Author: wmb Date: Mon Aug 29 03:35:47 2011 New Revision: 2484 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2484
Log: OLPC XO-1 touchpad driver - made it use stream mode instead of remote mode, thus hopefully removing the last vestige of remote mode usage.
Modified: dev/olpc/touchpad/touchpad.fth
Modified: dev/olpc/touchpad/touchpad.fth ============================================================================== --- dev/olpc/touchpad/touchpad.fth Mon Aug 29 03:31:47 2011 (r2483) +++ dev/olpc/touchpad/touchpad.fth Mon Aug 29 03:35:47 2011 (r2484) @@ -292,20 +292,26 @@ : clipx ( delta -- x ) mouse-x @ + 0 max screen-w 1- min dup mouse-x ! ; : clipy ( delta -- y ) mouse-y @ + 0 max screen-h 1- min dup mouse-y ! ;
+: rel>abs ( dy dy buttons -- x y buttons ) + >r ( dx dy ) + swap clipx swap negate clipy ( x y ) + r> ( buttons ) +; + \ Try to receive a GS-format packet. If one arrives within \ 20 milliseconds, return true and the decoded information. \ Otherwise return false. : pad? ( -- false | x y z tap? true ) mode @ 3 = if - poll-event if ( dx dy buttons ) - >r ( dx dy ) - swap clipx swap negate clipy 0 ( x y z ) - 0 r@ 1 and or ( x y z tap ) - r> 4 and 0<> 2 and or ( x y z tap' ) - 8 or ( x y z tap' ) - true - else - false + stream-poll? if ( dx dy buttons ) + rel>abs ( x y buttons ) + >r 0 ( x y z r: buttons ) + 0 r@ 1 and or ( x y z tap r: buttons ) + r> 4 and 0<> 2 and or ( x y z tap' ) + 8 or ( x y z tap' ) + true ( x y z tap true ) + else ( ) + false ( false ) then exit then
