Author: wmb Date: 2009-08-21 11:27:16 +0200 (Fri, 21 Aug 2009) New Revision: 1315
Added: dev/via/unichrome/accel2d.fth Modified: dev/via/unichrome/loadpkg.fth dev/via/unichrome/unichrome.fth Log: Via Unichrome display driver - use 2D acceleration for faster scrolling.
Added: dev/via/unichrome/accel2d.fth =================================================================== --- dev/via/unichrome/accel2d.fth (rev 0) +++ dev/via/unichrome/accel2d.fth 2009-08-21 09:27:16 UTC (rev 1315) @@ -0,0 +1,106 @@ +\ See license at end of file +purpose: Via Unichrome graphics acceleration + +alias depth+ wa+ + +: mmio@ ( offset -- l ) mmio-base + rl@ ; +: mmio! ( l offset -- ) mmio-base + rl! ; + +\ Do this once +: gp-setup ( -- ) + 0 h# 14 mmio! \ Destination map base - beginning of frame buffer + 0 h# 1c mmio! \ Source map base - beginning of frame buffer + bytes/line 3 rshift dup wljoin 8 mmio! \ Dest and src pitch + depth case + 8 of 0 endof \ 8-bpp 3:3:2 + d# 16 of h# 100 endof \ 16-bpp 5:6:5 + d# 32 of h# 300 endof \ 32-bpp 8:8:8:8 + endcase + 4 mmio! \ Mode +; + +: wait-done ( -- ) + begin h# 400 mmio@ h# 10002 and 0= until +; +: wh! ( w h -- ) + swap 1- swap 1- wljoin h# c mmio! ( src-x,y dst-x,y ) \ Set width and height +; +: dst! ( x y -- ) wljoin h# 10 mmio! ; +: src! ( x y -- ) wljoin h# 18 mmio! ; +: pattern! ( color -- ) h# 58 mmio! ; + +\ This one is a big win compared to doing it with the CPU +\ Scrolling the whole screen takes about 3.4 mS (GP) or 74 mS (CPU) +: gp-move ( src-x,y dst-x,y w,h -- ) + wh! dst! src! ( ) + h# cc.00.00.01 0 mmio! ( ) \ Perform BLT Output = source + wait-done +; + +\ gp-fill takes 2/3 as long wfill, and about the same time as lfill +\ gp-fill of the entire OLPC screen takes 2 mS; one character row 120 uS +: gp-fill ( color dst-x,y w,h -- ) + wh! dst! pattern! + h# f0.00.20.01 0 mmio! \ Output = pattern + wait-done +; + +\ some tests +1 [if] +: gp-fill-screen ( color -- ) + 0 0 screen-width screen-height gp-fill +; +: gp-scroll-screen ( -- ) + 0 char-height 0 0 screen-width ( src-x,y dst-x,y ) + screen-height char-height - gp-move +; +: gp-fill-last-line ( color -- ) + bg 0 screen-height char-height - screen-width char-height gp-fill +; +[then] + +: rc>pixels ( r c -- x y ) swap char-width * swap char-height * ; +: +window ( x y -- x' y' ) window-left 2/ window-top d+ ; +: rc>window ( r c -- x y ) rc>pixels +window ; + +: accel-delete-lines ( delta-#lines -- ) + >r ( r: delta-#lines ) + 0 line# r@ + rc>window ( src-x,y r: delta ) + 0 line# rc>window ( src-x,y dst-x,y r: delta ) + #columns #lines r@ - rc>pixels ( src-x,y dst-x,y w,h r: delta ) + gp-move ( r: delta ) + screen-background ( color r: delta ) + 0 #lines r@ - rc>window ( color dst-x,y r: delta ) + #columns r> rc>pixels ( color dst-x,y w,h ) + gp-fill +; + +: accel-install ( -- ) + gp-setup + ['] accel-delete-lines is delete-lines +; +' accel-install is gp-install + +\ LICENSE_BEGIN +\ Copyright (c) 2009 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: dev/via/unichrome/loadpkg.fth =================================================================== --- dev/via/unichrome/loadpkg.fth 2009-08-21 09:26:26 UTC (rev 1314) +++ dev/via/unichrome/loadpkg.fth 2009-08-21 09:27:16 UTC (rev 1315) @@ -19,7 +19,7 @@
fload ${BP}/dev/video/controlr/vga.fth \ Standard VGA interfaces fload ${BP}/dev/via/unichrome/unichrome.fth \ Controller code -\ fload ${BP}/dev/via/unichrome/accel2d.fth \ Accelerator +fload ${BP}/dev/via/unichrome/accel2d.fth \ Accelerator fload ${BP}/dev/via/unichrome/vgamodes.fth \ Text mode support fload ${BP}/dev/video/common/rectangle16.fth \ Rectangular graphics fload ${BP}/cpu/x86/pc/olpc/expand16.fth \ Expand image by 2x
Modified: dev/via/unichrome/unichrome.fth =================================================================== --- dev/via/unichrome/unichrome.fth 2009-08-21 09:26:26 UTC (rev 1314) +++ dev/via/unichrome/unichrome.fth 2009-08-21 09:27:16 UTC (rev 1315) @@ -622,10 +622,12 @@ fb-va /fb + to graphmem ;
+defer gp-install ' noop to gp-install + : set-fb ( -- ) width height ( width height ) over char-width / over char-height / ( width height rows cols ) - /scanline depth fb-install ( gp-install ) ( ) + /scanline depth fb-install gp-install ( ) ;
0 value open-count
