Author: wmb Date: Tue Aug 16 02:45:53 2011 New Revision: 2461 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2461
Log: OLPC XO-1.75 - enabled DCON freeze functionality since some machines now support it.
Modified: dev/olpc/dcon/mmp2dcon.fth
Modified: dev/olpc/dcon/mmp2dcon.fth ============================================================================== --- dev/olpc/dcon/mmp2dcon.fth Sat Aug 13 02:51:41 2011 (r2460) +++ dev/olpc/dcon/mmp2dcon.fth Tue Aug 16 02:45:53 2011 (r2461) @@ -1,6 +1,11 @@ \ See license at end of file \ " dcon" device-name
+new-device +" dcon" device-name +" olpc,xo1-dcon" +compatible +finish-device + \ DCON internal registers, accessed via I2C \ 0 constant DCON_ID \ 1 constant DCON_MODE @@ -52,7 +57,7 @@ : dcon-unload ( -- ) d# 142 gpio-clr ; [then] \ : dcon-blnk? ( -- flag ) ; \ Not hooked up -: dcon-stat@ ( -- n ) h# d4019100 l@ 4 rshift 3 and ; +: dcon-stat@ ( -- n ) h# 019100 io@ 4 rshift 3 and ; : dcon-irq? ( -- flag ) d# 124 gpio-pin@ 0= ;
\ DCONSTAT values: 0 SCANINT 1 SCANINT_DCON 2 DISPLAYLOAD 3 MISSED @@ -60,8 +65,6 @@ 1 value vga? \ VGA 0 value color? \ COLOUR
-\ : gxfb! ( l offset -- ) gxfb-dc-regs + rl! ; \ Probably should be IO mapped - d# 905 value resumeline \ Configurable; should be set from args
: wait-output ( -- ) d# 40 ms ; @@ -99,7 +102,6 @@ dcon-load \ Put the DCON in VGA-refreshed mode d# 25 ms \ Ensure that that DCON sees the DCONLOAD high \ display-on -[ifdef] notdef else begin ( ) dcon-unload \ Put the DCON in self-refresh mode @@ -109,7 +111,6 @@ \ We got a false ack from the DCON so start over from LOAD state dcon-load d# 25 ms ( ) repeat ( ) -[then] then ;
