Author: wmb Date: Tue Nov 8 20:19:10 2011 New Revision: 2675 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2675
Log: EXT2FS - added an option for "local replay" of a dirty ext3 journal, without writing to the disk.
Modified: ofw/fs/ext2fs/methods.fth ofw/fs/ext2fs/recovery.fth
Modified: ofw/fs/ext2fs/methods.fth ============================================================================== --- ofw/fs/ext2fs/methods.fth Tue Nov 8 20:19:06 2011 (r2674) +++ ofw/fs/ext2fs/methods.fth Tue Nov 8 20:19:10 2011 (r2675) @@ -161,7 +161,7 @@ dup bsize > abort" Bad size for ext2fsfread" dfile-size lblk# bsize um* d- drop ( addr count rem ) umin swap ( actual addr ) - lblk# read-file-block ( actual ) + lblk# j-read-file-block ( actual ) dup 0> if lblk#++ then ( actual ) ;
@@ -250,6 +250,7 @@ update-gds flush release-buffers + free-overlay-list ; : read ( adr len -- actual ) ext2fs-fd ['] fgets catch if 3drop 0 then
Modified: ofw/fs/ext2fs/recovery.fth ============================================================================== --- ofw/fs/ext2fs/recovery.fth Tue Nov 8 20:19:06 2011 (r2674) +++ ofw/fs/ext2fs/recovery.fth Tue Nov 8 20:19:10 2011 (r2675) @@ -133,16 +133,15 @@
: write-jblock ( d.block# adr -- ) -rot drop write-fs-block ( error? ) -\ j-blocksize 2swap ( adr len d.block# ) -\ j-blocksize du* ( adr len d.byte# ) -\ write-bytes if ." Journal recovery write error" cr abort then ;
0 value next-log-block +: log-block++ ( -- block# ) + next-log-block dup 1 +wrap to next-log-block ( block# ) +; : next-jblock ( buf -- ) - next-log-block read-file-block ( ) - next-log-block 1 +wrap to next-log-block ( ) + log-block++ read-file-block ( ) ;
0 value crc32-sum @@ -208,9 +207,66 @@ then ( ) ;
-: replay-tag ( -- ) - obh next-jblock ( ) +listnode + /n 2* field >o_block# + /n field >o_pblock# + /n field >o_escaped? +nodetype: overlay-node + +list: overlay-list + +: free-overlay-list ( -- ) + begin overlay-list >next-node while ( ) + overlay-list delete-after ( node ) + overlay-node free-node ( ) + repeat ( ) +; + +\ node is either the found one or the insertion point +: find-overlay? ( d.block# -- d.block# node found? ) + revoke-list ['] block#> find-node drop ( d.block# node ) + 3dup >r_block# 2@ d= ( d.block# node ) +;
+: j-read-file-block ( adr lblk# -- ) + >pblk# ?dup if ( adr pblk# ) + u>d find-overlay? if ( adr d.pblk# node ) + nip nip ( adr node ) + tuck >o_pblock# l@ ( node adr pblk# ) + block over bsize move ( node adr ) + swap >o_escaped? l@ if ( adr ) + jbd_magic swap be-l! ( ) + else ( adr ) + drop ( ) + then ( ) + else ( adr d.pblk# node ) + 2drop ( adr pblk# ) + block swap bsize move ( ) + then ( ) + else ( adr ) + bsize erase ( ) + then ( ) +; + +0 value j-read-only? +: set-overlay-node ( escaped? log-blk# d.block# node -- ) + >r ( escaped? log-blk# d.block# r: node ) + r@ >o_block# 2! ( escaped? log-blk# r: node ) + >pblk# r@ >o_pblock# l! ( escaped? r: node ) + r> >o_escaped? l! ( ) +; +: note-jblock ( d.block# escaped? log-blk# -- ) + 2swap find-overlay? if ( escaped? log-blk# d.block# node ) + set-overlay-node ( ) + else ( escaped? log-blk# d.block# node ) + >r ( escaped? log-blk# d.block# r: prev-node ) + >r overlay-node allocate-node ( d.block# escaped? log-blk# newnode r: prevnode ) + dup >r set-overlay-node ( r: prevnode newnode ) + r> r> insert-after ( ) + then +; + +: replay-tag ( -- ) tagp >t_blocknr be-l@ ( block# ) j-incompat 2 and if ( block# ) \ 2:FEATURE_INCOMPAT_64BIT tagp >t_blocknr_high be-l@ ( d.block# ) @@ -220,10 +276,16 @@ 2dup revoked? if ( d.block# ) 2drop ( ) else ( d.block# ) - tagp >t_flags be-l@ 1 and if ( d.block# ) \ 1:FLAG_ESCAPE - jbd_magic obh >data be-l! ( d.block# ) - then ( d.block# ) - obh write-jblock ( ) + tagp >t_flags be-l@ 1 and ( d.block# escaped? ) + j-read-only? if ( d.block# escaped? ) + log-block++ note-jblock ( ) + else ( d.block# escaped? ) + obh next-jblock ( d.block# escaped? ) + if ( d.block# ) \ 1:FLAG_ESCAPE + jbd_magic obh >data be-l! ( d.block# ) + then ( d.block# ) + obh write-jblock ( ) + then ( ) then ( ) ;
@@ -360,7 +422,7 @@
2 ['] one-pass catch if ." Journal replay failed" cr - free-revoke-list free-journal exit + free-overlay-list free-revoke-list free-journal exit then
free-revoke-list @@ -369,3 +431,4 @@ free-journal cr ; +\ XXX need to do free-overlay-list in close
