/ext2fs/bitmap.fth ofw/fs/ext2fs/dir.fth ofw/fs/ext2fs/sb.fth
Modified: ofw/fs/ext2fs/bitmap.fth ============================================================================== --- ofw/fs/ext2fs/bitmap.fth Thu Apr 19 21:05:54 2012 (r2946) +++ ofw/fs/ext2fs/bitmap.fth Fri Apr 20 09:07:04 2012 (r2947) @@ -75,11 +75,32 @@ then ( n r: adr ) r> h# 0e + le-w! ( ) ; -: free-inodes+! ( n inode# -- ) +: free-inodes+! ( n group# -- ) tuck free-inodes@ + ( group# n' ) over free-inodes! ( group# ) gd-update ( ) ; +: used-dirs@ ( group# -- n ) + group-desc dup h# 10 + le-w@ ( adr lo ) + desc64? if ( adr lo ) + swap h# 30 + le-w@ wljoin ( n ) + else ( adr lo ) + nip ( n ) + then ( n ) +; +: used-dirs! ( n group# -- ) + group-desc >r ( n r: adr ) + desc64? if ( n r: adr ) + lwsplit ( lo hi r: adr ) + r@ h# 30 + le-w! ( lo r: adr ) + then ( n r: adr ) + r> h# 10 + le-w! ( ) +; +: used-dirs+! ( n group# -- ) + tuck used-dirs@ + ( group# n' ) + over used-dirs! ( group# ) + gd-update ( ) +;
[ifdef] 386-assembler code find-low-zero ( n -- bit# )
Modified: ofw/fs/ext2fs/dir.fth ============================================================================== --- ofw/fs/ext2fs/dir.fth Thu Apr 19 21:05:54 2012 (r2946) +++ ofw/fs/ext2fs/dir.fth Fri Apr 20 09:07:04 2012 (r2947) @@ -78,7 +78,7 @@ : +link-count ( increment -- ) \ link-count = 1 means that the directory has more links than can \ be represented in a 16-bit number; don't increment in that case. - dir? if ( increment ) + dir? sb-nlink? and if ( increment ) link-count 1 = if ( increment ) drop exit ( -- ) then ( increment ) @@ -89,7 +89,7 @@ \ If the incremented value exceeds the limit, store 1 \ We should also set the RO_COMPAT_DIR_NLINK bit in the superblock, \ but we assume that OFW won't be used to create enormous directories - dir? if ( link-count ) + dir? sb-nlink? and if ( link-count ) dup d# 65000 >= if ( link-count ) drop 1 ( link-count' ) then ( link-count' ) @@ -106,6 +106,9 @@ dup ctime! ( time ) \ set creation time mtime! ( ) \ set modification time 0 link-count! ( ) \ link count will be incremented by new-dirent + dir? if + 1 inode# 1- ipg / used-dirs+! + then inode# ( inode# ) ;
@@ -214,6 +217,10 @@
\ Delete the currently selected inode. Does not affect the directory entry, if any. : idelete ( -- ) + dir? if + -1 inode# 1- ipg / used-dirs+! + then + \ Short symlinks hold no blocks, but have a string in the direct block list, \ so we must not interpret that string as a block list. d.#blks-held d0<> if @@ -276,7 +283,7 @@ new-inode ( name$ inode# )
\ new-inode changed the value of inode#; we must restore it so - \ new-dirent can find info about the containing diretory + \ new-dirent can find info about the containing directory wd-inum set-inode ( name$ inode# )
new-dirent ( error? )
Modified: ofw/fs/ext2fs/sb.fth ============================================================================== --- ofw/fs/ext2fs/sb.fth Thu Apr 19 21:05:54 2012 (r2946) +++ ofw/fs/ext2fs/sb.fth Fri Apr 20 09:07:04 2012 (r2947) @@ -57,6 +57,7 @@ : sb-64bit? ( -- flag ) incompat-flags h# 80 and 0<> ; : sb-extents? ( -- flag ) incompat-flags h# 40 and 0<> ; : sb-gd-csum? ( -- flag ) ro-flags h# 10 and 0<> ; +: sb-nlink? ( -- flag ) ro-flags h# 20 and 0<> ;
\ Don't write to a disk that uses extensions we don't understand : unknown-extensions? ( -- unsafe? )
