Author: wmb Date: Mon Oct 3 23:36:09 2011 New Revision: 2571 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2571
Log: OLPC XO-1.75 - Removed some redundant code.
Modified: cpu/arm/olpc/1.75/devices.fth
Modified: cpu/arm/olpc/1.75/devices.fth ============================================================================== --- cpu/arm/olpc/1.75/devices.fth Mon Oct 3 23:27:28 2011 (r2570) +++ cpu/arm/olpc/1.75/devices.fth Mon Oct 3 23:36:09 2011 (r2571) @@ -4,26 +4,8 @@ \ h# 30000 +io to uart-base \ UART1 base address on MMP2 d# 26000000 to uart-clock-frequency
-: init-clocks - -1 h# 51024 io! \ PMUM_CGR_PJ - everything on - h# 07 h# 15064 io! \ APBC_AIB_CLK_RST - reset, functional and APB clock on - h# 03 h# 15064 io! \ APBC_AIB_CLK_RST - release reset, functional and APB clock on - h# 13 h# 1502c io! \ APBC_UART1_CLK_RST - VCTCXO, functional and APB clock on (26 mhz) - h# 13 h# 15034 io! \ APBC_UART3_CLK_RST - VCTCXO, functional and APB clock on (26 mhz) - h# c1 h# 1e0c8 io! \ GPIO29 = af1 for UART1 RXD - h# c1 h# 1e0cc io! \ GPIO30 = af1 for UART1 TXD - h# c4 h# 1e260 io! \ GPIO115 = af4 for UART3 RXD - h# c4 h# 1e264 io! \ GPIO116 = af4 for UART3 TXD -; - -: inituarts ( -- ) - init-clocks - - h# 40 1 uart! \ Marvell-specific UART Enable bit - 3 3 uart! \ 8 bits, no parity - 7 2 uart! \ Clear and enable FIFOs - d# 115200 baud -; +\ CForth has already set up the serial port +: inituarts ( -- ) ;
fload ${BP}/forth/lib/sysuart.fth \ Set console I/O vectors to UART
