Author: wmb Date: 2009-01-13 21:16:46 +0100 (Tue, 13 Jan 2009) New Revision: 1071
Added: ofw/inet/iscsi/README Log: Added README file in iscsi directory
Added: ofw/inet/iscsi/README =================================================================== --- ofw/inet/iscsi/README (rev 0) +++ ofw/inet/iscsi/README 2009-01-13 20:16:46 UTC (rev 1071) @@ -0,0 +1,255 @@ += iSCSI for OFW = + +== Introduction == + +The purpose of this code is to allow a system to boot from +an iSCSI target device. It acts as an iSCSI initiator, performing +target discovery, normal login, and SCSI reads. + +This is a minimal implementation. Many features of the iSCSI protocol +are not supported, including multiple connections and failover, +encrypted connections, and header digests. + +== Usage == + +Normal boot syntax is + + boot iscsi:server//disk:,\filename + +e.g. + + boot iscsi:10.0.0.100//disk:,\system.img + +If the target requires CHAP authentcation, two environment variables +must be set: + + iscsi-user + iscsi-password + +e.g. + + setenv iscsi-user testy + setenv iscsi-password rudeword + +The usual OFW methods are supported, so it is possible to select +a dvice for reading and writing. For example, + + select iscsi:10.0.0.100//disk:0 + load-base 0 20 read-blocks . + + +== Limitations == + +Targets with multiple LUNs have not been tried, and may not work +correctly. + +Most negotiated parameters are ignored. + +Targets that require DataDigest or HeaderDigest set to CRC32 are +not supported. Support for digests would probably not be difficult +to add. + +SCSI writes are implemented, but have had minimal testing. + +The ISID is hard-coded to that of Sun Microsystems. It might be +better to set it dynamically somehow. + +== Parameter Negotiation == + +All negotiable parameters, or "keys", in RFC3270 are supported. +If a target sets an unknown key login will fail. +In most cases the values that have been negotiated are not used. + +This initiator specifies certain values during login, then accepts +whatever values the target requests. + +In particular, MaxRecvDataSegmentLength is set to the actual length +of the input buffer that has been allocated. The SCSI code limits +data sizes to max-transfer, which will be the smaller of the buffer +size and MaxRecvDataSegmentLength. + +SCSI writes should also be limited by FirstBurstLength if it happens +to be smaller. That has not been implemented as writes are not likely +to be used. + +== A walk through the code == + +The ofw iSCSI package is optionally included in cpu/x86/pc/biosload/fw.bth +as follows. + + support-package: iscsi + fload ${BP}/ofw/inet/loadiscsi.fth \ iSCSI client + end-support-package + +The file loadiscsi.fth declares a devalias, loads the rest of +the iscsi files, and creates a disk node in packages. + + devalias iscsi tcp//iscsi + +We make heavy use of the interposer mechanism. + + load iscsi:10.0.0.100//disk:,\README + +becomes + + load net//obp-tftp:last//tcp//iscsi:10.0.0.100//disk:,\README + +This allows iscsi access to tcp methods using $call-parent, +and allows the disk node access to iscsi using $call-parent. + +Two debug flags are defined. + +Set debug? true for general diganostic messages, including +a brief description of each iSCSI Protocol Data Unit (PDU) +that is sent or received. + +Set verbose? true to see a hex dump of each PDU, + + +=== Files in /iscsi/ === + +low.fth contains calls to the parent tcp node. They are used to +select a target server, connect to a remote port, disconnect, +and to read and write tcp packets. + + wait-read ( adr len -- actual ) + +uses tcp-read to get up to len bytes into the buffer at adr. +it returns the number actually read, or -1 if the connection +has been disconnected. wait-read will retry tcp-reads until +it times out, currently after 60 seconds. + +low.fth also contains some minor words used elsewhere. + +buffer.fth defines the data structure variations for the PDUs, +naming the fields that are used, and allocates input and output +buffers. It defines words to read and write various fields, and +words to send and receive PDUs. + +The output buffer is small, as any large writes will send the data +segment from whatever address it happens to occupy. + +The input buffer is large, as writes are first accepted into it +then moved to their destination. + +It is assumed the there are no Additional Header Segments. + +send-pdu and get-pdu are deferred to allow using the debug +versions of each. The default values are (send-pdu) and (get-pdu). + +There are actually two words for sending a PDU. +send-pdu sends everything from the output buffer. +send-pdu+data sends the header from the output buffer, and specified +data. In retrospect it might have been better to combine them into +a single routine. + +get-pdu first reads the header using read-all, determines the +length of the remaining data (if any) from the header, and +reads the rest with read-all. + + read-all ( adr total -- ) + +retries until it reads exactly total bytes into the buffer at adr. + + init-pdu + +initializes an outgoing PDU. + +During parameter negotiation, various strings are concatenated +onto the output buffer, each terminated with a null. +append, append0, and addnull are used in that process. + +debug.fth may be omitted out to save space. +(That has not been tested recently.) +It defines variants of the PDU send and receive words which +display the PDUs. + +keys.fth handles the details of parameter negotiation. +All known keys are defined in a set of vocabularies grouped +by behavior. + +bkeys has keys with boolean values (Yes or No). + +dkeys has keys with digest values (CRC32C ot None). + +nkeys has keys with numeric values. + +tkeys has keys with text values. + + get-key ( $key -- $value ) + +takes a key and returns a string with its value. + + set-key ( $value $key -- ) + +assigns a value to a key. + + set-iname ( -- ) + +sets InitiatorAlias to iqn.1986-03.com.sun:boot plus +the mac-address. + +get-hex is used to the CHAP challenge CHAP_C + +put-hex is used for the CHAP response CHAP_R + +append-key builds on the earlier append methods for parameter negotiation. + +parse-keys handles incoming parameters. during negotiation. + +inet/random.fth is included to set the low 15 bits of the isid +to a random value at the start of each session. This is done +to ensure uniqueness, as a target will reject duplicate session +ids. + +ppp/md5.fth is used for CHAP authentication. + +chap.fth contains the actual calculation of a CHA response. + +ipackets,fth handles incoming PDUs. +get-response is deffered to allow using the debug version. +(get-response) gets an incoming PDU and dispatches it to a handler +based on its opcode. + +nop-in must send a nop-out if the nop-in was unsolicited. + +Targets may choose to respond to a read request with a series +of scsi-data-in PDUs. +scsi-data-in moves incoming data to its destination, and +recursively calls get-response if the PDU was not final. + + +opackets.fth defines and handles outgoing PDUs. +send-cmd sends the PDU in the output buffer, and calls get-response. + +opackets.fth also defines execute-command, on which the SCSI depends. + +The bulk of opackets.fth is concerned with login. +login-discovery sets the keys to default values, then +sends a PDU to initiates a discovery login (with login-d). +If the target set AuthMethod to CHAP, auth-login performs +CHAP authentication using the environment variable iscsi-user +and iscsi-password. Otherwise it does login-none which ensure that +the target is past the authentication stage. + +login-discovery then uses login-dp to negotiate parameters, +and login-st to send a "SendTargets" request. The repsonse +should set TargetAddress, which is used during normal login. + +login-discovery then logs out (possibly not necessary) and +disconnects. + +login-normal goes through a similar process using login-n and login-np. + +methods.fth defines the usual OFW device words open-hardware and such. +The bulk of the work is in mount, which sets the target address, +connects to its ISCSI port, and does login-discovery and login-normal. + +scsi.fth defines stubs for some routines that the SCSI code wants, +though they are not useful here. +Note: that might change when support for targets with multiple LUNs +is added. + +scsi.fth also defines max-transfer which the SCSI code uses to limit +the size of data transfers. It is set to the minimum of our input +buffer size and MaxRecvDataSegmentLength.
