Author: quozl Date: Sat Aug 11 05:10:47 2012 New Revision: 3154 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3154
Log: OLPC CL4 - Neonode, add signal strength and failed component tests
Modified: cpu/arm/olpc/nn-touchscreen.fth ============================================================================== --- cpu/arm/olpc/nn-touchscreen.fth Sat Aug 11 02:33:01 2012 (r3153) +++ cpu/arm/olpc/nn-touchscreen.fth Sat Aug 11 05:10:47 2012 (r3154) @@ -10,6 +10,10 @@
fload ${BP}/cpu/arm/olpc/touchscreen-common.fth
+[ifndef] 2u.x +: 2u.x base @ >r hex 0 <# # # #> type r> base ! ; +[then] + : set-gpios touch-rst-gpio# dup gpio-set gpio-dir-out touch-tck-gpio# dup gpio-clr gpio-dir-out @@ -32,16 +36,10 @@ true ;
-: out ( byte ... bytes# -- ) twsi-out ; - -defer process -' noop to process - : anticipate ( id msecs -- ) get-msecs + ( id limit ) begin in? if - process over pbuf 2+ c@ ( id limit received-id ) = if 2drop exit then then ( id limit ) @@ -52,17 +50,17 @@
: read-boot-complete ( -- ) h# 07 d# 20 anticipate ;
-: initialise ( -- ) h# 01 h# 01 h# ee 3 out h# 01 d# 20 anticipate ; +: initialise ( -- ) h# 01 h# 01 h# ee 3 twsi-out h# 01 d# 20 anticipate ;
: set-resolution ( -- ) set-geometry - screen-h wbsplit swap screen-w wbsplit swap h# 02 h# 05 h# ee 7 out + screen-h wbsplit swap screen-w wbsplit swap h# 02 h# 05 h# ee 7 twsi-out h# 02 d# 20 anticipate ;
-: start ( -- ) h# 04 h# 01 h# ee 3 out ; +: start ( -- ) h# 04 h# 01 h# ee 3 twsi-out ;
-: deactivate ( -- ) h# 00 h# 01 h# ee 3 out h# 00 d# 20 anticipate ; +: deactivate ( -- ) h# 00 h# 01 h# ee 3 twsi-out h# 00 d# 20 anticipate ;
: configure ( -- ) initialise @@ -102,18 +100,94 @@ then ;
-: selftest + +0 value faults +: fault faults 1+ to faults ; + +: .bits ( addr low high -- addr ) + ." ( " swap do ( addr ) + i over bittest if + i . fault + then + loop ." )" cr ( addr ) + \ FIXME: express failed devices in terms of IR PCB component names. +; + +: test-os-axis ( axis -- ) + h# 21 h# 02 h# ee 4 twsi-out + h# 21 d# 30 anticipate + pbuf 2+ c@ h# 21 <> abort" o s bad response" + + pbuf 3 + c@ if h# 0a else h# 0e then >r ( r:nleds ) + pbuf 4 + ( r:nleds array ) + + \ bit array layout: | open_pd | short_pd | short_led | open_led | + \ subarray widths: | npds bits | npds bits | nleds bits | nleds bits | + \ npds = nleds+1 + + \ 0 npds + ." open_pd=" 0 r@ 1+ .bits + \ npds npds*2 + ." short_pd=" r@ 1+ r@ 1+ 2* .bits + \ npds*2 npds*2+nleds + ." short_led=" r@ 1+ 2* dup r@ + .bits + \ npds*2+nleds npds*2+nleds*2 + ." open_led=" r@ 1+ 2* r@ + dup r@ + .bits + r> drop drop ( ) + cr +; + +: test-os + 0 test-os-axis + 1 test-os-axis +; + +: test-fss-axis ( axis -- ) + d# 64 swap h# 0f h# 03 h# ee 5 twsi-out + h# 0f d# 20 anticipate + pbuf 2+ c@ h# 0f <> abort" fss bad response" + push-decimal + pbuf 4 + c@ 0 do ( ) + pbuf 5 + i + c@ + dup 0= if fault then + 4 .r space + i d# 10 mod d# 9 = if cr then + loop cr + pop-base + \ FIXME: using a light guide, characterise a low signal level, + \ detect, and fail self test + \ FIXME: express failed signals in terms of IR PCB component names. +; + +: test-fss + ." Signals X Axis" cr 0 test-fss-axis + ." Signals Y Axis" cr 1 test-fss-axis +; + +: selftest ( -- error? ) + + \ skip test during SMT, as the IR PCB is required for controller to + \ respond, issue being worked with Neonode 2012-08. + smt-test? if false exit then + open 0= if ." No touchscreen present" cr false exit then
+ diagnostic-mode? if + 0 to faults + test-os + test-fss + faults if true exit then + then + ." dumping events from touchscreen controller, press a key to stop" cr
\ FIXME: graphically show data on screen until key begin in? if ." rx: " pbuf plen bounds do - i c@ 0 <# # # #> type space + i c@ 2u.x space loop cr then key?
