Author: wmb Date: Wed Jul 6 04:22:55 2011 New Revision: 2331 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2331
Log: GUI - interact with mouse in stream mode instead of remote-polling mode to decrease command traffic over the PS/2 bus.
Modified: cpu/arm/olpc/1.75/mfgtest.fth ofw/gui/dialog.fth ofw/gui/iconmenu.fth ofw/gui/mouse.fth
Modified: cpu/arm/olpc/1.75/mfgtest.fth ============================================================================== --- cpu/arm/olpc/1.75/mfgtest.fth Wed Jul 6 04:20:34 2011 (r2330) +++ cpu/arm/olpc/1.75/mfgtest.fth Wed Jul 6 04:22:55 2011 (r2331) @@ -24,7 +24,7 @@ begin key? if key drop refresh exit then mouse-ih if - 10 get-event if + mouse-event? if \ Ignore movement, act only on a button down event nip nip if wait-buttons-up refresh exit then then
Modified: ofw/gui/dialog.fth ============================================================================== --- ofw/gui/dialog.fth Wed Jul 6 04:20:34 2011 (r2330) +++ ofw/gui/dialog.fth Wed Jul 6 04:22:55 2011 (r2331) @@ -287,7 +287,7 @@ mouse-ih 0= if drop false exit then >r false to dialog-ready? - begin 10 get-event while ( x y buttons ) + begin mouse-event? while ( x y buttons ) remove-mouse-cursor ( x y buttons ) -rot update-position ( buttons ) r@ mouse-buttons ( ?? )
Modified: ofw/gui/iconmenu.fth ============================================================================== --- ofw/gui/iconmenu.fth Wed Jul 6 04:20:34 2011 (r2330) +++ ofw/gui/iconmenu.fth Wed Jul 6 04:22:55 2011 (r2331) @@ -424,7 +424,7 @@
: do-mouse ( - ) mouse-ih 0= if exit then - begin 10 get-event while ( x y buttons ) + begin mouse-event? while ( x y buttons ) remove-mouse-cursor -rot update-position ( buttons ) new-sq? @@ -452,15 +452,6 @@ " screen" open-dev is screen-ih then ; -: ?open-mouse ( -- ) - mouse-ih 0= if - " mouse" open-dev is mouse-ih - mouse-ih 0= if - " /mouse" open-dev to mouse-ih - then - mouse-ih if alloc-mouse-cursor then - then -;
true config-flag menu? 0 value default-selection @@ -472,7 +463,13 @@
: .menu ( -- ) ." Type 'menu' to return to the menu" cr ;
-: wait-buttons-up ( -- ) begin 0 get-event drop nip nip 0= until ; +: wait-buttons-up ( -- ) + begin + mouse-event? if ( x y buttons ) + nip nip 0= if exit then + then + again +; headers : wait-return ( -- ) ." ... Press any key to return to the menu ... " @@ -481,7 +478,7 @@ begin key? if key drop refresh exit then mouse-ih if - 10 get-event if + mouse-event? if \ Ignore movement, act only on a button down event nip nip if wait-buttons-up refresh exit then then @@ -505,13 +502,15 @@ ' menu-interact to run-menu
: setup-graphics ( -- ) - ?open-screen set-menu-colors ?open-mouse + ?open-screen set-menu-colors ; : setup-menu ( -- ) setup-graphics + ?open-mouse cursor-off gui-alerts ; +: unsetup-menu ( -- ) ?close-mouse restore-scroller ;
defer current-menu ' clear to current-menu : set-menu ( xt -- ) to current-menu current-menu ; @@ -538,7 +537,7 @@ screen-wh ( color x y w y ) fill-rectangle-noff ( )
- restore-scroller + unsetup-menu ;
\ Note that menu establishes a new return stack state. Be sure to
Modified: ofw/gui/mouse.fth ============================================================================== --- ofw/gui/mouse.fth Wed Jul 6 04:20:34 2011 (r2330) +++ ofw/gui/mouse.fth Wed Jul 6 04:22:55 2011 (r2331) @@ -172,6 +172,27 @@ endcase ; headers + +0 value close-mouse? +: ?close-mouse ( -- ) + close-mouse? if + mouse-ih close-dev + 0 to mouse-ih + then +; +: ?open-mouse ( -- ) + mouse-ih 0= dup to close-mouse? if + " mouse" open-dev is mouse-ih + mouse-ih 0= if + " /mouse" open-dev to mouse-ih + then + mouse-ih if alloc-mouse-cursor then + then +; +: mouse-event? ( -- false | x y buttons true ) + " stream-poll?" mouse-ih $call-method +; + \ LICENSE_BEGIN \ Copyright (c) 2006 FirmWorks \
