Author: quozl Date: Mon Feb 11 05:58:33 2013 New Revision: 3542 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3542
Log: OLPC - telnetd, allow subsequent reconnections, display IP address of client, suppress 300ms options negotiation allowing to occur during normal mux I/O, also fixes #12539.
Modified: ofw/inet/telnetd.fth
Modified: ofw/inet/telnetd.fth ============================================================================== --- ofw/inet/telnetd.fth Mon Feb 11 05:20:02 2013 (r3541) +++ ofw/inet/telnetd.fth Mon Feb 11 05:58:33 2013 (r3542) @@ -7,6 +7,8 @@
support-package: telnet false value debug-options? +false value verbose? +false value listening?
: (read) ( adr len -- actual ) " read" $call-parent ; : (write) ( adr len -- actual ) " write" $call-parent ; @@ -130,7 +132,7 @@ \ Remove the linefeed in a cr-lf pair. \ The Windows telnet client sends CR-LF per the Telnet NVT spec. \ The Linux telnet client just sends CR. -0 value last-was-cr? +false value last-was-cr?
: do-lf ( adr len -- adr' len' ) last-was-cr? if swallow else 1 /string then @@ -148,12 +150,41 @@ repeat ( adr end-adr 0 ) drop swap - ( len' ) ; -: read ( adr len -- actual ) - over swap (read) ( adr actual ) - dup 0< if nip exit then ( adr actual ) - process-escapes ( actual' ) + +: .his-ip-addr ( -- ) + " his-ip-addr" $call-parent .ipaddr ; -: write ( adr len -- actual ) + +: accept? ( -- connected? ) + d# 23 " accept" $call-parent 0= if false exit then + + verbose? if ." telnetd: connection from " .his-ip-addr cr then + + 3 send-do \ You suppress go-ahead + 0 send-do \ Be binary + 1 send-will \ I will echo + false to listening? + false to last-was-cr? + true +; + +: disconnect ( -- ) + " disconnect" $call-parent + verbose? if ." telnetd: connection closed by " .his-ip-addr cr then + true to listening? +; + +: read ( adr len -- actual|-1|-2 ) + listening? if accept? drop 2drop -2 exit then + over swap (read) ( adr actual ) + dup case ( adr actual ) + -1 of disconnect nip exit endof + -2 of nip exit endof + endcase + process-escapes ( actual' ) +; +: write ( adr len -- actual|-1 ) + listening? if 2drop -1 exit then tuck begin ( len adr len ) #iac split-string ( len head$ tail$ ) dup while ( len head$ tail$ ) @@ -165,43 +196,18 @@ 2drop (write) drop ( len ) ;
-0 instance value verbose? - : open ( -- flag ) + true to listening? my-args " verbose" $= to verbose?
verbose? if ." telnet://" " my-ip-addr" $call-parent .ipaddr cr then
- begin d# 23 " accept" $call-parent until + begin accept? until
verbose? if ." Connected" cr then
- 3 send-do \ You suppress go-ahead - 0 send-do \ Be binary - 1 send-will \ I will echo - - get-msecs ( time ) - begin - get-msecs over d# 300 + - 0< - while - the-byte h# 10 (read) dup 0< if ( msecs count ) - \ Bail out if the connection closed - -1 = if drop false exit then - - \ The other alternative is -2, meaning no bytes available. - \ In that case, we'll eventually time out. - else ( msecs count ) - \ Keep advancing the timeout while bytes are still coming in - the-byte swap process-escapes drop ( msecs ) - drop get-msecs - then - repeat - drop - - false to last-was-cr? - true ; : close ( -- ) ; @@ -210,24 +216,15 @@
0 value telnet-ih
-defer getchar-hook ' = to getchar-hook -patch getchar-hook = stdin-getchar - : exit-telnet ( -- ) - telnet-ih remove-output - telnet-ih remove-input - telnet-ih close-dev - ['] = to getchar-hook -; + telnet-ih 0= if exit then
-: ?telnet-closed ( read-return 1 -- flag ) - over -1 = if ( -1 1 ) - exit-telnet ( -1 1 ) - carret pending-char c! ( 1 1 ) - ." Connection closed" \ cr - 2drop true exit - then ( read-return 1 ) - = + " verbose?" telnet-ih $call-method ( verbose? ) + telnet-ih remove-output ( verbose? ) + telnet-ih remove-input ( verbose? ) + telnet-ih close-dev ( verbose? ) + 0 to telnet-ih ( verbose? ) + if ." telnetd: off" cr then ( ) ;
devalias telnetd tcp//telnet:verbose @@ -238,7 +235,6 @@ telnet-ih add-output telnet-ih add-input \ hint: use " screen-ih remove-output " to speed up your telnet output - ['] ?telnet-closed to getchar-hook ; \ LICENSE_BEGIN \ Copyright (c) 2006 FirmWorks
