Author: wmb Date: Sun Jul 17 10:56:25 2011 New Revision: 2385 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2385
Log: OLPC XO-1.75 - completed the change begun by svn 2371, this time modifying the copy of the affected code that is actually used by XO-1.75.
Modified: cpu/arm/olpc/1.75/mfgtest.fth
Modified: cpu/arm/olpc/1.75/mfgtest.fth ============================================================================== --- cpu/arm/olpc/1.75/mfgtest.fth Sat Jul 16 14:20:43 2011 (r2384) +++ cpu/arm/olpc/1.75/mfgtest.fth Sun Jul 17 10:56:25 2011 (r2385) @@ -34,18 +34,21 @@
: mfg-test-dev ( $ -- ) restore-scroller - ??cr ." Testing " 2dup type cr - locate-device if ." Can't find device node" cr exit then ( phandle ) - " selftest" rot execute-phandle-method ( return abort? ) - if - ?dup if + ??cr ." Testing " 2dup type cr ( $ ) + 2dup locate-device if ( $ ) + 2drop ." Can't find device node" cr exit ( -- ) + else + drop ( $ ) + then ( $ phandle ) + " selftest" execute-device-method if ( return-code ) + ?dup if ( return-code ) ??cr ." Selftest failed. Return code = " .d cr mfg-color-red sq-border! false to pass? red-screen flush-keyboard mfg-wait-return - else + else ( ) green-letters ." Okay" cr black-letters
