Author: quozl Date: Fri Aug 24 11:01:01 2012 New Revision: 3224 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3224
Log: OLPC XO-4 - configure and read thermal sensor
Added: cpu/arm/mmp3/thermal.fth Modified: cpu/arm/olpc/build-fw.fth
Added: cpu/arm/mmp3/thermal.fth ============================================================================== --- /dev/null 00:00:00 1970 (empty, because file is newly added) +++ cpu/arm/mmp3/thermal.fth Fri Aug 24 11:01:01 2012 (r3224) @@ -0,0 +1,192 @@ +\ See license at end of file +purpose: Driver for the MMP3 thermal sensor + +\ FIXME: characterise the observations using an IR thermometer, +\ because the datasheet and the registers manual disagree on +\ interpretation of these gray code values. + +create gc0 \ high range +d# 780 w, \ 0000 +d# 830 w, \ 0001 +d# 855 w, \ 0010 +d# 805 w, \ 0011 +d# 955 w, \ 0100 +d# 930 w, \ 0101 +d# 880 w, \ 0110 +d# 905 w, \ 0111 +d# 0 w, \ 1000 +d# 1130 w, \ 1001 +d# 1080 w, \ 1010 +d# 1105 w, \ 1011 +d# 980 w, \ 1100 +d# 1005 w, \ 1101 +d# 1055 w, \ 1110 +d# 1030 w, \ 1111 + +create gc1 \ low range +d# 260 w, \ 0000 +d# 285 w, \ 0001 +d# 335 w, \ 0010 +d# 310 w, \ 0011 +d# 435 w, \ 0100 +d# 410 w, \ 0101 +d# 360 w, \ 0110 +d# 385 w, \ 0111 +d# 0 w, \ 1000 +d# 610 w, \ 1001 +d# 560 w, \ 1010 +d# 585 w, \ 1011 +d# 460 w, \ 1100 +d# 485 w, \ 1101 +d# 535 w, \ 1110 +d# 510 w, \ 1111 + +: gc>c ( gray-code -- tenths-of-celcius ) + dup h# 0800.0000 and ( gray-code low-range? ) + if gc1 else gc0 then ( gray-code table ) + swap h# f and wa+ w@ +; + +h# 03.b000 value tsense + +: +ts ( offset -- io-offset ) tsense swap la+ ; +: ts@ ( offset -- l ) +ts io@ ; +: ts! ( l offset -- ) +ts io! ; + +: ts-clock ( offset -- ) + 7 over apbc! 3 swap apbc! ( n ) +; + +: ts-clocks + h# 90 ts-clock + h# 98 ts-clock + h# 9c ts-clock + h# a0 ts-clock +; + +: ts-start ( n -- ) + dup ts@ h# 4000.0000 or swap ts! +; + +: ts-wait ( n -- ) + d# 10 get-msecs + ( n limit ) + begin + over ts@ h# 2000.0000 and ( n limit ready? ) + if 2drop exit then + dup get-msecs - 0< ( n limit timeout? ) + until ( n limit ) + 2drop ( ) +; + +: ts-read ( n -- gc ) + dup ts-wait ( n ) + dup ts@ ( n gc ) + swap ts-start ( gc ) +; + +: ts-range-low ( n -- ) + dup ts@ h# 0800.0000 or swap ts! +; + +: ts-range-high ( n -- ) + dup ts@ h# 0800.0000 invert and swap ts! +; + +: init-thermal-sensor ( -- ) + ts-clocks + 3 0 do i ts-range-low i ts-start loop +; + +\ switch the sensors out of low range - does not work +[ifdef] notyet +: hot + ts-clocks + 3 0 do i ts-range-high i ts-start loop +; +[then] + +\ read and average the three sensors +: cpu-temperature ( -- celcius ) + 0 ts-read gc>c + 1 ts-read gc>c + 2 ts-read gc>c + + + d# 30 / +; + +: ?thermal ( -- ) + cpu-temperature d# 70 > abort " CPU too hot" + \ FIXME: choose an appropriate limit, because + \ - the sample unit easily reaches 61C, + \ - using the low range we can't see greater than 61C, and + \ - the high range doesn't actually work. +; + +: .c.c ( n -- ) 0 <# # [char] . hold #s #> type ." C " ; + +: .c ( n -- ) (.) type ." C " ; + +: .thermal + push-decimal + time&date >unix-seconds . + ." sensors: " + 0 ts@ gc>c .c.c \ innermost? + 1 ts@ gc>c .c.c + 2 ts@ gc>c .c.c \ outermost? + ." cpu: " cpu-temperature .c + ." battery: " bat-temp .c + pop-base +; + +: watch-thermal + begin + .thermal cr d# 1000 ms key? + until key drop cr +; + +[ifdef] notyet \ FIXME +: test-thermal + .thermal cr + + \ save the threshold set by cforth + thermal-base 4 + io@ >r + + \ temporarily set the threshold close to current value + thermal-base io@ h# 3ff and 8 + wd-thresh! + + begin + (cr .thermal kill-line d# 500 ms key? + until key drop cr + + \ restore the threshold + r> wd-thresh! + .thermal cr +; +[then] + +stand-init: Thermal sensor + init-thermal-sensor +; + +\ LICENSE_BEGIN +\ Copyright (c) 2012 FirmWorks +\ +\ Permission is hereby granted, free of charge, to any person obtaining +\ a copy of this software and associated documentation files (the +\ "Software"), to deal in the Software without restriction, including +\ without limitation the rights to use, copy, modify, merge, publish, +\ distribute, sublicense, and/or sell copies of the Software, and to +\ permit persons to whom the Software is furnished to do so, subject to +\ the following conditions: +\ +\ The above copyright notice and this permission notice shall be +\ included in all copies or substantial portions of the Software. +\ +\ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, +\ EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF +\ MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND +\ NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE +\ LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION +\ OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION +\ WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE. +\ +\ LICENSE_END
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Fri Aug 24 05:22:48 2012 (r3223) +++ cpu/arm/olpc/build-fw.fth Fri Aug 24 11:01:01 2012 (r3224) @@ -354,7 +354,11 @@ extra-mem-va /extra-mem add-memory ;
+[ifdef] mmp3 +fload ${BP}/cpu/arm/mmp3/thermal.fth +[else] fload ${BP}/cpu/arm/mmp2/thermal.fth +[then] fload ${BP}/cpu/arm/mmp2/fuse.fth [ifdef] bsl-uart-base fload ${BP}/cpu/arm/olpc/bsl.fth
