Author: wmb Date: 2008-12-05 00:59:50 +0100 (Fri, 05 Dec 2008) New Revision: 1023
Modified: cpu/x86/pc/olpc/nandcastui.fth cpu/x86/pc/olpc/wifichannel.fth Log: OLPC - tweaks to the NANDblaster command line UI.
Modified: cpu/x86/pc/olpc/nandcastui.fth =================================================================== --- cpu/x86/pc/olpc/nandcastui.fth 2008-12-04 09:26:55 UTC (rev 1022) +++ cpu/x86/pc/olpc/nandcastui.fth 2008-12-04 23:59:50 UTC (rev 1023) @@ -40,7 +40,7 @@ >r 2>r ( placement-filename$ r: channel# image-filename$ ) $file-to-mem ( spec$ r: channel# image-filename$ ) swap redundancy 2r> r> ( speclen specadr redundancy image-filename$ channel# ) - " rom:nb_tx ether:%d %s 131072 %d %d %d" sprintf boot-load go + " rom:nb_tx ether:%d %s %d 131072 %d %d" sprintf boot-load go ; : #nb-secure ( zip-filename$ image-filename$ channel# -- ) depth 5 < abort" #nb-secure-update - too few arguments" @@ -48,7 +48,7 @@ load-read sig$ ?save-string swap ( siglen sigadr r: channel# image-filename$ ) img$ ?save-string swap ( siglen sigadr speclen specadr r: channel# image-filename$ ) redundancy 2r> r> ( siglen sigadr speclen specadr redundancy image-filename$ channel# ) - " rom:nb_tx ether:%d %s 131072 %d %d %d %d %d" sprintf boot-load go + " rom:nb_tx ether:%d %s %d 131072 %d %d %d %d" sprintf boot-load go ; : t1 " u:\os767.plc" " u:\os767.img" d# 11 #nb-update ; : t2 " u:\fs.zip" " u:\os767.img" d# 11 #nb-secure ;
Modified: cpu/x86/pc/olpc/wifichannel.fth =================================================================== --- cpu/x86/pc/olpc/wifichannel.fth 2008-12-04 09:26:55 UTC (rev 1022) +++ cpu/x86/pc/olpc/wifichannel.fth 2008-12-04 23:59:50 UTC (rev 1023) @@ -112,6 +112,7 @@ find-multinand-server abort" No multicast NAND server" ( chan# ) #nb ; +alias nb nandblaster
d# 10 constant rssi-threshold : nb-clone ( -- )
