Author: wmb Date: 2009-12-29 00:34:14 +0100 (Tue, 29 Dec 2009) New Revision: 1639
Modified: ofw/fs/cifs/smb.fth Log: Removed trailing whitespace in smb.fth. No functional change.
Modified: ofw/fs/cifs/smb.fth =================================================================== --- ofw/fs/cifs/smb.fth 2009-12-28 23:21:06 UTC (rev 1638) +++ ofw/fs/cifs/smb.fth 2009-12-28 23:34:14 UTC (rev 1639) @@ -276,7 +276,7 @@ loop ( adr ) drop ( ) buf8 8 -; +;
0 instance value password-buf d# 16 buffer: p21-buf @@ -386,7 +386,7 @@ --bytes-- ( path$ ) +path ( ) }smb ( true | rem$ false ) -; +;
0 instance value fid 0 instance value attributes \ 01:RO 02:Hidden 04:System 08:Volume 10:Directory 20:Archive @@ -658,12 +658,12 @@ dup h# 1f and 2* swap ( secs packed ) dup h# 07e0 and 5 >> swap ( secs mins packed ) h# f800 and d# 11 >> ( secs mins hours ) -; +; : >dmy ( dos-packed-date -- day month year ) dup h# 1f and swap ( day packed ) dup h# 01e0 and 5 >> swap ( day month packed ) h# fe00 and 9 >> d# 1980 + ( day month year ) -; +; \ Convert DOS file attributes to the firmware encoding \ see showdir.fth for a description of the firmware encoding : >canonical-attrs ( dos-attrs -- canon-attrs ) @@ -755,7 +755,7 @@ third 1+ 2* +xw ( path$ access flags ) \ Byte count for string + terminator +xw ( path$ access ) \ Create flage 0 +xw ( path$ access ) \ Root FID - + --bytes-- 0 +xb \ Null share password ( path$ ) +unicode$ @@ -813,14 +813,14 @@
\ It's a file, so open it - first try to open read/write. pathname$ 2 do-open if ( ) - \ Failing that, try to open read-only + \ Failing that, try to open read-only pathname$ 0 do-open if ( ) free-buffers false exit then ( ) then ( )
\ If any arguments remain, assume we are dealing with a ZIP - \ archive and interpose the ZIP handler + \ archive and interpose the ZIP handler tail$ dup if ( tail$ ) " zip-file-system" $interpose ( okay? ) else ( tail$ )
