Author: wmb Date: Thu Oct 13 06:27:05 2011 New Revision: 2601 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2601
Log: OLPC XO-1.75 - Fixed regression that caused test /memory to fail; the DMA region was no longer mapped virtual=physical.
Modified: cpu/arm/olpc/1.75/prefw.bth cpu/arm/olpc/1.75/probemem.fth
Modified: cpu/arm/olpc/1.75/prefw.bth ============================================================================== --- cpu/arm/olpc/1.75/prefw.bth Thu Oct 13 03:13:55 2011 (r2600) +++ cpu/arm/olpc/1.75/prefw.bth Thu Oct 13 06:27:05 2011 (r2601) @@ -64,6 +64,9 @@ ; ' (cpu-arch to cpu-arch
+[ifndef] virtual-mode +fload ${BP}/cpu/arm/mmp2/mmuon.fth +[then] fload ${BP}/cpu/arm/olpc/1.75/probemem.fth \ Memory probing
stand-init: Probing memory @@ -77,8 +80,6 @@ ; fload ${BP}/ofw/core/initdict.fth \ Dynamic dictionary allocation fload ${BP}/arch/arm/loadarea.fth \ Allocate and map program load area -[else] -fload ${BP}/cpu/arm/mmp2/mmuon.fth [then]
\ XXX should be elsewhere
Modified: cpu/arm/olpc/1.75/probemem.fth ============================================================================== --- cpu/arm/olpc/1.75/probemem.fth Thu Oct 13 03:13:55 2011 (r2600) +++ cpu/arm/olpc/1.75/probemem.fth Thu Oct 13 06:27:05 2011 (r2601) @@ -93,7 +93,11 @@ then ( ) ;
+: map-dma ( -- ) + dma-mem-va >physical dup /dma-mem map-sections +; : selftest ( -- error? ) + map-dma
false to mem-fail?
