Author: wmb Date: 2009-08-09 06:00:58 +0200 (Sun, 09 Aug 2009) New Revision: 1290
Modified: dev/hdaudio/conexant.fth dev/hdaudio/core.fth Log: HD Audio selftest improvements from Luke Gorrie.
Modified: dev/hdaudio/conexant.fth =================================================================== --- dev/hdaudio/conexant.fth 2009-08-09 03:38:09 UTC (rev 1289) +++ dev/hdaudio/conexant.fth 2009-08-09 04:00:58 UTC (rev 1290) @@ -27,6 +27,7 @@ : pin-sense? ( -- ? ) h# f0900 cmd? h# 8000.0000 and 0<> ; : set-connection ( n -- ) h# 70100 or cmd ; : enable-hp-input ( -- ) h# 70721 cmd ; +: disable-hp-input ( -- ) h# 70700 cmd ;
: cx2058x-enable-recording ( -- ) mic-in to node pin-sense? if @@ -36,7 +37,10 @@ then ;
-: cx2058x-disable-recording ( -- ) ; +: cx2058x-disable-recording ( -- ) + mic-in to node disable-hp-input + mic to node disable-hp-input +;
: cx2058x-enable-playback ( -- ) h# 10 to node h# 70640 cmd h# 20000 stream-format or cmd
Modified: dev/hdaudio/core.fth =================================================================== --- dev/hdaudio/core.fth 2009-08-09 03:38:09 UTC (rev 1289) +++ dev/hdaudio/core.fth 2009-08-09 04:00:58 UTC (rev 1290) @@ -262,8 +262,7 @@
0 value open-count : open ( -- flag ) - open-count 0= if init-controller then - init-codec + open-count 0= if init-controller init-codec then open-count 1+ to open-count true ; @@ -429,7 +428,7 @@
: open-out ( -- ) 4 to sd# - 48kHz + d# 48.000 set-sample-rate ;
: audio-out ( adr len -- actual ) @@ -456,7 +455,7 @@ ;
: write ( adr len -- actual ) - open-out audio-out install-playback-alarm + 4 to sd# audio-out install-playback-alarm ;
\ Alarm handle to stop the stream when the content has been played. @@ -479,7 +478,7 @@ 0 value recbuf-phys d# 65535 value /recbuf
-: open-in ( -- ) 48kHz ; +: open-in ( -- ) d# 48.000 set-sample-rate ;
: record-stream ( -- ) 0 to sd#
