Author: pgf Date: 2010-01-05 20:03:26 +0100 (Tue, 05 Jan 2010) New Revision: 1644
Modified: cpu/x86/pc/olpc/via/assy.fth cpu/x86/pc/olpc/via/runin.fth cpu/x86/pc/olpc/via/smt.fth Log: updates/fixes to production bootfiles
Modified: cpu/x86/pc/olpc/via/assy.fth =================================================================== --- cpu/x86/pc/olpc/via/assy.fth 2010-01-05 16:55:28 UTC (rev 1643) +++ cpu/x86/pc/olpc/via/assy.fth 2010-01-05 19:03:26 UTC (rev 1644) @@ -39,6 +39,7 @@
: put-ka-tag ( value$ key$ -- ) 2over 8 min ka-dir$ " %s%s" sprintf ( value$ key$ filename$ ) + ." Fetching KA tag file " 2dup type cr ( value$ key$ filename$ ) $read-file if ( value$ key$ ) ." ERROR: No KA tag file for " 2swap type cr ( key$ ) 2drop ( ) @@ -162,6 +163,19 @@ get-sn ;
+: safe-delete ( $name -- ) + 2dup $file-exists? if + 2dup $delete + then +; + +: $copy! ( $src $dst -- ) + 2dup $file-exists? if + 2dup $delete + then + $copy1 +; + 0 0 2value response$
: execute-downloads ( adr len -- ) @@ -170,9 +184,12 @@ ?remove-cr ( rem$ line$ ) [char] : left-parse-string ( rem$ value$ key$ ) " Command" $= if ( rem$ value$ ) + ." Will execute:" cr ( rem$ value$ ) + 2dup type cr ( rem$ value$ ) evaluate ( rem$ ) + else + 2drop ( rem$ ) then ( rem$ value$ ) - 2drop ( rem$ ) repeat ( rem$ ) 2drop ( ) ; @@ -192,12 +209,15 @@ ;
: inject-tags ( -- ) + + ." Merging new tags" cr + get-mfg-data
" TS" ($delete-tag) " MS" ($delete-tag) " BD" ($delete-tag) - " NT" ($delete-tag) + \ leave NT so we can use one tag throughout: " NT" ($delete-tag)
sn$ " SN" put-tag fwver$ " BV" put-tag @@ -206,6 +226,8 @@ mac$ " WM" put-tag swdl-date$ " SD" put-tag
+ ." Parsing tags" cr + response$ parse-tags
flash-write-enable @@ -242,10 +264,12 @@ ." Done" cr
response$ execute-downloads + inject-tags
." Powering off ..." d# 2000 ms power-off ;
+." Starting assembly phase" cr start-assy-test
Modified: cpu/x86/pc/olpc/via/runin.fth =================================================================== --- cpu/x86/pc/olpc/via/runin.fth 2010-01-05 16:55:28 UTC (rev 1643) +++ cpu/x86/pc/olpc/via/runin.fth 2010-01-05 19:03:26 UTC (rev 1644) @@ -117,7 +117,7 @@ begin halt again ; : handle-tag ( value$ key$ -- ) - 2dup find-tag if ( value$ key$ old-value$ ) \ Tag already exists, check it + 2dup ram-find-tag if ( value$ key$ old-value$ ) \ Tag already exists, check it 2over " KA" $= 0= if ?-null then ( value$ key$ old-value$' ) 2>r 2over 2r@ $= if ( value$ key$ r: old-value$' ) 2drop 2drop 2r> 2drop ( ) @@ -161,7 +161,7 @@ pop-base ; : make-md-tag ( -- ) - time&date ( s m h d m y ) format-date " MD" put-ascii-tag + time&date ( s m h d m y ) format-date " md" put-ascii-tag ; : inject-tags ( -- ) get-mfg-data @@ -169,6 +169,7 @@ " TS" ($delete-tag) " MS" ($delete-tag) " BD" ($delete-tag) + " NT" ($delete-tag) " MD" ($delete-tag) make-md-tag
@@ -265,7 +266,6 @@ wait-scanner ?usb-keyboard wait-lan -\ wait-usb-key ;
: my-cifs-connect ( adr -- ) @@ -278,12 +278,26 @@ 2>r 2dup 2r> $copy $delete ;
+: $safe-delete ( $name -- ) + 2dup $file-exists? if + 2dup $delete + then +; + +: $copy! ( $src $dst -- ) + 2dup $file-exists? if + 2dup $delete + then + $copy1 +; + + : finish-final-test ( -- ) wait-connections
get-info
-\ verify-rtc-date + verify-rtc-date
." Getting final tags .. " cifs-connect final-tag-exchange \ Note: no disconnect... @@ -295,10 +309,10 @@ final-result cifs-disconnect ." Done" cr
- " int:\runin\olpc.fth" $delete-all + \ need to delete target, due to #9957 + " int:\runin\final.fth.sav" $safe-delete
- \ Ultimately this should just be delete of runin\olpc.fth - " int:\runin\olpc.fth" " int:\runin\runin.sav" do-rename + " int:\runin\final.fth" " int:\runin\final.fth.sav" $rename ;
\ Make the "wait for SD insertion" step highly visible @@ -318,7 +332,7 @@ \ The operator can type this to reset the state to run \ the Linux-based runin tests again. : rerunin ( -- ) - " int:\runin\olpc.fth" $delete-all + " int:\runin\final.fth" $safe-delete fail-log-file$ fail-backup-file$ do-rename ;
@@ -364,4 +378,5 @@
device-end
+." Starting final phase" cr after-runin
Modified: cpu/x86/pc/olpc/via/smt.fth =================================================================== --- cpu/x86/pc/olpc/via/smt.fth 2010-01-05 16:55:28 UTC (rev 1643) +++ cpu/x86/pc/olpc/via/smt.fth 2010-01-05 19:03:26 UTC (rev 1644) @@ -111,10 +111,10 @@ smt-filename$ open-temp-file pass? if " PASS" else " FAIL" then " RESULT=" put-key+value " PROCESS=FVT" put-key-line - " STATION=" put-key-line - " OPID=" put-key-line - " GUID=" put-key-line - board#$ " MB_NUM=" put-key+value + opid$ " OPID=" put-key+value + station#$ " STATION=" put-key+value + board#$ " MB_NUM=" put-key+value + \ " GUID=" put-key-line " Result" submit-file ;
@@ -180,8 +180,9 @@
response$ write-new-tags ( )
+ " EN" " SS" put-ascii-tag ( ) + \ board#$ " B#" put-ascii-tag ( ) -\ " EN" " SS" put-ascii-tag ( ) \ " ASSY" " TS" put-ascii-tag ( ) \ " "(D3)" " SG" ($add-tag) ( )
@@ -263,4 +264,5 @@ dend
\ Automatically run the sequence +." Starting SMT phase" cr start-smt-test
