Author: wmb Date: Sat Feb 13 06:48:07 2010 New Revision: 1736 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1736
Log: OLPC XO-1.0 - fixed regression in wireless open routine - new USB set-config scheme was improperly applied to the wireless driver.
Modified: dev/usb2/device/wlan/usb8388.fth
Modified: dev/usb2/device/wlan/usb8388.fth ============================================================================== --- dev/usb2/device/wlan/usb8388.fth Sat Feb 13 06:47:01 2010 (r1735) +++ dev/usb2/device/wlan/usb8388.fth Sat Feb 13 06:48:07 2010 (r1736) @@ -61,6 +61,13 @@ : set-parent-channel ( -- ) set-device device set-target ;
: setup-bus-io ( /inbuf /outbuf -- error? ) + reset? if + configuration set-config if + ." Failed to set USB configuration for wireless" cr + true exit + then + bulk-in-pipe bulk-out-pipe reset-bulk-toggles + then 4 bulk-out-pipe " begin-out-ring" $call-parent ( /inbuf ) h# 40 bulk-in-pipe " begin-in-ring" $call-parent false
