Author: rsmith Date: Sat Oct 20 03:42:59 2012 New Revision: 3375 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3375
Log: OLPC ARM: convert s3-selftest to use sus power measurement
ec-sus-pwr reads a power measurement from the EC that only happens after the EC senses the SoC is in suspend. This reading gives much more consistent results as long as the SoC is suspended for long enough for the EC to update. (1s or more)
Modified: cpu/arm/mmp2/rtc.fth
Modified: cpu/arm/mmp2/rtc.fth ============================================================================== --- cpu/arm/mmp2/rtc.fth Sat Oct 20 02:20:13 2012 (r3374) +++ cpu/arm/mmp2/rtc.fth Sat Oct 20 03:42:59 2012 (r3375) @@ -67,7 +67,7 @@ \ on the operator. ." Testing suspend/resume" cr ." Sleeping for 3 seconds .. " d# 1000 ms - ec-rst-pwr ['] cancel-alarm 3 rtc-wake str ec-max-pwr ( power ) + ec-rst-pwr ['] cancel-alarm 3 rtc-wake str ec-sus-pwr ( power ) \ Negative power is consumed from battery, positive is supplied to battery dup suspend-power-limit < if ( power ) ." System used too much power during suspend - " negate .d ." mW" cr ( )
