Author: wmb Date: 2009-12-16 09:37:06 +0100 (Wed, 16 Dec 2009) New Revision: 1626
Modified: cpu/x86/pc/olpc/rtcwake.fth cpu/x86/pc/olpc/via/probemem.fth cpu/x86/pc/olpc/via/rtcwake.fth Log: OLPC trac 9887 - added suspend/resume test to memory selftest.
Modified: cpu/x86/pc/olpc/rtcwake.fth =================================================================== --- cpu/x86/pc/olpc/rtcwake.fth 2009-12-16 08:20:30 UTC (rev 1625) +++ cpu/x86/pc/olpc/rtcwake.fth 2009-12-16 08:37:06 UTC (rev 1626) @@ -51,7 +51,7 @@
: show-rtc-wake ." R" ;
-d# 1 constant rtc-alarm-delay +d# 1 value rtc-alarm-delay : pm-sleep-rtc ( -- ) 0 acpi-l@ h# 400.0000 or 0 acpi-l! \ Enable RTC SCI ['] show-rtc-wake rtc-alarm-delay " set-alarm" clock-node @ $call-method @@ -103,6 +103,22 @@ autowack-off ;
+: s3-selftest ( -- error? ) + \ The general failure mode here is that it won't wake up, so + \ it's hard to return a real error code. We just have to rely + \ on the operator. + ." Testing S3 suspend/resume" cr + rtc-alarm-delay >r + ." Sleeping for 1 second .. " 1 to rtc-alarm-delay pm-sleep-rtc cr + ." Sleeping for 4 seconds .. " 4 to rtc-alarm-delay pm-sleep-rtc cr + ." Sleeping for 8 seconds .. " 8 to rtc-alarm-delay pm-sleep-rtc cr + r> to rtc-alarm-delay + false +; +dev /memory +[ifdef] test-s3 ' s3-selftest to test-s3 [then] +dend + stand-init: Century h# 20 cmos-century cmos! \ The century is in BCD, hence h# ;
Modified: cpu/x86/pc/olpc/via/probemem.fth =================================================================== --- cpu/x86/pc/olpc/via/probemem.fth 2009-12-16 08:20:30 UTC (rev 1625) +++ cpu/x86/pc/olpc/via/probemem.fth 2009-12-16 08:37:06 UTC (rev 1626) @@ -79,6 +79,7 @@ : 8u.h ( n -- ) push-hex (.8) type pop-base ; [then] : .chunk ( adr len -- ) ." Testing memory at: " swap 8u.h ." size " 8u.h cr ; +defer test-s3 ( -- error? ) ' false is test-s3 : selftest ( -- error? ) " available" get-my-property if ." No available property" cr true exit then ( adr len ) @@ -88,7 +89,8 @@ \ We maintain a 1-1 convenience mapping so explicit mapping is unnecessary memory-test-suite if 2drop true exit then ( rem$ ) repeat drop - false + + test-s3 ;
device-end
Modified: cpu/x86/pc/olpc/via/rtcwake.fth =================================================================== --- cpu/x86/pc/olpc/via/rtcwake.fth 2009-12-16 08:20:30 UTC (rev 1625) +++ cpu/x86/pc/olpc/via/rtcwake.fth 2009-12-16 08:37:06 UTC (rev 1626) @@ -51,7 +51,7 @@
-d# 1 constant rtc-alarm-delay +d# 1 value rtc-alarm-delay : pm-sleep-rtc ( -- ) 0 acpi-l@ h# 400.0000 or 0 acpi-l! \ Enable RTC SCI ['] show-rtc-wake rtc-alarm-delay " set-alarm" clock-node @ $call-method @@ -63,6 +63,19 @@ begin pm-sleep-rtc space dup . (cr 1+ key? until key drop ; +: s3-selftest ( -- error? ) + \ The general failure mode here is that it won't wake up, so + \ it's hard to return a real error code. We just have to rely + \ on the operator. + ." Testing S3 suspend/resume" cr + rtc-alarm-delay >r + ." Sleeping for 1 second .. " 1 to rtc-alarm-delay pm-sleep-rtc cr + ." Sleeping for 4 seconds .. " 4 to rtc-alarm-delay pm-sleep-rtc cr + ." Sleeping for 8 seconds .. " 8 to rtc-alarm-delay pm-sleep-rtc cr + r> to rtc-alarm-delay + false +; +dev /memory ' s3-selftest to test-s3 dend
