Author: wmb Date: Tue Oct 4 20:18:25 2011 New Revision: 2575 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2575
Log: OLPC - in enable-security, change the hardcoded address for the wp tag to be relative to mfg-data-top, thus allowing it to work for XO-1.75 too.
Modified: cpu/x86/pc/olpc/setwp.fth
Modified: cpu/x86/pc/olpc/setwp.fth ============================================================================== --- cpu/x86/pc/olpc/setwp.fth Tue Oct 4 03:02:09 2011 (r2574) +++ cpu/x86/pc/olpc/setwp.fth Tue Oct 4 20:18:25 2011 (r2575) @@ -10,9 +10,10 @@ \ require a full erase. That is faster and safer than copying out the \ data, erasing the block and rewriting it.
+: wp-loc$ ( -- adr len ) mfg-data-top 2- 2 ; : enable-security ( "serialnumber" -- ) board-revision h# b48 < abort" Only supported on B4 and later" - h# fffefffe 2 " wp" $= if ." wp is already set" cr exit then + wp-loc$ " wp" $= if ." wp is already set" cr exit then " SN" find-tag 0= abort" No serial number (SN tag); enabling security would brick me." ( sn$ ) -null ( sn$' ) safe-parse-word ( sn$ confirmation$ ) @@ -22,10 +23,10 @@ 0= abort" Canceled"
" U#" find-tag 0= abort" No U# tag; enabling security would brick me." 2drop - h# fffefffe 2 " ww" $= 0= abort" No ww tag" + wp-loc$ " ww" $= 0= abort" No ww tag" spi-start spi-identify " wp" h# efffe write-spi-flash - h# fffefffe 2 " wp" $= if ." Succeeded" cr then + wp-loc$ " wp" $= if ." Succeeded" cr then spi-reprogrammed ;
