Author: wmb Date: 2009-08-20 08:20:52 +0200 (Thu, 20 Aug 2009) New Revision: 1305
Modified: dev/ide/dmaide.fth Log: DMA IDE driver - added a timeout to the completion wait routine to prevent hangs.
Modified: dev/ide/dmaide.fth =================================================================== --- dev/ide/dmaide.fth 2009-08-20 06:17:45 UTC (rev 1304) +++ dev/ide/dmaide.fth 2009-08-20 06:20:52 UTC (rev 1305) @@ -37,8 +37,14 @@ dma-stat@ dma-stat! \ Clear old errors ;
-: dma-wait ( -- ) - begin 1 ms dma-stat@ dup 1 and 0= swap 2 and or until +: dma-wait ( ms -- timeout? ) + 0 do + 1 ms + dma-stat@ dup 1 and 0= swap 2 and or if + false unloop exit + then + loop + true ;
\ Sense and clear errors. The bit masked by 04 is read-clear and means @@ -56,7 +62,10 @@ dma-cmd@ 1 or dma-cmd! ( adr phys #blks ) ; : dma-end ( adr phys #blks -- actual# ) - dma-wait 0 dma-cmd! ( adr phys #blks ) + d# 500 dma-wait if ( adr phys #blks ) + 3drop 0 exit + then ( adr phys #blks ) + 0 dma-cmd! ( adr phys #blks ) dma-interrupt? if ( adr phys #blks ) r-csr@ drop \ Clear interrupt in drive dma-stat@ h# f0 and 4 or dma-stat! ( adr phys #blks )
