Author: quozl Date: Mon Apr 18 07:04:30 2011 New Revision: 2189 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2189
Log: OLPC XO-1.5 - "help" output review; avoid mentioning q2c series, use .zd4 file in example, change USB key to USB drive, vertically align comments, drop "boot u:\boot\vmlinuz" as it is unlikely to be used, explain "printenv boot-device" as a new line, expand configuration variable meanings, change "initrd.imz" to "initrd.img", indent URL of OFW_FAQ.
Modified: cpu/x86/pc/olpc/via/help.fth
Modified: cpu/x86/pc/olpc/via/help.fth ============================================================================== --- cpu/x86/pc/olpc/via/help.fth Thu Apr 14 08:06:40 2011 (r2188) +++ cpu/x86/pc/olpc/via/help.fth Mon Apr 18 07:04:30 2011 (r2189) @@ -3,31 +3,31 @@ warning @ warning off : help ( -- ) blue-letters ." UPDATES:" black-letters mcr - ." flash u:\q2c18.rom Rewrite the firmware from USB key" mcr - ." flash ext:\q2c18.rom Rewrite the firmware from external SD file" mcr - ." fs-update u:\boot\os51.zd Rewrite the OS on internal SD from USB key" mcr + \ ================================================================================ + ." fs-update u:\os1.zd4 Rewrite the OS on internal SD from USB drive" mcr + ." flash u:\q3a64.rom Rewrite the firmware from USB drive" mcr + ." flash ext:\q3a64.rom Rewrite the firmware from external SD file" mcr blue-letters ." DIRECTORY LISTING:" black-letters mcr - ." dir u:\ List USB key root directory" mcr - ." dir u:\boot\ List USB key /boot directory" mcr - ." dir int:\boot*.zip List .zip files in internal SD /boot directory" mcr + ." dir u:\ List USB drive root directory" mcr + ." dir u:\boot\ List USB drive /boot directory" mcr + ." dir int:\boot*.zip List .zip files in internal SD /boot directory" mcr blue-letters ." BOOTING:" black-letters mcr - ." boot Load the OS from list of default locations" mcr - ." 'printenv boot-device' shows the list" mcr - ." boot <cmdline> Load the OS, passing <cmdline> to kernel" mcr - ." boot u:\boot\vmlinuz Load the OS from a specific location" mcr + ." boot Start the OS from list of default locations" mcr + ." printenv boot-device Show the list of default locations used by boot" mcr + ." boot u:\test.fth Start the OS from a specific location" mcr blue-letters ." CONFIGURATION VARIABLES FOR BOOTING:" black-letters mcr - ." boot-device Kernel or boot script path. Example: ext:\boot\olpc.fth" mcr - ." boot-file Default cmdline. Example: console=ttyS0,115200" mcr - ." ramdisk initrd pathname. Example: disk:\boot\initrd.imz" mcr + ." boot-device Kernel or boot script paths. Example: ext:\boot\olpc.fth" mcr + ." boot-file Default kernel command line. Example: console=ttyS0,115200" mcr + ." ramdisk Initial RAMDISK path. Example: int:\boot\initrd.img" mcr blue-letters ." MANAGING CONFIGURATION VARIABLES:" black-letters mcr - ." printenv [ <name> ] Show configuration variables" mcr - ." setenv <name> <value> Set configuration variable" mcr - ." editenv <name> Edit configuration variable" mcr + ." printenv [ <name> ] Show configuration variables" mcr + ." setenv <name> <value> Set configuration variable" mcr + ." editenv <name> Edit configuration variable" mcr blue-letters ." DIAGNOSTICS:" black-letters mcr - ." test <device-name> Test device. Example: test mouse" mcr - ." test-all Test all devices that have test routines" mcr - ." menu Graphical interface to selftests" mcr + ." test <device-name> Test device. Example: test mouse" mcr + ." test-all Test all devices that have test routines" mcr + ." menu Graphical interface to selftests" mcr blue-letters ." More information: " black-letters mcr - green-letters ." http://wiki.laptop.org/go/OFW_FAQ" black-letters cr + green-letters ." http://wiki.laptop.org/go/OFW_FAQ" black-letters cr ; warning !
