Author: quozl Date: Fri Feb 21 21:57:18 2014 New Revision: 3710 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3710
Log: OLPC - keyject, avoid cancel, use black-letters throughout
Modified: cpu/x86/pc/olpc/keyject.fth
Modified: cpu/x86/pc/olpc/keyject.fth ============================================================================== --- cpu/x86/pc/olpc/keyject.fth Thu Jan 23 19:18:01 2014 (r3709) +++ cpu/x86/pc/olpc/keyject.fth Fri Feb 21 21:57:18 2014 (r3710) @@ -97,7 +97,7 @@ 2over 2over ($add-tag) ( value$ name$ ) ." Added " type cr ( value$ ) then ( value$ ) - cancel ( value$ ) + black-letters ( value$ ) free-mem ( ) else ( name$ ) ." Warning: key " type ." is not in firmware image dropins" cr ( ) @@ -116,7 +116,7 @@
: keyject-error ( msg$ -- ) cr - red-letters ." Not injecting because: " type cr cancel + red-letters ." Not injecting because: " type cr black-letters cr ." Will update firmware in 20 seconds" cr d# 21 1 do i .d (cr d# 1,000 ms loop @@ -217,7 +217,7 @@
: ?keyject ( -- ) visible - green-letters cr ." Security Key Injector" cr cr cancel + green-letters cr ." Security Key Injector" cr cr black-letters \ Get the new firmware first, so any security checks use the old keys get-new-firmware do-keyject? if
