Author: wmb Date: Tue Aug 14 22:42:28 2012 New Revision: 3171 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3171
Log: OLPC - Renamed gpio-prop to gpio-property and changed the argument order for conformance with Forth conventions.
Modified: cpu/arm/mmp2/gpio.fth cpu/arm/mmp2/twsi.fth
Modified: cpu/arm/mmp2/gpio.fth ============================================================================== --- cpu/arm/mmp2/gpio.fth Tue Aug 14 22:41:15 2012 (r3170) +++ cpu/arm/mmp2/gpio.fth Tue Aug 14 22:42:28 2012 (r3171) @@ -78,11 +78,10 @@ h# 108 make-gpio-mux-node end-package
-: gpio-prop ( $gpioname low? gpionum -- ) - " /gpio" encode-phandle ( $gpioname low? gpionum propval$ ) - rot encode-int encode+ ( $gpioname low? propval$' ) - rot encode-int encode+ ( $gpioname propval$' ) - 2swap property +: gpio-property ( gpionum low? gpioname$ -- ) + 2>r swap ( low? gpionum r: gpioname$ ) + " /gpio" encode-phandle ( low? gpionum propval$ r: gpioname$ ) + rot encode-int encode+ ( low? propval$' r: gpioname$ ) + rot encode-int encode+ ( propval$' r: gpioname$ ) + 2r> property ( ) ; - -
Modified: cpu/arm/mmp2/twsi.fth ============================================================================== --- cpu/arm/mmp2/twsi.fth Tue Aug 14 22:41:15 2012 (r3170) +++ cpu/arm/mmp2/twsi.fth Tue Aug 14 22:42:28 2012 (r3171) @@ -213,10 +213,10 @@ " touchscreen" name " zforce" +compatible my-address my-space 1 reg - " reset-gpio" 1 d# 98 gpio-prop - " test-gpio" 1 d# 139 gpio-prop - " hd-gpio" 1 d# 12 gpio-prop - " dr-gpio" 1 d# 99 gpio-prop + touch-rst-gpio# 1 " reset-gpio" gpio-property + touch-tck-gpio# 1 " test-gpio" gpio-property + touch-hd-gpio# 1 " hd-gpio" gpio-property + touch-int-gpio# 1 " dr-gpio" gpio-property end-package [then]
