Author: lwalter Date: Tue Aug 9 20:23:31 2011 New Revision: 2439 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2439
Log: Add mfgtest support
Added: cpu/x86/pc/alex/disptest.fth
Added: cpu/x86/pc/alex/disptest.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/x86/pc/alex/disptest.fth Tue Aug 9 20:23:31 2011 (r2439) @@ -0,0 +1,236 @@ +purpose: Display test +\ See license at end of file + +\needs final-test? 0 value final-test? +\needs smt-test? 0 value smt-test? + +dev /display + +d# 100 constant bar-int +h# 7 constant test-colors16-mask +create test-colors16 +\ white magenta yellow red green blue cyan black + ffff w, f81f w, ffe0 w, f800 w, 07e0 w, 001f w, 07ff w, 0000 w, + +: fill-rect ( -- ) " fill-rectangle" $call-screen ; +: dimens ( -- w h ) " dimensions" $call-screen ; +: ht ( -- h ) " height" $call-screen ; +: wth ( -- w ) " width" $call-screen ; + +: whole-screen ( -- x y w h ) 0 0 dimens ; + +: black-screen ( -- ) 0 whole-screen fill-rect ; + +: test-color16 ( n -- color ) + test-colors16 swap bar-int / test-colors16-mask and wa+ w@ +; +: .horizontal-bars16 ( -- ) + dimens ( width height ) + 0 ?do ( width ) + i test-color16 0 i 3 pick bar-int fill-rect + bar-int +loop drop +; +: .vertical-bars16 ( -- ) + dimens ( width height ) + swap 0 ?do ( height ) + i test-color16 i 0 bar-int 4 pick fill-rect + bar-int +loop drop +; + +instance variable rn \ Random number +d# 5,000 constant burnin-time \ 5 seconds + +: random ( -- n ) + rn @ d# 1103515245 * d# 12345 + h# 7FFFFFFF and dup rn ! +; + +: randomize-color ( -- c ) + random h# 1f and d# 11 << + random h# 3f and d# 5 << or + random h# 1f and or +; +: randomize-xy ( -- x y ) + dimens ( width height ) + random 3ff and min swap ( y width ) + random 7ff and min swap ( x y ) +; +: randomize-wh ( x y -- w h ) + dimens ( x y width height ) + rot - -rot ( max-h x width ) + swap - swap ( max-w max-h ) + randomize-xy ( max-w max-h w h ) + rot min -rot min swap ( w' h' ) +; +: .random-rect ( -- ) + randomize-color ( c ) + randomize-xy ( c x y ) + 2dup randomize-wh ( c x y w h ) + " fill-rectangle" $call-screen ( ) +; + +: random-selftest ( -- ) + get-msecs rn ! + get-msecs burnin-time + ( limit ) + begin + get-msecs over u< ( limit reached? ) + while ( limit ) + .random-rect ( limit ) + key? if key 2drop exit then + repeat ( limit ) + drop +; + +0 value xbias +0 value ybias +0 value hstripe +0 value vstripe +: set-stripes ( -- ) + wth d# 256 / to hstripe + ht d# 256 / to vstripe + wth hstripe d# 256 * - to xbias + ht vstripe d# 256 * - to ybias +; +: half-bias ( -- ) xbias 2/ to xbias ybias 2/ to ybias ; +: gvsr ( -- ) + set-stripes half-bias black-screen ( ) + d# 256 0 do ( ) + d# 256 0 do ( ) + i j 0 rgb>565 ( color ) + hstripe i * xbias + ( color x ) + vstripe j * ybias + ( color x y ) + hstripe vstripe ( color x y w h ) + fill-rect + loop + loop +; +: gvsb ( -- ) + set-stripes half-bias black-screen ( ) + d# 256 0 do ( ) + d# 256 0 do ( ) + 0 j i rgb>565 ( color ) + hstripe i * xbias + ( color x ) + vstripe j * ybias + ( color x y ) + hstripe vstripe ( color x y ) + fill-rect + loop + loop +; +: hgradient ( -- ) + set-stripes black-screen ( ) + d# 256 0 do ( ) + i i i rgb>565 ( color ) + hstripe i * xbias + 0 ( color x y ) + hstripe ht ( color x y sw h ) + fill-rect ( ) + loop ( ) +; + +: vgradient ( -- ) + set-stripes black-screen ( ) + d# 256 0 do ( ) + i i i rgb>565 ( color ) + 0 vstripe i * ybias + ( color x y ) + wth vstripe ( color x y w sh ) + fill-rect ( ) + loop ( ) +; + + +h# ff h# ff h# ff rgb>565 constant white-color + +: hline ( y -- ) >r white-color 0 r> wth 1 fill-rect ; +: vline ( y -- ) >r white-color r> 0 1 ht fill-rect ; + +: crosshatch ( -- ) + black-screen + ht 0 do i hline d# 10 +loop + wth 0 do i vline d# 10 +loop +; +: short-wait ( -- ) smt-test? if d# 250 ms else d# 500 ms then ; +: brightness-ramp ( -- ) + 0 h# 0f do i bright! short-wait -1 +loop + backlight-off short-wait backlight-on + h# f bright! +; + +: red-screen ( -- ) + load-base whole-screen " read-rectangle" $call-screen + h# ff 00 00 rgb>565 whole-screen fill-rect + d# 1000 ms + load-base whole-screen fill-rect +; +: hold-time ( -- ) + smt-test? if + d# 500 ms + else + final-test? if d# 500 ms else d# 1000 ms then + then +; + +: hold-time2 ( -- ) + smt-test? if + d# 500 ms + else + final-test? if key drop then + d# 1000 ms + then +; +: wait ( -- ) + hold-time +\ 0 set-source \ Freeze image + hold-time +\ 1 set-source \ Unfreeze image + hold-time2 +; + +warning @ warning off +: selftest ( -- error? ) + depth d# 16 < if false exit then + smt-test? 0= if + .horizontal-bars16 wait + .vertical-bars16 wait + then + gvsr wait + gvsb wait + hgradient wait + vgradient wait + crosshatch wait + brightness-ramp + + smt-test? 0= if + burnin-time d# 5000 > if + ." Press a key to stop early." cr + d# 1000 ms + then + random-selftest + then + + confirm-selftest? +; +warning ! + +device-end + +\ LICENSE_BEGIN +\ Copyright (c) 2007 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
