Author: quozl Date: Wed Feb 27 05:25:20 2013 New Revision: 3575 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3575
Log: OLPC XO-1 - backport serial terminal, without logging, tested without r3569 (breaks build).
Modified: cpu/x86/pc/olpc/fw.bth cpu/x86/pc/olpc/terminal.fth
Modified: cpu/x86/pc/olpc/fw.bth ============================================================================== --- cpu/x86/pc/olpc/fw.bth Tue Feb 26 19:38:09 2013 (r3574) +++ cpu/x86/pc/olpc/fw.bth Wed Feb 27 05:25:20 2013 (r3575) @@ -657,6 +657,7 @@ : enable-serial ; fload ${BP}/cpu/x86/pc/olpc/charge.fth \ Fancy battery charge logger fload ${BP}/cpu/x86/pc/olpc/diskspeed.fth \ Mass storage speed test +fload ${BP}/cpu/x86/pc/olpc/terminal.fth \ Serial terminal emulator fload ${BP}/cpu/x86/pc/olpc/apt.fth \ Common developer utilities
tag-file @ fclose tag-file off
Modified: cpu/x86/pc/olpc/terminal.fth ============================================================================== --- cpu/x86/pc/olpc/terminal.fth Tue Feb 26 19:38:09 2013 (r3574) +++ cpu/x86/pc/olpc/terminal.fth Wed Feb 27 05:25:20 2013 (r3575) @@ -199,8 +199,12 @@ 0 value serial-ih
: usb-open ( -- ) - " /usb/serial" open-dev dup 0= abort" can't open USB serial adapter" - to serial-ih + " /usb/serial" open-dev ?dup if to serial-ih exit then +[ifdef] olpc-cl1 + " /usb@f,4/serial" open-dev ?dup if to serial-ih exit then + " /usb@f,5/serial" open-dev ?dup if to serial-ih exit then +[then] + true abort" can't open USB serial adapter" ;
: usb-close ( -- ) @@ -313,6 +317,7 @@
: serial serial{ {serial} }serial ;
+[ifdef] log-ih : serial-log ( "filename" -- ) serial{ safe-parse-word $create-file to log-ih @@ -322,6 +327,7 @@ log-ih close-dev }serial ; +[then]
: use-uart use-uart ; : use-usb use-usb ;
