Author: wmb Date: Thu Dec 2 03:09:15 2010 New Revision: 2059 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2059
Log: OLPC XO-1.5 - fixed a bug in the SPI "cloning" code that lets you use an XO-1.5 board as an SPI programmer. Also added high-level versions of a couple of code words just for good measure.
Modified: dev/via/spi/bbspi.fth
Modified: dev/via/spi/bbspi.fth ============================================================================== --- dev/via/spi/bbspi.fth Thu Dec 2 03:07:34 2010 (r2058) +++ dev/via/spi/bbspi.fth Thu Dec 2 03:09:15 2010 (r2059) @@ -22,6 +22,7 @@ : bb-spi-cs-on ( -- ) gpo-port dup pc@ 8 invert and swap pc! ; : bb-spi-cs-off ( -- ) gpo-port dup pc@ 8 or swap pc! ;
+[ifdef] 386-assembler code bb-spi-out ( b -- ) bx pop
@@ -39,6 +40,8 @@ ax dx out bl bl add \ Shift left loopa + clk-mask do-mask + invert # ax and \ Clk low + ax dx out c;
code bb-spi-in ( -- b ) @@ -66,9 +69,44 @@ bx inc then loopa + bp ax mov \ Base value + gpo-port # dx mov \ Out port + ax dx out \ CLK low bp pop bx push c; +[then] +[ifndef] bb-spi-in +: bb-spi-out ( b -- ) + gpo-port pl@ ( portval ) + clk-mask invert and ( portval' ) + do-mask invert and ( portval' ) + swap ( portval b ) + 8 0 do ( portval b ) + 2dup h# 80 and if ( portval b portval ) + do-mask or ( portval b portval' ) + then ( portval b portval ) + dup gpo-port pl! ( portval b portval ) \ CLK low with data + clk-mask or gpo-port pl! ( portval b ) \ CLK high with data + 2* ( portval b' ) + loop ( portval b ) + drop gpo-port pl! ( ) \ CLK low +; + +: bb-spi-in ( -- b ) + gpo-port pl@ ( portval ) + clk-mask invert and 0 ( portval b ) + 8 0 do ( portval b ) + over gpo-port pl! ( portval b ) \ CLK low + over clk-mask or gpo-port pl! ( portval b ) \ CLK high + 2* ( portval b' ) + gpi-port pl@ di-mask and if ( portval b ) + 1+ ( portval b' ) + then ( portval b ) + loop ( portval b ) + swap gpo-port pl! ( b ) \ CLK low +; +[then]
: bb-spi-start ( -- ) ['] bb-spi-in to spi-in @@ -80,7 +118,7 @@ \ use-spi-flash-read \ Readback with SPI commands, not memory ops use-hw-spi-flash-read
- gpo-port dup pc@ clk-mask invert and do-mask invert and cs-mask or swap pc! \ CLK, DO low, CS# high + gpo-port dup pl@ clk-mask invert and do-mask invert and cs-mask or swap pl! \ CLK, DO low, CS# high h# 88e4 config-b@ 2 or h# 88e4 config-b! ;
