Author: wmb Date: 2008-10-04 02:10:31 +0200 (Sat, 04 Oct 2008) New Revision: 971
Modified: dev/pckbd.fth Log: OLPC - Added support for new OLPC keyboard controller.
Modified: dev/pckbd.fth =================================================================== --- dev/pckbd.fth 2008-10-01 19:05:29 UTC (rev 970) +++ dev/pckbd.fth 2008-10-04 00:10:31 UTC (rev 971) @@ -102,9 +102,17 @@
: clear-out-buf ( -- ) " clear-out-buf" $call-parent ;
+: timed-read ( #ms -- true | data false ) + 0 do + get-data? if unloop false exit then + 1 ms + loop + true +; + : ?ack ( response -- ) begin h# fa <> while \ Consume stuff while waiting for ack - d# 10 ms get-data? 0= if exit then + d# 10 timed-read if exit then repeat ;
@@ -211,18 +219,36 @@ oem-keymap if oem-keymap /keymap free-mem then 0 to oem-keymap ; + [ifdef] olpc : ?olpc-keyboard ( -- ) " enable-intf" $call-parent - begin get-data? while + begin 5 timed-read 0= while drop true to keyboard-present? - 5 ms repeat keyboard-present? if exit then kbd-reset 0= to keyboard-present? ;
+\ For the ENE keyboard controller we have to tell the EC to use +\ a different internal mapping table. OLPC switched from an +\ ALPS to an ENE controller in late 2007. +: olpc-set-ec-keymap ( -- ) + h# f2 cmd + + \ Keyboards return the ID sequence ab XX + 2 timed-read if exit then ( id1 ) + h# ab <> if exit then + + \ The ENE keyboard controller return ab 41 + 2 timed-read if exit then ( id2 ) + h# 41 <> if exit then + + \ This looks like an ENE controller, so flip the mapping table + h# f7 cmd +; + fload ${BP}/cpu/x86/pc/olpc/keymap.fth [then]
@@ -328,13 +354,13 @@ " us" set-keyboard \ choose-type ; -: consume ( -- ) begin 5 ms get-data? while drop repeat ; +: consume ( -- ) begin 5 timed-read 0= while drop repeat ;
: get-initial-state ( -- ) d# 200 ms \ Give the keyboard time to respond
\ 5 ms is less than the standard auto-repeat rate - begin 5 ms get-data? while handle-initial-scan repeat + begin 5 timed-read 0= while handle-initial-scan repeat
default-disable-kbd \ Clear last typematic key, if any consume @@ -359,7 +385,7 @@ clear-state [ifdef] ?olpc-keyboard ?olpc-keyboard - keyboard-present? if exit then + keyboard-present? if olpc-set-ec-keymap exit then [else] get-initial-state
