Author: quozl Date: Fri Jul 6 09:46:38 2012 New Revision: 3039 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3039
Log: TI BSL downloader - reverse polarity of test result report, cleanup messages, report timeout of flush, and initialise UART2 APB clocks and UART enable bit
Modified: cpu/arm/olpc/bsl.fth
Modified: cpu/arm/olpc/bsl.fth ============================================================================== --- cpu/arm/olpc/bsl.fth Wed Jul 4 18:18:52 2012 (r3038) +++ cpu/arm/olpc/bsl.fth Fri Jul 6 09:46:38 2012 (r3039) @@ -41,7 +41,12 @@ \ These are MMP2/3 dependent
: bsl-baud ( baud-rate -- ) \ 9600,8,e,1 - uart-base >r bsl-uart-base to uart-base baud h# 1b 3 uart! r> to uart-base + uart-base >r ( baud-rate r: uart-base ) + bsl-uart-base to uart-base + h# 13 h# 30 apbc! \ enable the uart2 clocks + h# 40 1 uart! \ uart unit enable + baud h# 1b 3 uart! ( r: uart-base ) + r> to uart-base ( ) ;
: bsl-send ( char -- ) uart-base >r bsl-uart-base to uart-base uemit r> to uart-base ; @@ -88,7 +93,16 @@ dly bsl-test-gpio# gpio-clr ; -: flush-bsl ( -- ) begin receive? while drop repeat ; + +: flush-bsl + get-msecs d# 2000 + ( limit ) + begin + receive? 0= if exit then ( limit char ) + drop dup get-msecs - 0< ( limit timeout? ) + until + drop true abort" BSL flush timeout" +; + : rst-bsl ( -- ) msp430-off start-bsl flush-bsl ;
d# 1000 constant timeout @@ -102,6 +116,7 @@ until ( limit ) drop true abort" BSL data timeout" ; + : ack? ( -- okay? ) get-msecs timeout + ( limit ) begin ( limit ) @@ -262,7 +277,6 @@ ;
: force-erase ( -- ) - ." Resetting/erasing" cr rst-bsl ['] 00-password catch drop rst-bsl @@ -368,6 +382,7 @@ : $flash-bsl ( filename$ -- ) $read-open ( ) set-bsl-file-format ( ) + ." Resetting/erasing" cr force-erase ( ) ." Programming" cr begin ( ) @@ -428,7 +443,7 @@ ." Erasing ..." force-erase cr ." Writing ..." bsl-test-data h# 8000 bsl-write cr ( ) ." Verifying ..." bsl-test-data h# 8000 bsl-verify cr ( okay? ) - if ." FAILED!" else ." Good" then cr + if ." Good" else ." FAILED!" then cr ;
\ LICENSE_BEGIN
