Author: wmb Date: Wed Oct 12 00:29:49 2011 New Revision: 2592 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2592
Log: OLPC - changed the IP address for some developer-convenience functions. Only affects Mitch.
Modified: cpu/x86/pc/olpc/fw.bth cpu/x86/pc/olpc/via/fw.bth
Modified: cpu/x86/pc/olpc/fw.bth ============================================================================== --- cpu/x86/pc/olpc/fw.bth Wed Oct 12 00:28:40 2011 (r2591) +++ cpu/x86/pc/olpc/fw.bth Wed Oct 12 00:29:49 2011 (r2592) @@ -644,11 +644,7 @@ quit ;
-: newrom - " flash! http:\10.20.0.14\new.rom" eval -\ " wifi media lab 802.11" eval -\ " flash http:\18.85.46.172\new.rom" eval -; +: newrom " flash! http:\192.168.200.200\new.rom" eval ; : urom " flash! u:\new.rom" eval ;
\ Fancy battery charge logger.
Modified: cpu/x86/pc/olpc/via/fw.bth ============================================================================== --- cpu/x86/pc/olpc/via/fw.bth Wed Oct 12 00:28:40 2011 (r2591) +++ cpu/x86/pc/olpc/via/fw.bth Wed Oct 12 00:29:49 2011 (r2592) @@ -482,8 +482,9 @@ end-support-package devalias smb tcp//cifs devalias cifs tcp//cifs -: op " select smb:\test:testxxx@10.20.0.14\XTest\hello.txt" eval ; -: dsmb " dir smb:\test:testxxx@10.20.0.14\XTest" eval ; +\ Examples: +\ select smb:\test:testxxx@10.20.0.14\XTest\hello.txt +\ dir smb:\test:testxxx@10.20.0.14\XTest\
fload ${BP}/cpu/x86/pc/olpc/via/memtest.fth
@@ -733,9 +734,7 @@
: newrom enable-serial - " flash! http:\10.20.0.14\new.rom" eval -\ " wifi media lab 802.11" eval -\ " flash http:\18.85.46.172\new.rom" eval + " flash! http:\192.168.200.200\new.rom" eval ; : urom enable-serial " flash! u:\new.rom" eval ; : qrom enable-serial " essid qz" eval " flash http:\olpc.lan\qrom.rom" eval ;
