Author: wmb Date: Tue Aug 9 06:27:31 2011 New Revision: 2433 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2433
Log: GUID Partition Table support - decode ChromeOS kernel retry counters.
Modified: ofw/disklabel/showgpt.fth
Modified: ofw/disklabel/showgpt.fth ============================================================================== --- ofw/disklabel/showgpt.fth Tue Aug 9 06:26:34 2011 (r2432) +++ ofw/disklabel/showgpt.fth Tue Aug 9 06:27:31 2011 (r2433) @@ -128,12 +128,16 @@ 'guid d# 36 2dup upper ( adr len ) ;
+d# 100 constant chromeos-kernel-index +0 value partition-type-index + : .gpt-type ( adr -- ) >guid$ 2>r 0 ( string# r: guid$ ) begin ( string# r: guid$ ) dup ['] partition-type-guids ( string# string# xt r: guid$ ) catch 0= while ( string# 'this r: guid$ ) count 2r@ $= if ( string# r: guid$ ) + dup to partition-type-index ( string# r: guid$ ) 1+ partition-type-guids count type ( r: guid$ ) 2r> 2drop exit ( -- ) then ( string# r: guid$ ) @@ -143,6 +147,19 @@ 2drop ( ) ;
+: .gpt-extra ( adr -- ) + partition-type-index chromeos-kernel-index = if ( adr ) + \ For ChromeOS Kernel, display (success,tries,priority) + h# 36 + le-w@ wbsplit ( tries|pri success ) + ." (" (.) type ." ," ( tries|pri ) + push-decimal ( tries|pri ) + dup 4 rshift (.) type ." ," ( tries|pri ) + h# f and (.) type ." )" ( ) + pop-base ( ) + else ( adr ) + drop ( ) + then ( ) +; : .gpt-partition ( adr # -- ) \ Skip unused entries over 8 0 bskip 0= if 2drop exit then ( adr i ) @@ -152,6 +169,7 @@ \ dup .gpt-guid ( adr ) d# 50 to-column ( adr ) dup .gpt-type ( adr ) + dup .gpt-extra ( adr ) drop cr ( ) ; : .gpt-partitions ( -- )
