Author: rsmith Date: 2010-01-28 14:59:56 +0100 (Thu, 28 Jan 2010) New Revision: 1716
Added: cpu/x86/pc/olpc/via/final.fth Removed: cpu/x86/pc/olpc/via/runin.fth Log: Rename runin.fth to final.fth
Copied: cpu/x86/pc/olpc/via/final.fth (from rev 1714, cpu/x86/pc/olpc/via/runin.fth) =================================================================== --- cpu/x86/pc/olpc/via/final.fth (rev 0) +++ cpu/x86/pc/olpc/via/final.fth 2010-01-28 13:59:56 UTC (rev 1716) @@ -0,0 +1,465 @@ +\ Post-runin boot script $Revision$ + +visible + +\ Location of the files containing KA tag data +: ka-dir$ ( -- adr len ) " http:\10.1.0.1\ka" ; + +: mfg-ntp-server ( -- name$ ) + " NT" find-tag if ?-null else " 10.1.0.1" then +; +' mfg-ntp-server to ntp-servers + +\ The Linux-based runin selftests put this file at int:\runin\olpc.fth +\ after they have finished. On the next reboot, OFW thus boots this +\ script instead of int:\boot\olpc.fth . This script either displays +\ the failure log (if int:\runin\fail.log is present) or modifies the +\ manufacturing data tags to cause the next boot to enter final test. + +d# 128 buffer: mb-buf : mb$ mb-buf count ; + +: get-mb-tags ( -- ) + " B#" find-tag if + ?-null + then + mb-buf place +; + +: set-tag-assy ( -- ) + get-mb-tags + + clear-mfg-buf + + " " " ww" put-ascii-tag + + " "(D3)" " SG" ($add-tag) + mb$ " B#" put-ascii-tag + " EN" " SS" put-ascii-tag + + " ASSY" " TS" put-ascii-tag + " cifs:\Administrator:qmsswdl@10.0.0.2\OLPC_TM" " MS" put-ascii-tag + " u:\boot\olpc.fth net" " BD" put-ascii-tag + + flash-write-enable + (put-mfg-data) + no-kbc-reboot + kbc-on +; + +d# 20 buffer: sn-buf +: sn$ ( -- adr len ) sn-buf count ; + +: try-scan-sn ( -- gotit? ) + sn-buf 1+ d# 20 accept ( n ) + d# 12 <> if + " Wrong length, try again" .problem + false exit + then + sn-buf 1+ " TSHC" comp if + " Must begin with TSHC, try again" .problem + false exit + then + sn-buf 2+ sn-buf 1+ d# 11 move \ Elide the T + d# 11 sn-buf c! + true +; + +: scan-sn ( -- ) + ." *****" + + begin + " Please Input Serial Number ......" .instructions + try-scan-sn + until +; + +: board#$ ( -- adr len ) + " B#" find-tag 0= abort" Missing B# tag !!!" + -null +; + +: get-sn-value ( --) + " SN" find-tag if + ?-null + else + abort" Missing SN tag !!!" + then + sn-buf place +; + +0 0 2value response$ + +: final-filename$ ( -- adr len ) sn$ " %s.txt" sprintf ; + +: check-err-msg ( adr len -- ) + begin dup while ( adr len ) + linefeed left-parse-string ( rem$ line$ ) + ?remove-cr ( rem$ line$ ) + [char] : left-parse-string ( rem$ value$ key$ ) + " ERR_MSG" $= if ( rem$ value$ ) + page show-fail + type ( rem$ ) + cr cr + ." Perss any key to power off!" + key drop cr cr + power-off + then ( rem$ value$ ) + 2drop ( rem$ ) + repeat ( rem$ ) + 2drop ( ) +; + +\ Send the board number as the request and return the response data +: final-tag-exchange ( -- ) + final-filename$ open-temp-file + sn$ " SN:" put-key+value + " Request" submit-file + " Response" get-response to response$ + response$ check-err-msg +; + +: show-result-screen ( -- ) + pass? if + clear-screen + ." PASS" cr cr + green-screen + else + ." FAIL" cr cr + set-tag-assy + red-screen + then +; + +: put-ka-tag ( value$ key$ -- ) + 2over 8 min ka-dir$ " %s%s" sprintf ( value$ key$ filename$ ) + $read-file if ( value$ key$ ) + ." ERROR: No KA tag file for " 2swap type cr ( key$ ) + true abort" KA file not found" ( key$ ) + 2drop ( ) + else ( value$ key$ file-data$ ) + 2swap ($add-tag) ( value$ ) + 2drop ( ) + then +; + +false value write-protect? + +: special-tag? ( value$ key$ -- true | value$ key$ false ) + 2dup " KA" $= if ( value$ key$ ) + put-ka-tag ( ) + true exit ( -- true ) + then ( value$ key$ ) + 2dup " WP" nocase-$= if ( value$ key$ ) + 2drop " 0" $= 0= to write-protect? ( ) + true exit ( -- true ) + then ( value$ key$ ) + 2dup " ak" nocase-$= if ( value$ key$ ) + 2drop " 0" $= 0= if ( ) + " " " ak" ($add-tag) ( ) + then ( ) + true exit ( -- true ) + then ( value$ key$ ) + false ( value$ key$ false ) +; +: put-tag ( value$ key$ -- ) + special-tag? if exit then + put-ascii-tag +; +: show-tag ( value$ -- ) + 2dup $tag-printable? if ?-null type else wrapped-cdump then +; +: do-tag-error ( -- ) + ." Problem with tag processing. Halting." cr + begin halt again +; +: handle-tag ( value$ key$ -- ) + 2dup ram-find-tag if ( value$ key$ old-value$ ) \ Tag already exists, check it + 2over " KA" $= 0= if ?-null then ( value$ key$ old-value$' ) + 2>r 2over 2r@ $= if ( value$ key$ r: old-value$' ) + 2drop 2drop 2r> 2drop ( ) + else ( value$ key$ r: old-value$' ) + type ." tag changed!" cr ( value$ r: old-value$' ) + ." Old: " 2r> show-tag cr ( value$ ) + ." New: " show-tag cr ( ) + do-tag-error + then + else ( value$ key$ ) \ New tag, add it + put-tag + then +; + +: replace-ka-value ( rem$ value$ key$ -- rem$ file-data$ key$ ) + 2swap 2dup 8 min ka-dir$ " %s%s" sprintf ( rem$ key$ value$ filename$ ) + $read-file if ( rem$ key$ value$ ) + ." ERROR: No KA tag file for " type cr ( rem$ key$ ) + true abort" KA file not found" ( rem$ key$ ) + 2drop ( rem$ ) + else ( rem$ key$ value$ file-data$ ) + 2swap 2drop ( rem$ key$ file-data$ ) + 2swap ( rem$ file-data$ key$ ) + then +; + +: parse-tags ( adr len -- ) + begin dup while ( adr len ) + linefeed left-parse-string ( rem$ line$ ) + ?remove-cr ( rem$ line$ ) + [char] : left-parse-string ( rem$ value$ key$ ) + dup 2 = if ( rem$ value$ key$ ) + \ catch value from http, if KA tag + 2dup " KA" $= if ( rem$ value$ key$ ) + replace-ka-value ( rem$ value$' key$ ) + then + handle-tag ( rem$ ) + else ( rem$ value$ key$ ) + 4drop ( rem$ ) + then ( rem$ ) + repeat ( adr len ) + 2drop ( ) +; + +: format-date ( s m h d m y -- adr len ) + push-decimal + >r >r >r >r >r >r + <# + [char] Z hold + r> u# u# drop + r> u# u# drop + r> u# u# drop + [char] T hold + r> u# u# drop + r> u# u# drop + r> u# u# u# u# + u#> + pop-base +; +: make-md-tag ( -- ) + time&date ( s m h d m y ) format-date " md" put-ascii-tag +; +: inject-tags ( -- ) + get-mfg-data + + " TS" ($delete-tag) + " MS" ($delete-tag) + " BD" ($delete-tag) + " NT" ($delete-tag) + " MD" ($delete-tag) + " Pr" ($delete-tag) + make-md-tag + + response$ parse-tags + + " TS" ($delete-tag) + " SHIP" " TS" put-ascii-tag + + flash-write-enable + (put-mfg-data) + \ Change "ww" to "wp" if we want security to be enabled + write-protect? if " wp" h# efffe write-spi-flash then + no-kbc-reboot + kbc-on +; + +d# 180 constant rtc-threshold \ yes, really. 3 minutes +0 value ntp-seconds +0 value rtc-seconds +: .clocks ( -- ) + ." RTC: " rtc-seconds unix-seconds> .date space .time ." UTC" cr + ." NTP: " ntp-seconds unix-seconds> .date space .time ." UTC" cr +; +: verify-rtc-date ( -- ) +\ XXX check RTC power lost bit + ." Getting time from NTP server .. " + begin ntp-timestamp while ." Retry " repeat ( d.timestamp ) + + ntp>time&date >unix-seconds to ntp-seconds + time&date >unix-seconds to rtc-seconds + ntp-seconds rtc-seconds - ( lost-seconds ) + dup rtc-threshold > if ( lost-seconds ) + page show-fail ( lost-seconds ) + ." Clock lost " .d ." seconds since SMT" cr ( ) + .clocks + stall + then ( lost-seconds ) + + abs dup rtc-threshold > if ( gained-seconds ) + page show-fail ( gained-seconds ) + ." Clock gained " .d ." seconds since SMT" cr ( ) + .clocks + stall + then + ." NTP and RTC clocks agree." cr +; + +: put-key:value ( value$ key$ -- ) " %s:%s" sprintf put-key-line ; + +: upload-tag ( data$ tag$ -- ) + 2dup " wp" $= if ( data$ tag$ ) + 4drop " 1" " WP" put-key:value ( ) + exit + then + 2dup " ww" $= if ( data$ tag$ ) + 4drop " 0" " WP" put-key:value ( ) + exit + then + 2dup " ak" $= if ( data$ tag$ ) + 4drop " 1" " ak" put-key:value ( ) + exit + then + 2dup " KA" $= if ( data$ tag$ ) + 4drop ( ) + exit + then + 2dup " SG" $= if ( data$ tag$ ) + 4drop ( ) + exit + then ( data$ tag$ ) + + 2swap ?-null 2swap ( data$' tag$ ) + put-key:value ( ) +; + +: upload-tags ( -- ) + mfg-data-top ( adr ) + begin another-tag? while ( adr' data$ tname-adr ) + 2 upload-tag ( adr ) + repeat ( adr ) + drop +; + +\ Upload the result data +: final-result ( -- ) + final-filename$ open-temp-file + upload-tags + pass? if " PASS" else " FAIL" then " RESULT=" put-key+value + " Handshake" submit-file +; + +: wait-connections ( -- ) + silent-probe-usb + wait-lan +; + +: my-cifs-connect ( adr -- ) + open-dev to cifs-ih + cifs-ih 0= abort" Cannot open SMB share" +; + +\ $rename gives "Unimplemented package interface procedure" on ext2 +: do-rename + 2>r 2dup 2r> $copy $delete +; + +: $safe-delete ( $name -- ) + 2dup $file-exists? if + 2dup $delete + then + 2drop +; + +: $copy! ( $src $dst -- ) + 2dup $file-exists? if + 2dup $delete + then + $copy1 +; + + +: finish-final-test ( -- ) + + " int:\runin\final.fth" $safe-delete + " int:\runin\repass.fth" 2dup $file-exists? if + " int:\runin\final.fth" $copy + else + 2drop + then + + wait-connections + + get-sn-value + + verify-rtc-date + + ." Getting final tags .. " + cifs-connect final-tag-exchange \ Note: no disconnect... + ." Done" cr + + inject-tags + + ." Submitting results .. " + final-result cifs-disconnect + ." Done" cr + + " int:\runin\repass.fth" $safe-delete + + \ need to delete target, due to #9957 + " int:\runin\final.fth.sav" $safe-delete + + " int:\runin\final.fth" " int:\runin\final.fth.sav" $rename +; + +\ Make the "wait for SD insertion" step highly visible +dev ext +warning @ warning off +: wait&clear ( -- error? ) wait-card? page ; +patch wait&clear wait-card? selftest +: selftest ( -- ) page show-pass selftest ; +warning ! +dend + +: fail-backup-file$ ( -- name$ ) + time&date format-date " int:\runin\fail-%s.log" sprintf +; +: fail-log-file$ ( -- name$ ) " int:\runin\fail.log" ; + +\ The operator can type this to reset the state to run +\ the Linux-based runin tests again. +: rerunin ( -- ) + " int:\runin\final.fth" $safe-delete + fail-log-file$ fail-backup-file$ do-rename +; + +: after-runin ( -- ) + fail-log-file$ $read-file 0= if ( adr len ) + page + show-fail + ." Type a key to see the failure log" + key drop cr cr + list + ." Type R to restart runin, any other key to power off " + key dup emit cr upc [char] R = if + ." Resetting state to restart runin." cr + ." The old failure log is in " fail-backup-file$ type cr + rerunin + else + power-off + then + else + autorun-mfg-tests + pass? if finish-final-test then + show-result-screen + then + + ." Type a key to power off" + key cr + power-off +; + +\ Override the display self test +dev /display + +warning @ warning off +: selftest ( -- error? ) + depth d# 16 < if false exit then + + .vertical-bars16 wait + hgradient + + confirm-selftest? +; +warning ! + +device-end + +." Starting final phase" cr +after-runin
Deleted: cpu/x86/pc/olpc/via/runin.fth =================================================================== --- cpu/x86/pc/olpc/via/runin.fth 2010-01-28 02:44:36 UTC (rev 1715) +++ cpu/x86/pc/olpc/via/runin.fth 2010-01-28 13:59:56 UTC (rev 1716) @@ -1,465 +0,0 @@ -\ Post-runin boot script $Revision$ - -visible - -\ Location of the files containing KA tag data -: ka-dir$ ( -- adr len ) " http:\10.1.0.1\ka" ; - -: mfg-ntp-server ( -- name$ ) - " NT" find-tag if ?-null else " 10.1.0.1" then -; -' mfg-ntp-server to ntp-servers - -\ The Linux-based runin selftests put this file at int:\runin\olpc.fth -\ after they have finished. On the next reboot, OFW thus boots this -\ script instead of int:\boot\olpc.fth . This script either displays -\ the failure log (if int:\runin\fail.log is present) or modifies the -\ manufacturing data tags to cause the next boot to enter final test. - -d# 128 buffer: mb-buf : mb$ mb-buf count ; - -: get-mb-tags ( -- ) - " B#" find-tag if - ?-null - then - mb-buf place -; - -: set-tag-assy ( -- ) - get-mb-tags - - clear-mfg-buf - - " " " ww" put-ascii-tag - - " "(D3)" " SG" ($add-tag) - mb$ " B#" put-ascii-tag - " EN" " SS" put-ascii-tag - - " ASSY" " TS" put-ascii-tag - " cifs:\Administrator:qmsswdl@10.0.0.2\OLPC_TM" " MS" put-ascii-tag - " u:\boot\olpc.fth net" " BD" put-ascii-tag - - flash-write-enable - (put-mfg-data) - no-kbc-reboot - kbc-on -; - -d# 20 buffer: sn-buf -: sn$ ( -- adr len ) sn-buf count ; - -: try-scan-sn ( -- gotit? ) - sn-buf 1+ d# 20 accept ( n ) - d# 12 <> if - " Wrong length, try again" .problem - false exit - then - sn-buf 1+ " TSHC" comp if - " Must begin with TSHC, try again" .problem - false exit - then - sn-buf 2+ sn-buf 1+ d# 11 move \ Elide the T - d# 11 sn-buf c! - true -; - -: scan-sn ( -- ) - ." *****" - - begin - " Please Input Serial Number ......" .instructions - try-scan-sn - until -; - -: board#$ ( -- adr len ) - " B#" find-tag 0= abort" Missing B# tag !!!" - -null -; - -: get-sn-value ( --) - " SN" find-tag if - ?-null - else - abort" Missing SN tag !!!" - then - sn-buf place -; - -0 0 2value response$ - -: final-filename$ ( -- adr len ) sn$ " %s.txt" sprintf ; - -: check-err-msg ( adr len -- ) - begin dup while ( adr len ) - linefeed left-parse-string ( rem$ line$ ) - ?remove-cr ( rem$ line$ ) - [char] : left-parse-string ( rem$ value$ key$ ) - " ERR_MSG" $= if ( rem$ value$ ) - page show-fail - type ( rem$ ) - cr cr - ." Perss any key to power off!" - key drop cr cr - power-off - then ( rem$ value$ ) - 2drop ( rem$ ) - repeat ( rem$ ) - 2drop ( ) -; - -\ Send the board number as the request and return the response data -: final-tag-exchange ( -- ) - final-filename$ open-temp-file - sn$ " SN:" put-key+value - " Request" submit-file - " Response" get-response to response$ - response$ check-err-msg -; - -: show-result-screen ( -- ) - pass? if - clear-screen - ." PASS" cr cr - green-screen - else - ." FAIL" cr cr - set-tag-assy - red-screen - then -; - -: put-ka-tag ( value$ key$ -- ) - 2over 8 min ka-dir$ " %s%s" sprintf ( value$ key$ filename$ ) - $read-file if ( value$ key$ ) - ." ERROR: No KA tag file for " 2swap type cr ( key$ ) - true abort" KA file not found" ( key$ ) - 2drop ( ) - else ( value$ key$ file-data$ ) - 2swap ($add-tag) ( value$ ) - 2drop ( ) - then -; - -false value write-protect? - -: special-tag? ( value$ key$ -- true | value$ key$ false ) - 2dup " KA" $= if ( value$ key$ ) - put-ka-tag ( ) - true exit ( -- true ) - then ( value$ key$ ) - 2dup " WP" nocase-$= if ( value$ key$ ) - 2drop " 0" $= 0= to write-protect? ( ) - true exit ( -- true ) - then ( value$ key$ ) - 2dup " ak" nocase-$= if ( value$ key$ ) - 2drop " 0" $= 0= if ( ) - " " " ak" ($add-tag) ( ) - then ( ) - true exit ( -- true ) - then ( value$ key$ ) - false ( value$ key$ false ) -; -: put-tag ( value$ key$ -- ) - special-tag? if exit then - put-ascii-tag -; -: show-tag ( value$ -- ) - 2dup $tag-printable? if ?-null type else wrapped-cdump then -; -: do-tag-error ( -- ) - ." Problem with tag processing. Halting." cr - begin halt again -; -: handle-tag ( value$ key$ -- ) - 2dup ram-find-tag if ( value$ key$ old-value$ ) \ Tag already exists, check it - 2over " KA" $= 0= if ?-null then ( value$ key$ old-value$' ) - 2>r 2over 2r@ $= if ( value$ key$ r: old-value$' ) - 2drop 2drop 2r> 2drop ( ) - else ( value$ key$ r: old-value$' ) - type ." tag changed!" cr ( value$ r: old-value$' ) - ." Old: " 2r> show-tag cr ( value$ ) - ." New: " show-tag cr ( ) - do-tag-error - then - else ( value$ key$ ) \ New tag, add it - put-tag - then -; - -: replace-ka-value ( rem$ value$ key$ -- rem$ file-data$ key$ ) - 2swap 2dup 8 min ka-dir$ " %s%s" sprintf ( rem$ key$ value$ filename$ ) - $read-file if ( rem$ key$ value$ ) - ." ERROR: No KA tag file for " type cr ( rem$ key$ ) - true abort" KA file not found" ( rem$ key$ ) - 2drop ( rem$ ) - else ( rem$ key$ value$ file-data$ ) - 2swap 2drop ( rem$ key$ file-data$ ) - 2swap ( rem$ file-data$ key$ ) - then -; - -: parse-tags ( adr len -- ) - begin dup while ( adr len ) - linefeed left-parse-string ( rem$ line$ ) - ?remove-cr ( rem$ line$ ) - [char] : left-parse-string ( rem$ value$ key$ ) - dup 2 = if ( rem$ value$ key$ ) - \ catch value from http, if KA tag - 2dup " KA" $= if ( rem$ value$ key$ ) - replace-ka-value ( rem$ value$' key$ ) - then - handle-tag ( rem$ ) - else ( rem$ value$ key$ ) - 4drop ( rem$ ) - then ( rem$ ) - repeat ( adr len ) - 2drop ( ) -; - -: format-date ( s m h d m y -- adr len ) - push-decimal - >r >r >r >r >r >r - <# - [char] Z hold - r> u# u# drop - r> u# u# drop - r> u# u# drop - [char] T hold - r> u# u# drop - r> u# u# drop - r> u# u# u# u# - u#> - pop-base -; -: make-md-tag ( -- ) - time&date ( s m h d m y ) format-date " md" put-ascii-tag -; -: inject-tags ( -- ) - get-mfg-data - - " TS" ($delete-tag) - " MS" ($delete-tag) - " BD" ($delete-tag) - " NT" ($delete-tag) - " MD" ($delete-tag) - " Pr" ($delete-tag) - make-md-tag - - response$ parse-tags - - " TS" ($delete-tag) - " SHIP" " TS" put-ascii-tag - - flash-write-enable - (put-mfg-data) - \ Change "ww" to "wp" if we want security to be enabled - write-protect? if " wp" h# efffe write-spi-flash then - no-kbc-reboot - kbc-on -; - -d# 180 constant rtc-threshold \ yes, really. 3 minutes -0 value ntp-seconds -0 value rtc-seconds -: .clocks ( -- ) - ." RTC: " rtc-seconds unix-seconds> .date space .time ." UTC" cr - ." NTP: " ntp-seconds unix-seconds> .date space .time ." UTC" cr -; -: verify-rtc-date ( -- ) -\ XXX check RTC power lost bit - ." Getting time from NTP server .. " - begin ntp-timestamp while ." Retry " repeat ( d.timestamp ) - - ntp>time&date >unix-seconds to ntp-seconds - time&date >unix-seconds to rtc-seconds - ntp-seconds rtc-seconds - ( lost-seconds ) - dup rtc-threshold > if ( lost-seconds ) - page show-fail ( lost-seconds ) - ." Clock lost " .d ." seconds since SMT" cr ( ) - .clocks - stall - then ( lost-seconds ) - - abs dup rtc-threshold > if ( gained-seconds ) - page show-fail ( gained-seconds ) - ." Clock gained " .d ." seconds since SMT" cr ( ) - .clocks - stall - then - ." NTP and RTC clocks agree." cr -; - -: put-key:value ( value$ key$ -- ) " %s:%s" sprintf put-key-line ; - -: upload-tag ( data$ tag$ -- ) - 2dup " wp" $= if ( data$ tag$ ) - 4drop " 1" " WP" put-key:value ( ) - exit - then - 2dup " ww" $= if ( data$ tag$ ) - 4drop " 0" " WP" put-key:value ( ) - exit - then - 2dup " ak" $= if ( data$ tag$ ) - 4drop " 1" " ak" put-key:value ( ) - exit - then - 2dup " KA" $= if ( data$ tag$ ) - 4drop ( ) - exit - then - 2dup " SG" $= if ( data$ tag$ ) - 4drop ( ) - exit - then ( data$ tag$ ) - - 2swap ?-null 2swap ( data$' tag$ ) - put-key:value ( ) -; - -: upload-tags ( -- ) - mfg-data-top ( adr ) - begin another-tag? while ( adr' data$ tname-adr ) - 2 upload-tag ( adr ) - repeat ( adr ) - drop -; - -\ Upload the result data -: final-result ( -- ) - final-filename$ open-temp-file - upload-tags - pass? if " PASS" else " FAIL" then " RESULT=" put-key+value - " Handshake" submit-file -; - -: wait-connections ( -- ) - silent-probe-usb - wait-lan -; - -: my-cifs-connect ( adr -- ) - open-dev to cifs-ih - cifs-ih 0= abort" Cannot open SMB share" -; - -\ $rename gives "Unimplemented package interface procedure" on ext2 -: do-rename - 2>r 2dup 2r> $copy $delete -; - -: $safe-delete ( $name -- ) - 2dup $file-exists? if - 2dup $delete - then - 2drop -; - -: $copy! ( $src $dst -- ) - 2dup $file-exists? if - 2dup $delete - then - $copy1 -; - - -: finish-final-test ( -- ) - - " int:\runin\final.fth" $safe-delete - " int:\runin\repass.fth" 2dup $file-exists? if - " int:\runin\final.fth" $copy - else - 2drop - then - - wait-connections - - get-sn-value - - verify-rtc-date - - ." Getting final tags .. " - cifs-connect final-tag-exchange \ Note: no disconnect... - ." Done" cr - - inject-tags - - ." Submitting results .. " - final-result cifs-disconnect - ." Done" cr - - " int:\runin\repass.fth" $safe-delete - - \ need to delete target, due to #9957 - " int:\runin\final.fth.sav" $safe-delete - - " int:\runin\final.fth" " int:\runin\final.fth.sav" $rename -; - -\ Make the "wait for SD insertion" step highly visible -dev ext -warning @ warning off -: wait&clear ( -- error? ) wait-card? page ; -patch wait&clear wait-card? selftest -: selftest ( -- ) page show-pass selftest ; -warning ! -dend - -: fail-backup-file$ ( -- name$ ) - time&date format-date " int:\runin\fail-%s.log" sprintf -; -: fail-log-file$ ( -- name$ ) " int:\runin\fail.log" ; - -\ The operator can type this to reset the state to run -\ the Linux-based runin tests again. -: rerunin ( -- ) - " int:\runin\final.fth" $safe-delete - fail-log-file$ fail-backup-file$ do-rename -; - -: after-runin ( -- ) - fail-log-file$ $read-file 0= if ( adr len ) - page - show-fail - ." Type a key to see the failure log" - key drop cr cr - list - ." Type R to restart runin, any other key to power off " - key dup emit cr upc [char] R = if - ." Resetting state to restart runin." cr - ." The old failure log is in " fail-backup-file$ type cr - rerunin - else - power-off - then - else - autorun-mfg-tests - pass? if finish-final-test then - show-result-screen - then - - ." Type a key to power off" - key cr - power-off -; - -\ Override the display self test -dev /display - -warning @ warning off -: selftest ( -- error? ) - depth d# 16 < if false exit then - - .vertical-bars16 wait - hgradient - - confirm-selftest? -; -warning ! - -device-end - -." Starting final phase" cr -after-runin
