Author: wmb Date: 2009-11-13 21:47:00 +0100 (Fri, 13 Nov 2009) New Revision: 1471
Modified: cpu/x86/pc/olpc/via/startgfxrestore.fth Log: Via - restore display FIFO registers and other tuning knobs in S3 resume.
Modified: cpu/x86/pc/olpc/via/startgfxrestore.fth =================================================================== --- cpu/x86/pc/olpc/via/startgfxrestore.fth 2009-11-13 20:40:24 UTC (rev 1470) +++ cpu/x86/pc/olpc/via/startgfxrestore.fth 2009-11-13 20:47:00 UTC (rev 1471) @@ -31,78 +31,163 @@
\ olpc-lcd-mode
-c0 1b seq-set \ Secondary engine clock (LCK) can be gated on or off +c0 1b seq-set \ Secondary engine clock (LCK) can be gated on or off
-80 17 crt-clr \ Assert reset while programming geometry +80 17 crt-clr \ Assert reset while programming geometry
crtc-table - 30 36 ireg \ Turn off primary DAC to save power + 30 36 ireg \ Turn off primary DAC to save power
- d7 50 ireg \ Htotal low - af 51 ireg \ Hdisplay low - af 52 ireg \ Hblank low - d7 53 ireg \ Hblankend - 24 54 ireg \ Hblank, Hblankend overflow - 44 55 ireg \ Htotal and hdisplay overflow - \ b7 56 ireg \ Hsync low - b5 56 ireg \ Hsync low - bd 57 ireg \ Hsyncend low - 8f 58 ireg \ Vtotal low - 83 59 ireg \ Vdisplay low - 83 5a ireg \ Vblank low - 8f 5b ireg \ Vblankend low - 9b 5c ireg \ Hsync,Hsyncend,Vblank,Vblankend overflow - 1b 5d ireg \ Hblankend, Hsync, Vtotal, Vdisplay overflow - 88 5e ireg \ Vsync low - 6a 5f ireg \ Vsyncend all and Vsync overflow + d7 50 ireg \ Htotal low + af 51 ireg \ Hdisplay low + af 52 ireg \ Hblank low + d7 53 ireg \ Hblankend + 24 54 ireg \ Hblank, Hblankend overflow + 44 55 ireg \ Htotal and hdisplay overflow + \ b7 56 ireg \ Hsync low + b5 56 ireg \ Hsync low + bd 57 ireg \ Hsyncend low + 8f 58 ireg \ Vtotal low + 83 59 ireg \ Vdisplay low + 83 5a ireg \ Vblank low + 8f 5b ireg \ Vblankend low + 9b 5c ireg \ Hsync,Hsyncend,Vblank,Vblankend overflow + 1b 5d ireg \ Hblankend, Hsync, Vtotal, Vdisplay overflow + 88 5e ireg \ Vsync low + 6a 5f ireg \ Vsyncend all and Vsync overflow
- 00 62 ireg \ Starting address - 00 63 ireg \ Starting address - 00 64 ireg \ Starting address + 00 62 ireg \ Starting address + 00 63 ireg \ Starting address + 00 64 ireg \ Starting address
- 96 65 ireg \ Fetch count (67 overflow already set above) - 2c 66 ireg \ Offset (frame buffer pitch) low (67 overflow already set above) - 51 67 ireg \ Color depth - 16bpp ([7:6] = 10) - no interlace ([5] = 0), various overflow bits - f0 68 ireg \ Display queue depth - c8 6a ireg \ Enable secondary display - 00 6b ireg \ Disable simultaneous display, IGA2 on, IGA2 screen enable not slaved to IGA1 + 96 65 ireg \ Fetch count (67 overflow already set above) + 2c 66 ireg \ Offset (frame buffer pitch) low (67 overflow already set above) + 51 67 ireg \ Color depth - 16bpp ([7:6] = 10) - no interlace ([5] = 0), various overflow bits + f0 68 ireg \ Display queue depth + c8 6a ireg \ Enable secondary display + 00 6b ireg \ Disable simultaneous display, IGA2 on, IGA2 screen enable not slaved to IGA1
- 00 6c ireg \ VCK source from PLL output clock, LCKCK PLL source from X1 pin + 00 6c ireg \ VCK source from PLL output clock, LCKCK PLL source from X1 pin
- 00 71 ireg \ Offset overflow - 00 79 ireg \ LCD scaling off + 00 71 ireg \ Offset overflow + 00 79 ireg \ LCD scaling off
- 60 88 ireg \ LVDS sequential - 01 8a ireg \ LCD adjust LP - 08 94 ireg \ Expire number - 11 95 ireg \ extension bits - 10 97 ireg \ LVDS channel 2 - secondary display - 1b 9b ireg \ DVP mode - alpha:80, VSYNC:40, HSYNC:20, secondary:10, clk polarity:8, clk adjust:7 - 00 a3 ireg \ IGA2 frame buffer is system local memory, address bits [28:26] are 0 - 8b a7 ireg \ expected vertical display low - 01 a8 ireg \ expected vertical display high + 60 88 ireg \ LVDS sequential + 01 8a ireg \ LCD adjust LP + 08 94 ireg \ Expire number + 11 95 ireg \ extension bits + 10 97 ireg \ LVDS channel 2 - secondary display + 1b 9b ireg \ DVP mode - alpha:80, VSYNC:40, HSYNC:20, secondary:10, clk polarity:8, clk adjust:7 + 00 a3 ireg \ IGA2 frame buffer is system local memory, address bits [28:26] are 0 + 8b a7 ireg \ expected vertical display low + 01 a8 ireg \ expected vertical display high
- 80 f3 ireg \ 18-bit TTL LCD - 0a f9 ireg \ V1 power mode exit delay - 0d fb ireg \ IGA2 Interlace VSYNC timing + 80 f3 ireg \ 18-bit TTL LCD + 0a f9 ireg \ V1 power mode exit delay + 0d fb ireg \ IGA2 Interlace VSYNC timing end-table
+\ general-init +01 1e seq-set \ ROC ECK seq-table - 9f 4a ireg \ 2nd PLL value 0 - 0c 4b ireg \ 2nd PLL value 1 - 05 4c ireg \ 2nd PLL value 2 - 04 40 ireg \ Pulse LCDCK PLL reset - 00 40 ireg \ Release LCDCK PLL reset + 00 20 ireg \ max queuing number (but manual recommends 4) + 14 22 ireg \ (display queue request expire number) + 40 34 ireg \ not documented + 01 3b ireg \ not documented + 38 40 ireg \ ECK freq + 30 4d ireg \ preempt arbiter end-table
-3cc port-rb 0c bitset 3c2 # dx mov al dx out \ use external clock (MISC register reads at 3cc, writes at 3c2) +crtc-table + 08 30 ireg \ DAC speed enhancement + 01 3b ireg \ Scratch 2 + 08 3c ireg \ Scratch 3 + c0 f7 ireg \ Spread spectrum + 01 32 ireg \ real time flipping (I think we can ignore this) +end-table
-80 17 crt-set \ Release reset +\ legacy-settings +seq-table + 00 00 ireg \ Reset sequencer + 01 01 ireg \ 8/9 timing + 0f 02 ireg \ Enable map planes + 00 03 ireg \ Character map select + 06 04 ireg \ Extended memory present + 03 00 ireg \ Release reset bits + 00 0a ireg \ Cursor start + 00 0b ireg \ Cursor end + 00 0e ireg \ Cursor loc + 00 0f ireg \ Cursor loc +end-table
-60 78 seq-set \ Inverse HSYNC and VSYNC on IGA2 for LVDS -30 1e seq-set \ Power up DVP1 pads -0c 2a seq-set \ Power up LVDS pads -30 1b seq-set \ Turn off primary engine clock to save power +crtc-table + 00 11 ireg \ Refreshes per line, disable vert intr + 23 17 ireg \ address wrap, sequential access, not CGA compat mode +end-table + +\ tune-fifos +seq-table + 60 16 ireg \ FIFO threshold + 1f 17 ireg \ FIFO depth (VX855 value) + 4e 18 ireg \ Display Arbiter (VX855 value) + + 18 21 ireg \ (typical request track FIFO number channel 0 + 1f 50 ireg \ FIFO + 81 51 ireg \ FIFO - 81 enable Northbridge FIFO + 00 57 ireg \ FIFO + 08 58 ireg \ Display FIFO low threshold select + 20 66 ireg \ request kill + 20 67 ireg \ request kill + 20 69 ireg \ request kill + 20 70 ireg \ request kill + 0f 72 ireg \ FIFO + 08 79 ireg \ request kill + 10 7a ireg \ request kill + c8 7c ireg \ request kill +end-table + +\ lower-power +seq-table + 7f 19 ireg \ clock gating + f0 1b ireg \ clock gating + ff 2d ireg \ Power control enables + ff 2e ireg \ clock gating + ff 3f ireg \ clock gating + 5f 4f ireg \ clock gating threshold + df 59 ireg \ clock gating + 00 a8 ireg \ leave on ROC ECK in C0 + 00 a9 ireg \ leave on ROC ECK in C1 + 80 aa ireg \ gate off ROC ECK in C4 + 80 ab ireg \ gate off ROC ECK in C3 + 00 ac ireg \ leave on ROC ECK in S3 + 00 ad ireg \ leave on ROC ECK in S1 Snapshot + 00 ae ireg \ leave on ROC ECK in C4P + 00 af ireg \ leave on ROC ECK in reserved state +end-table + +crtc-table + 01 36 ireg \ Enable PCI power management control + 34 37 ireg \ DAC power savings +end-table + +\ end of lower-power + +seq-table + 9f 4a ireg \ 2nd PLL value 0 + 0c 4b ireg \ 2nd PLL value 1 + 05 4c ireg \ 2nd PLL value 2 + 04 40 ireg \ Pulse LCDCK PLL reset + 00 40 ireg \ Release LCDCK PLL reset +end-table + +3cc port-rb 0c bitset 3c2 # dx mov al dx out \ use external clock (MISC register reads at 3cc, writes at 3c2) + +80 17 crt-set \ Release reset + +60 78 seq-set \ Inverse HSYNC and VSYNC on IGA2 for LVDS +30 1e seq-set \ Power up DVP1 pads +0c 2a seq-set \ Power up LVDS pads +30 1b seq-set \ Turn off primary engine clock to save power
d# 32000 wait-us \ Wait for DCON_BLNK to be low @@ -113,7 +198,7 @@ 0<> while d# 1000 wait-us cx dec -0= until then \ "then" resolves "while" +0= until then \ "then" resolves "while"
\ This is a cheesy way to set the DCON LOAD bit -- ff acpi-io-base 4d + port-wb \ B1 and B2 - DCON LOAD is the 0x04 bit (bit number 2) of PMIO+4d
