Author: wmb Date: 2009-09-05 11:09:26 +0200 (Sat, 05 Sep 2009) New Revision: 1351
Modified: cpu/x86/pc/olpc/via/startcominit.fth Log: Via - set the state of the WLAN activity LED in early startup.
Modified: cpu/x86/pc/olpc/via/startcominit.fth =================================================================== --- cpu/x86/pc/olpc/via/startcominit.fth 2009-09-05 09:07:41 UTC (rev 1350) +++ cpu/x86/pc/olpc/via/startcominit.fth 2009-09-05 09:09:26 UTC (rev 1351) @@ -67,13 +67,18 @@
\ Now AL contains the board ID h# d1 # al cmp u< if + acpi-io-base h# 4c + port-rl h# 200000 bitclr ax dx out \ Turn off WLAN activity LED (GPIO10) + \ A-test d# 17 0 devfunc 9b 01 01 mreg \ 1 selects GPO11/12 instead of CR_PWSEL/CR_PWOFF (DCONLOAD) 46 c0 40 mreg \ Enable UART on VCP port end-table + else \ B-test or later + acpi-io-base h# 4c + port-rl h# 20000 bitset ax dx out \ Turn off WLAN activity LED (GPIO10) + \ For B-test and later, we only enable serial if the jumper is present acpi-io-base 48 + port-rb h# 10 # al test 0= if d# 17 0 devfunc
