Author: wmb Date: Tue Aug 3 21:31:37 2010 New Revision: 1902 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/1902
Log: SD driver - fixed the ADATA SD card problems without a delay, by using READ/WRITE_SINGLE (instead of _MULTIPLE) for one-block transfers.
Modified: dev/mmc/sdhci/sdhci.fth
Modified: dev/mmc/sdhci/sdhci.fth ============================================================================== --- dev/mmc/sdhci/sdhci.fth Tue Aug 3 11:53:23 2010 (r1901) +++ dev/mmc/sdhci/sdhci.fth Tue Aug 3 21:31:37 2010 (r1902) @@ -432,6 +432,9 @@ : write-single ( address -- ) h# 183a h# 03 cmd ; \ CMD24 R1 WRITE_SINGLE_BLOCK : write-multiple ( address -- ) h# 193a h# 27 cmd ; \ CMD25 R1 WRITE_MULTIPLE
+: issue-write ( address #blocks -- ) 1 = if write-single else write-multiple then ; +: issue-read ( address #blocks -- ) 1 = if read-single else read-multiple then ; + : program-csd ( -- ) 0 h# 1b1a 0 cmd ; \ CMD27 R1 UNTESTED : protect ( group# -- ) h# 1c1b 0 cmd ; \ CMD28 R1b UNTESTED : unprotect ( group# -- ) h# 1d1b 0 cmd ; \ CMD29 R1b UNTESTED @@ -711,7 +714,7 @@
\ This is the correct way to wait for programming complete. : wait-write-done ( -- error? ) - writing? 0= if false exit then ( limit ) + writing? 0= if false exit then
get-msecs d# 4000 + ( limit ) \ Wait for return to "tran" state (4) @@ -899,14 +902,12 @@ rot dma-setup ( block# r: #blocks fresh? in? ) wait-write-done if drop r> r> r> 3drop true exit then ( block# ) address-shift lshift r> if ( block# r: #blocks fresh? ) - r> r> 2drop ( block# ) - read-multiple ( ) + r> drop ( block# r: #blocks ) + r> issue-read ( ) else ( block# r: #blocks fresh? ) - \ Ugly ugly workaround for a problem with AData Class 6 SD cards - \ They hang (data timeout) if you start a write too soon after a read. - " d# 1200 us" evaluate - r> if r> pre-write-erase else r> drop then ( block# ) - write-multiple true to writing? ( ) + r> if r@ pre-write-erase then ( block# r: #blocks ) + r> issue-write ( ) + true to writing? ( ) then ( ) true to dma? ( ) false ( error? )
