Author: wmb Date: 2009-10-16 01:43:00 +0200 (Fri, 16 Oct 2009) New Revision: 1423
Modified: cpu/x86/pc/biosints.fth cpu/x86/pc/olpc/via/addrs.fth cpu/x86/pc/olpc/via/fw.bth cpu/x86/pc/olpc/via/probemem.fth Log: OLPC trac 9486 - Added SMI and BIOS interrupt handling to XO-1.5 build.
Modified: cpu/x86/pc/biosints.fth =================================================================== --- cpu/x86/pc/biosints.fth 2009-10-15 23:40:38 UTC (rev 1422) +++ cpu/x86/pc/biosints.fth 2009-10-15 23:43:00 UTC (rev 1423) @@ -481,15 +481,7 @@ show-reads? if dup . cr then ;
-0 value entry-count -: ?hack - entry-count dup 1+ to entry-count 1 = if - hack-fix-mode - then -; - : bios-write-sectors ( adr sector# #sectors -- #read ) -\ ?hack noshow
\ ." Write " 2 pick . over . dup . ." -- "
Modified: cpu/x86/pc/olpc/via/addrs.fth =================================================================== --- cpu/x86/pc/olpc/via/addrs.fth 2009-10-15 23:40:38 UTC (rev 1422) +++ cpu/x86/pc/olpc/via/addrs.fth 2009-10-15 23:43:00 UTC (rev 1423) @@ -77,7 +77,8 @@ h# fd000 constant ssdt-adr
h# ffc00 constant smbios-adr -h# fff00 constant wake-adr +h# fff00 constant wake-adr \ Needs to be at least h# 32 bytes - used in acpi.fth +h# fff40 constant rm-buf \ 8-byte buffer used by BIOS INT 15 AH=C0 for returning config info
h# 3e.0000 constant inflate-base h# 30.0000 constant workspace
Modified: cpu/x86/pc/olpc/via/fw.bth =================================================================== --- cpu/x86/pc/olpc/via/fw.bth 2009-10-15 23:40:38 UTC (rev 1422) +++ cpu/x86/pc/olpc/via/fw.bth 2009-10-15 23:43:00 UTC (rev 1423) @@ -360,10 +360,10 @@
fload ${BP}/cpu/x86/pc/olpc/via/smbios.fth
-[ifdef] Later -fload ${BP}/dev/geode/smi.fth +fload ${BP}/dev/via/smi.fth \ fload ${BP}/cpu/x86/pc/biosload/rmenter.fth fload ${BP}/cpu/x86/pc/biosints.fth +[ifdef] Later fload ${BP}/cpu/x86/pc/olpc/biosresume.fth [then]
Modified: cpu/x86/pc/olpc/via/probemem.fth =================================================================== --- cpu/x86/pc/olpc/via/probemem.fth 2009-10-15 23:40:38 UTC (rev 1422) +++ cpu/x86/pc/olpc/via/probemem.fth 2009-10-15 23:43:00 UTC (rev 1423) @@ -12,6 +12,14 @@ \ Excludes RAM assigned to the frame buffer and used by OFW page tables : system-ram ( -- offset ) mem-info-pa 4 + l@ ;
+: fbphys ( -- adr ) + h# 6d h# 3c4 pc! h# 3c5 pc@ ( low ) + h# 6e h# 3c4 pc! h# 3c5 pc@ ( low high ) + bwjoin d# 21 lshift +; + +: fbsize ( -- n ) total-ram fbphys - ; + dev /memory
\ Excludes RAM already used for page tables
