Author: wmb Date: 2009-11-14 02:05:23 +0100 (Sat, 14 Nov 2009) New Revision: 1478
Modified: dev/usb2/device/storage/scsi.fth Log: OLPC trac 9423 - Added commented-out code to report occurences of the USB problem reported in that ticket, which has been suppressed by a retry workaround.
Modified: dev/usb2/device/storage/scsi.fth =================================================================== --- dev/usb2/device/storage/scsi.fth 2009-11-13 22:53:08 UTC (rev 1477) +++ dev/usb2/device/storage/scsi.fth 2009-11-14 01:05:23 UTC (rev 1478) @@ -141,6 +141,15 @@ ?dup if ( actual csw-len csw-usberror ) nip ( actual csw-usberror ) dup h# 10000000 = if ( actual csw-usberror ) +[ifdef] notdef +\ This is for testing the problem described in OLPC trac #9423 +\ The problem has been worked around so users no longer see it, +\ apart from a short delay when it happens, but for testing you +\ can enable this code to report the problem and count occurrences. +cr 7 emit ." TIMEOUT " 7 emit +" h# 72 cmos@ 1+ dup .d h# 72 cmos!" evaluate +cr +[then] 2drop 0 2 ( 0 2 ) \ Convert timeout error to a retry then ( actual usberror ) exit
