Author: wmb Date: 2009-02-20 19:16:26 +0100 (Fri, 20 Feb 2009) New Revision: 1109
Modified: cpu/x86/pc/olpc/smbios.fth Log: SMBIOS - fixed the UUID routine.
Modified: cpu/x86/pc/olpc/smbios.fth =================================================================== --- cpu/x86/pc/olpc/smbios.fth 2009-02-20 09:17:56 UTC (rev 1108) +++ cpu/x86/pc/olpc/smbios.fth 2009-02-20 18:16:26 UTC (rev 1109) @@ -337,23 +337,26 @@ ; : get-tag$ ( tag$ -- value$ ) find-tag 0= if " Not Available" then ?-null ;
-: too-long? ( dst-adr -- dst-adr flag ) dup pad - d# 10 >= ; +: too-long? ( dst-adr -- dst-adr flag ) dup pad - h# 10 >= ; : (uuid) ( -- true | adr len false ) " U#" find-tag if ( adr len ) + ?-null ( adr len' ) pad -rot ( dst-adr adr len ) bounds ?do ( dst-adr ) too-long? if drop true unloop exit then i c@ h# 10 digit if ( dst-adr digith ) i 1+ c@ h# 10 digit if ( dst-adr digith digitl ) - swap bwjoin over c! ( dst-adr ) - 1+ ( dst-adr' ) + swap 4 lshift or ( dst-adr byte ) + over c! 1+ ( dst-adr' ) + 2 ( dst-adr advance ) else ( dst-adr digith char ) 3drop true unloop exit then ( dst-adr ) else ( dst-adr char ) [char] - <> if drop true unloop exit then - then ( dst-adr ) - loop ( dst-adr ) + 1 ( dst-adr advance ) + then ( dst-adr advance ) + +loop ( dst-adr ) pad tuck - ( adr len ) dup h# 10 = if ( adr len ) false \ Good UUID ( adr len false )
