Author: wmb Date: Fri Jan 18 05:17:30 2013 New Revision: 3520 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3520
Log: OLPC XO-4 - Added device node for GALCORE graphics accelerator.
Added: cpu/arm/mmp3/galcore.fth
Added: cpu/arm/mmp3/galcore.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/mmp3/galcore.fth Fri Jan 18 05:17:30 2013 (r3520) @@ -0,0 +1,19 @@ +purpose: Device node for GALCORE graphics accelerator + +h# d420.d000 constant gpu-pa \ Base of GPU +h# 1000 constant /gpu + +dev / +new-device + " gpu" device-name + " mrvl,galcore" +compatible + gpu-pa /gpu reg + d# 0 encode-int 2 encode-int encode+ " interrupts" property + " /interrupt-controller/interrupt-controller@1c0" encode-phandle " interrupt-parent" property + + " galcore 3D" encode-string " galcore 2D" encode-string encode+ " interrupt-names" property + + " /pmua" encode-phandle d# 11 encode-int encode+ " clocks" property + " GCCLK" " clock-names" string-property +finish-device +device-end
