Author: quozl Date: Tue Jan 10 03:55:17 2012 New Revision: 2808 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/2808
Log: OLPC XO-1.75 - fix build error, move suspend and resume test out of rtc.fth into build-fw.fth to access final-test? word.
Modified: cpu/arm/mmp2/rtc.fth cpu/arm/olpc/build-fw.fth
Modified: cpu/arm/mmp2/rtc.fth ============================================================================== --- cpu/arm/mmp2/rtc.fth Tue Jan 10 03:29:32 2012 (r2807) +++ cpu/arm/mmp2/rtc.fth Tue Jan 10 03:55:17 2012 (r2808) @@ -56,14 +56,6 @@ ." OKAY" cr drop false ( error? ) then ( error? ) ; -dev /switches -: selftest ( -- error? ) - final-test? 0= if - s3-selftest if true exit then - then - selftest -; -device-end
\ LICENSE_BEGIN \ Copyright (c) 2011 FirmWorks
Modified: cpu/arm/olpc/build-fw.fth ============================================================================== --- cpu/arm/olpc/build-fw.fth Tue Jan 10 03:29:32 2012 (r2807) +++ cpu/arm/olpc/build-fw.fth Tue Jan 10 03:55:17 2012 (r2808) @@ -647,6 +647,18 @@ warning ! device-end
+\ Add suspend resume test except in final +dev /switches +warning @ warning off +: selftest ( -- error? ) + final-test? 0= if + s3-selftest if true exit then + then + selftest +; +warning ! +device-end + \ When reprogramming this machine's SPI FLASH, rebooting the EC is unnecessary : no-kbc-reboot ['] noop to spi-reprogrammed ; : kbc-on ;
