Author: quozl Date: Tue Nov 1 06:29:32 2011 New Revision: 2659 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2659
Log: OLPC XO-1.75 - split accelerometer debugging code into a separate file.
Added: cpu/arm/olpc/1.75/accelerometer.txt Modified: cpu/arm/olpc/1.75/accelerometer.fth
Modified: cpu/arm/olpc/1.75/accelerometer.fth ============================================================================== --- cpu/arm/olpc/1.75/accelerometer.fth Mon Oct 31 10:10:14 2011 (r2658) +++ cpu/arm/olpc/1.75/accelerometer.fth Tue Nov 1 06:29:32 2011 (r2659) @@ -14,259 +14,6 @@ : accelerometer-on ( -- ) h# 47 ctl1! ; : accelerometer-off ( -- ) h# 07 ctl1! ;
-0 [if] - -select /accelerometer - -: temperature-on ( -- ) h# c0 h# 1f acc-reg! ; -: bdu ( -- ) h# 23 acc-reg@ h# 80 or h# 23 acc-reg! ; -: adc1@ ( -- ) h# 08 acc-reg@ h# 09 acc-reg@ bwjoin wext 5 >>a ; -: adc2@ ( -- ) h# 0a acc-reg@ h# 0b acc-reg@ bwjoin wext 5 >>a ; - -: wait-adc3 begin h# 07 acc-reg@ h# 04 and until ; -: adc3@ ( -- l h ) - h# 0c acc-reg@ h# 0d acc-reg@ bwjoin wext 5 >>a -; -: 1hz ( -- ) h# 20 acc-reg@ h# 0f and h# 10 or h# 20 acc-reg! ; - -: .xr ( n -- ) push-hex 2 .r pop-base space ; -: .dr ( n -- ) push-decimal 3 .r pop-base space ; -: .br ( n -- ) - push-binary 0 <# # # # # [char] . hold # # # # #> type pop-base space ; -: .status-aux h# 07 acc-reg@ .br ; - -: .reg ( register -- value ) - space - dup .xr ." : " ( register ) - acc-reg@ ( value ) - dup .br - dup .xr - dup .dr -; - -: .ureg ( register -- ) - ." " .reg drop -; - -: .regs ( -- ) - h# 07 h# 00 do i .ureg cr loop - - ." STATUS_AUX " h# 07 .reg - dup h# 80 and if ." 321OR " then - dup h# 40 and if ." 3OR " then - dup h# 20 and if ." 2OR " then - dup h# 10 and if ." 1OR " then - dup h# 08 and if ." 321DA " then - dup h# 04 and if ." 3DA " then - dup h# 02 and if ." 2DA " then - dup h# 01 and if ." 1DA " then - drop cr - - ." OUT_1_L " h# 08 .reg cr - ." OUT_1_H " h# 09 .reg - bwjoin wext 5 >>a ." ( " .d ." )" cr - - ." OUT_2_L " h# 0A .reg cr - ." OUT_2_H " h# 0B .reg - bwjoin wext 5 >>a ." ( " .d ." )" cr - - ." OUT_3_L " h# 0C .reg cr - ." OUT_3_H " h# 0D .reg - bwjoin wext 5 >>a ." ( " .d ." )" cr - - ." INT_COUNTER " h# 0E .reg drop cr - ." WHO_AM_I " h# 0F .reg b# 0011.0011 = if ." ok" else ." bad" then cr - - h# 1f h# 10 do i .ureg cr loop - - ." TEMP_CFG_REG " h# 1F .reg - dup h# 80 and if ." ADC_PD " then - dup h# 40 and if ." TEMP_EN " then - dup h# 3f and if ." mbz " then - drop cr - - ." CTRL_REG1 " h# 20 .reg - dup h# f0 and 4 rshift - dup h# 00 = if ." [power-down] " then - dup h# 01 = if ." [1 Hz] " then - dup h# 02 = if ." [10 Hz] " then - dup h# 03 = if ." [25 Hz] " then - dup h# 04 = if ." [50 Hz] " then - dup h# 05 = if ." [100 Hz] " then - dup h# 06 = if ." [200 Hz] " then - dup h# 07 = if ." [400 Hz] " then - dup h# 08 = if ." [1.6 kHz] " then - dup h# 09 = if ." [1.25 kHz / 5 kHz] " then - drop - dup h# 08 and if ." LPen " then - dup h# 04 and if ." Zen " then - dup h# 02 and if ." Yen " then - dup h# 01 and if ." Xen " then - drop cr - - ." CTRL_REG2 " h# 21 .reg - dup h# 80 and if ." HPM1 " then - dup h# 40 and if ." HPM0 " then - dup h# 20 and if ." HPCF2 " then - dup h# 10 and if ." HPCF1 " then - dup h# 08 and if ." FDS " then - dup h# 04 and if ." HPCLICK " then - dup h# 02 and if ." HPIS2 " then - dup h# 01 and if ." HPIS1 " then - drop cr - - ." CTRL_REG3 " h# 22 .reg - dup h# 80 and if ." I1_CLICK " then - dup h# 40 and if ." I1_AOI1 " then - dup h# 20 and if ." I1_AOI2 " then - dup h# 10 and if ." I1_DRDY1 " then - dup h# 08 and if ." I1_DRDY2 " then - dup h# 04 and if ." I1_WTM " then - dup h# 02 and if ." I1_OVERRUN " then - dup h# 01 and if ." rsvd " then - drop cr - - ." CTRL_REG4 " h# 23 .reg - dup h# 80 and if ." BDU " then - dup h# 40 and if ." BLE " then - dup h# 20 and if ." FS1 " then - dup h# 10 and if ." FS2 " then - dup h# 08 and if ." HR " then - dup h# 04 and if ." ST1 " then - dup h# 02 and if ." ST0 " then - dup h# 01 and if ." SIM " then - drop cr - - ." CTRL_REG5 " h# 24 .reg - dup h# 80 and if ." BOOT " then - dup h# 40 and if ." FIFO_EN " then - dup h# 20 and if ." rsvd " then - dup h# 10 and if ." rsvd " then - dup h# 08 and if ." LIR_INT1 " then - dup h# 04 and if ." D4D_INT1 " then - dup h# 02 and if ." mbz " then - dup h# 01 and if ." mbz " then - drop cr - - ." CTRL_REG6 " h# 25 .reg - dup h# 80 and if ." I2_CLICKen " then - dup h# 40 and if ." I2_INT1 " then - dup h# 20 and if ." mbz " then - dup h# 10 and if ." BOOT_I1 " then - dup h# 08 and if ." mbz " then - dup h# 04 and if ." rsvd " then - dup h# 02 and if ." H_LACTIVE " then - dup h# 01 and if ." rsvd " then - drop cr - - ." REFERENCE " h# 26 .reg drop cr - - ." STATUS_REG " h# 27 .reg - dup h# 80 and if ." ZYXOR " then - dup h# 40 and if ." ZOR " then - dup h# 20 and if ." YOR " then - dup h# 10 and if ." XOR " then - dup h# 08 and if ." ZYXDA " then - dup h# 04 and if ." ZDA " then - dup h# 02 and if ." YDA " then - dup h# 01 and if ." ZDA " then - drop cr - - ." OUT_X_L " h# 28 .reg cr - ." OUT_X_H " h# 29 .reg - bwjoin wext 5 >>a ." ( " .d ." )" cr - - ." OUT_Y_L " h# 2a .reg cr - ." OUT_Y_H " h# 2b .reg - bwjoin wext 5 >>a ." ( " .d ." )" cr - - ." OUT_Z_L " h# 2c .reg cr - ." OUT_Z_H " h# 2d .reg - bwjoin wext 5 >>a ." ( " .d ." )" cr - - ." FIFO_CTRL_REG" h# 2e .reg - dup h# 80 and if ." FM1 " then - dup h# 40 and if ." FM0 " then - dup h# 20 and if ." TR " then - dup h# 10 and if ." FTH4 " then - dup h# 08 and if ." FTH3 " then - dup h# 04 and if ." FTH2 " then - dup h# 02 and if ." FTH1 " then - dup h# 01 and if ." FTH0 " then - drop cr - - ." FIFO_SRC_REG " h# 2f .reg - dup h# 80 and if ." WTM " then - dup h# 40 and if ." OVRN_FIFO " then - dup h# 20 and if ." EMPTY " then - dup h# 10 and if ." FSS4 " then - dup h# 08 and if ." FSS3 " then - dup h# 04 and if ." FSS2 " then - dup h# 02 and if ." FSS1 " then - dup h# 01 and if ." FSS0 " then - drop cr - - ." INT1_CFG " h# 30 .reg - dup h# 80 and if ." AOI " then - dup h# 40 and if ." 6D " then - dup h# 20 and if ." ZHIE/ZUPE " then - dup h# 10 and if ." ZLIE/ZDOWNE " then - dup h# 08 and if ." YHIE/YUPE " then - dup h# 04 and if ." YLIE/YDOWNE " then - dup h# 02 and if ." XHIE/XUPE " then - dup h# 01 and if ." XLIE/XDOWNE " then - drop cr - - ." INT1_SRC " h# 31 .reg - dup h# 80 and if ." mbz " then - dup h# 40 and if ." IA " then - dup h# 20 and if ." ZH " then - dup h# 10 and if ." ZL " then - dup h# 08 and if ." YH " then - dup h# 04 and if ." YL " then - dup h# 02 and if ." XH " then - dup h# 01 and if ." XL " then - drop cr - - ." INT1_THS " h# 32 .reg drop cr - ." INT1_DURATION" h# 33 .reg drop cr - - h# 38 h# 34 do i .ureg cr loop - - ." CLICK_CFG " h# 38 .reg - dup h# 80 and if ." rsvd " then - dup h# 40 and if ." rsvd " then - dup h# 20 and if ." ZD " then - dup h# 10 and if ." ZS " then - dup h# 08 and if ." YD " then - dup h# 04 and if ." YS " then - dup h# 02 and if ." XD " then - dup h# 01 and if ." XS " then - drop cr - - ." CLICK_SRC " h# 39 .reg - dup h# 80 and if ." rsvd " then - dup h# 40 and if ." IA " then - dup h# 20 and if ." DCLICK " then - dup h# 10 and if ." SCLICK " then - dup h# 08 and if ." Sign " then - dup h# 04 and if ." Z " then - dup h# 02 and if ." Y " then - dup h# 01 and if ." X " then - drop cr - - ." CLICK_THS " h# 3a .reg drop cr - ." TIME_LIMIT " h# 3b .reg drop cr - ." TIME_LATENCY " h# 3c .reg drop cr - ." TIME_WINDOW " h# 3d .reg drop cr - h# 3e .ureg cr - h# 3f .ureg cr - - \ register decode window is 00-7f, then 80-ff is a mirror -; -[then] - -: bext ( b -- n ) dup h# 80 and if h# ffffff00 or then ; : wext ( b -- n ) dup h# 8000 and if h# ffff0000 or then ; : acceleration@ ( -- x y z ) h# 28 acc-reg@ h# 29 acc-reg@ bwjoin wext 5 >>a
Added: cpu/arm/olpc/1.75/accelerometer.txt ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/olpc/1.75/accelerometer.txt Tue Nov 1 06:29:32 2011 (r2659) @@ -0,0 +1,268 @@ +\ accelerometer code for potential future use or debugging + +\ analog to digital converter +: adc1@ ( -- ) h# 08 acc-reg@ h# 09 acc-reg@ bwjoin wext 5 >>a ; +: adc2@ ( -- ) h# 0a acc-reg@ h# 0b acc-reg@ bwjoin wext 5 >>a ; + +\ temperature sensor +: temperature-on ( -- ) h# c0 h# 1f acc-reg! ; +: temperature@ ( -- l h ) + begin h# 07 acc-reg@ h# 04 and until + h# 0c acc-reg@ h# 0d acc-reg@ bwjoin wext 5 >>a +; + +\ block data update +: bdu ( -- ) h# 23 acc-reg@ h# 80 or h# 23 acc-reg! ; + +\ sample rate setting +: odr! ( n -- ) 4 lshift h# 20 acc-reg@ h# 0f and or h# 20 acc-reg! ; + +: 1hz ( -- ) 1 odr! ; +: 10hz ( -- ) 2 odr! ; +: 25hz ( -- ) 3 odr! ; +: 50hz ( -- ) 4 odr! ; \ power up default +: 100hz ( -- ) 5 odr! ; +: 200hz ( -- ) 6 odr! ; +: 400hz ( -- ) 7 odr! ; +: 1.6khz ( -- ) 8 odr! ; +: 5khz ( -- ) 9 odr! ; + +\ sign extend a byte +: bext ( b -- n ) dup h# 80 and if h# ffffff00 or then ; + +\ register dump + +: .xr ( n -- ) push-hex 2 .r pop-base space ; +: .dr ( n -- ) push-decimal 3 .r pop-base space ; +: .br ( n -- ) + push-binary 0 <# # # # # [char] . hold # # # # #> type pop-base space ; + +: .reg ( register -- value ) + space + dup .xr ." : " ( register ) + acc-reg@ ( value ) + dup .br + dup .xr + dup .dr +; + +: .ureg ( register -- ) + ." " .reg drop +; + +: .regs ( -- ) + h# 07 h# 00 do i .ureg cr loop + + ." STATUS_AUX " h# 07 .reg + dup h# 80 and if ." 321OR " then + dup h# 40 and if ." 3OR " then + dup h# 20 and if ." 2OR " then + dup h# 10 and if ." 1OR " then + dup h# 08 and if ." 321DA " then + dup h# 04 and if ." 3DA " then + dup h# 02 and if ." 2DA " then + dup h# 01 and if ." 1DA " then + drop cr + + ." OUT_1_L " h# 08 .reg cr + ." OUT_1_H " h# 09 .reg + bwjoin wext 5 >>a ." ( " .d ." )" cr + + ." OUT_2_L " h# 0A .reg cr + ." OUT_2_H " h# 0B .reg + bwjoin wext 5 >>a ." ( " .d ." )" cr + + ." OUT_3_L " h# 0C .reg cr + ." OUT_3_H " h# 0D .reg + bwjoin wext 5 >>a ." ( " .d ." )" cr + + ." INT_COUNTER " h# 0E .reg drop cr + ." WHO_AM_I " h# 0F .reg b# 0011.0011 = if ." ok" else ." bad" then cr + + h# 1f h# 10 do i .ureg cr loop + + ." TEMP_CFG_REG " h# 1F .reg + dup h# 80 and if ." ADC_PD " then + dup h# 40 and if ." TEMP_EN " then + dup h# 3f and if ." mbz " then + drop cr + + ." CTRL_REG1 " h# 20 .reg + dup h# f0 and 4 rshift + dup h# 00 = if ." [power-down] " then + dup h# 01 = if ." [1 Hz] " then + dup h# 02 = if ." [10 Hz] " then + dup h# 03 = if ." [25 Hz] " then + dup h# 04 = if ." [50 Hz] " then + dup h# 05 = if ." [100 Hz] " then + dup h# 06 = if ." [200 Hz] " then + dup h# 07 = if ." [400 Hz] " then + dup h# 08 = if ." [1.6 kHz] " then + dup h# 09 = if ." [1.25 kHz / 5 kHz] " then + drop + dup h# 08 and if ." LPen " then + dup h# 04 and if ." Zen " then + dup h# 02 and if ." Yen " then + dup h# 01 and if ." Xen " then + drop cr + + ." CTRL_REG2 " h# 21 .reg + dup h# 80 and if ." HPM1 " then + dup h# 40 and if ." HPM0 " then + dup h# 20 and if ." HPCF2 " then + dup h# 10 and if ." HPCF1 " then + dup h# 08 and if ." FDS " then + dup h# 04 and if ." HPCLICK " then + dup h# 02 and if ." HPIS2 " then + dup h# 01 and if ." HPIS1 " then + drop cr + + ." CTRL_REG3 " h# 22 .reg + dup h# 80 and if ." I1_CLICK " then + dup h# 40 and if ." I1_AOI1 " then + dup h# 20 and if ." I1_AOI2 " then + dup h# 10 and if ." I1_DRDY1 " then + dup h# 08 and if ." I1_DRDY2 " then + dup h# 04 and if ." I1_WTM " then + dup h# 02 and if ." I1_OVERRUN " then + dup h# 01 and if ." rsvd " then + drop cr + + ." CTRL_REG4 " h# 23 .reg + dup h# 80 and if ." BDU " then + dup h# 40 and if ." BLE " then + dup h# 20 and if ." FS1 " then + dup h# 10 and if ." FS2 " then + dup h# 08 and if ." HR " then + dup h# 04 and if ." ST1 " then + dup h# 02 and if ." ST0 " then + dup h# 01 and if ." SIM " then + drop cr + + ." CTRL_REG5 " h# 24 .reg + dup h# 80 and if ." BOOT " then + dup h# 40 and if ." FIFO_EN " then + dup h# 20 and if ." rsvd " then + dup h# 10 and if ." rsvd " then + dup h# 08 and if ." LIR_INT1 " then + dup h# 04 and if ." D4D_INT1 " then + dup h# 02 and if ." mbz " then + dup h# 01 and if ." mbz " then + drop cr + + ." CTRL_REG6 " h# 25 .reg + dup h# 80 and if ." I2_CLICKen " then + dup h# 40 and if ." I2_INT1 " then + dup h# 20 and if ." mbz " then + dup h# 10 and if ." BOOT_I1 " then + dup h# 08 and if ." mbz " then + dup h# 04 and if ." rsvd " then + dup h# 02 and if ." H_LACTIVE " then + dup h# 01 and if ." rsvd " then + drop cr + + ." REFERENCE " h# 26 .reg drop cr + + ." STATUS_REG " h# 27 .reg + dup h# 80 and if ." ZYXOR " then + dup h# 40 and if ." ZOR " then + dup h# 20 and if ." YOR " then + dup h# 10 and if ." XOR " then + dup h# 08 and if ." ZYXDA " then + dup h# 04 and if ." ZDA " then + dup h# 02 and if ." YDA " then + dup h# 01 and if ." ZDA " then + drop cr + + ." OUT_X_L " h# 28 .reg cr + ." OUT_X_H " h# 29 .reg + bwjoin wext 5 >>a ." ( " .d ." )" cr + + ." OUT_Y_L " h# 2a .reg cr + ." OUT_Y_H " h# 2b .reg + bwjoin wext 5 >>a ." ( " .d ." )" cr + + ." OUT_Z_L " h# 2c .reg cr + ." OUT_Z_H " h# 2d .reg + bwjoin wext 5 >>a ." ( " .d ." )" cr + + ." FIFO_CTRL_REG" h# 2e .reg + dup h# 80 and if ." FM1 " then + dup h# 40 and if ." FM0 " then + dup h# 20 and if ." TR " then + dup h# 10 and if ." FTH4 " then + dup h# 08 and if ." FTH3 " then + dup h# 04 and if ." FTH2 " then + dup h# 02 and if ." FTH1 " then + dup h# 01 and if ." FTH0 " then + drop cr + + ." FIFO_SRC_REG " h# 2f .reg + dup h# 80 and if ." WTM " then + dup h# 40 and if ." OVRN_FIFO " then + dup h# 20 and if ." EMPTY " then + dup h# 10 and if ." FSS4 " then + dup h# 08 and if ." FSS3 " then + dup h# 04 and if ." FSS2 " then + dup h# 02 and if ." FSS1 " then + dup h# 01 and if ." FSS0 " then + drop cr + + ." INT1_CFG " h# 30 .reg + dup h# 80 and if ." AOI " then + dup h# 40 and if ." 6D " then + dup h# 20 and if ." ZHIE/ZUPE " then + dup h# 10 and if ." ZLIE/ZDOWNE " then + dup h# 08 and if ." YHIE/YUPE " then + dup h# 04 and if ." YLIE/YDOWNE " then + dup h# 02 and if ." XHIE/XUPE " then + dup h# 01 and if ." XLIE/XDOWNE " then + drop cr + + ." INT1_SRC " h# 31 .reg + dup h# 80 and if ." mbz " then + dup h# 40 and if ." IA " then + dup h# 20 and if ." ZH " then + dup h# 10 and if ." ZL " then + dup h# 08 and if ." YH " then + dup h# 04 and if ." YL " then + dup h# 02 and if ." XH " then + dup h# 01 and if ." XL " then + drop cr + + ." INT1_THS " h# 32 .reg drop cr + ." INT1_DURATION" h# 33 .reg drop cr + + h# 38 h# 34 do i .ureg cr loop + + ." CLICK_CFG " h# 38 .reg + dup h# 80 and if ." rsvd " then + dup h# 40 and if ." rsvd " then + dup h# 20 and if ." ZD " then + dup h# 10 and if ." ZS " then + dup h# 08 and if ." YD " then + dup h# 04 and if ." YS " then + dup h# 02 and if ." XD " then + dup h# 01 and if ." XS " then + drop cr + + ." CLICK_SRC " h# 39 .reg + dup h# 80 and if ." rsvd " then + dup h# 40 and if ." IA " then + dup h# 20 and if ." DCLICK " then + dup h# 10 and if ." SCLICK " then + dup h# 08 and if ." Sign " then + dup h# 04 and if ." Z " then + dup h# 02 and if ." Y " then + dup h# 01 and if ." X " then + drop cr + + ." CLICK_THS " h# 3a .reg drop cr + ." TIME_LIMIT " h# 3b .reg drop cr + ." TIME_LATENCY " h# 3c .reg drop cr + ." TIME_WINDOW " h# 3d .reg drop cr + h# 3e .ureg cr + h# 3f .ureg cr + + \ register decode window is 00-7f, msb determines autoincrement +;
