Author: wmb Date: Fri Dec 23 00:59:27 2011 New Revision: 2783 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2783
Log: OLPC XO-1.75 and XO-3 - Fixed MMP2 hash engine code to use non-cached memory for DMA, fixing a problem whereby the hash answer was often wrong because the source data was stuck in L1 cache and thus invisible to DMA.
Modified: cpu/arm/mmp2/hash.fth
Modified: cpu/arm/mmp2/hash.fth ============================================================================== --- cpu/arm/mmp2/hash.fth Fri Dec 23 00:59:23 2011 (r2782) +++ cpu/arm/mmp2/hash.fth Fri Dec 23 00:59:27 2011 (r2783) @@ -18,7 +18,7 @@
h# 40 value /hash-block d# 20 value /hash-digest -/hash-block 2* buffer: (hash-buf) +0 value (hash-buf) : hash-buf ( -- adr ) (hash-buf) /hash-block round-up ; \ Aligned 0 value #hash-buf 0 value #hashed @@ -39,6 +39,10 @@ h# 291818 io! \ Low word of total size ; : hash-init ( -- ) + (hash-buf) 0= if + /hash-block 2* " /" " dma-alloc" execute-device-method drop + to (hash-buf) + then 1 h# 290c00 io! \ Select hash (0) for Accelerator A, crossing to direct DMA to it dma-stop 8 hash-control! \ Reset
