Author: wmb Date: 2009-07-22 09:12:17 +0200 (Wed, 22 Jul 2009) New Revision: 1247
Modified: ofw/fs/ext2fs/dir.fth ofw/fs/ext2fs/methods.fth Log: OLPC trac #9409 - fixed ext2 symlink problems.
Modified: ofw/fs/ext2fs/dir.fth =================================================================== --- ofw/fs/ext2fs/dir.fth 2009-07-20 21:39:07 UTC (rev 1246) +++ ofw/fs/ext2fs/dir.fth 2009-07-22 07:12:17 UTC (rev 1247) @@ -8,7 +8,6 @@
variable diroff variable totoff -variable current-dir
: get-dirblk ( -- end? ) lblk# bsize * file-size >= if true exit then @@ -40,6 +39,14 @@
: lblk#++ ( -- ) lblk# 1+ to lblk# ;
+: dirent-vars ( -- diroff totoff lblk# inode# ) + diroff @ totoff @ lblk# inode# +; +: restore-dirent ( diroff totoff lblk# inode# -- ) + to inode# to lblk# totoff ! diroff ! + get-dirblk drop +; + \ **** Select the next directory entry : next-dirent ( -- end? ) dirent-len@ dup diroff +! totoff +! @@ -80,7 +87,6 @@ ;
\ On entry: -\ current-dir @ is the inode of the directory file \ dir-block# is the physical block number of the first directory block \ diroff @ is 0 \ On successful exit: @@ -162,7 +168,6 @@ else \ First dirent in block; zap its inode 0 dirent-inode! - then update false @@ -183,90 +188,164 @@ r> dirent-inode@ init-inode ;
+: linkpath ( -- a ) + file-acl if bsize 9 rshift else 0 then ( #acl-blocks ) + #blks-held <> if \ long symbolic link path + direct0 int@ block + else \ short symbolic link path + direct0 + then +; + +\ -- + +1 constant regular-type +2 constant dir-type +7 constant symlink-type + +\ Information that we need about the working file/directory +\ The working file changes at each level of a path search + +0 instance value wd-inum \ Inumber of directory to search +0 instance value wf-inum \ Inumber of file or directory found +0 instance value wf-type \ Type - 4 for directory, d# 10 for symlink, etc + +char \ instance value delimiter + +defer $resolve-path +d# 1024 constant /symlink \ Max length of a symbolic link + +: set-root ( -- ) + root-dir# to wd-inum root-dir# to wf-inum dir-type to wf-type +; + +: strip\ ( name$ -- name$' ) + dup 0<> if ( name$ ) + over c@ delimiter = if ( name$ ) + 1 /string ( name$ ) + set-root ( name$ ) + then ( name$ ) + then ( name$ ) +; + +: set-inode ( inode# -- ) + to inode# + 0 to lblk# +; + +: first-dirent ( dir-inode# -- end? ) \ Adapted from (init-dir) + set-inode + get-dirblk if true exit then + 0 diroff ! 0 totoff ! ( ) + false ( ) +; + \ On entry: -\ current-dir @ is the inode of the directory file +\ inode# is the inode of the directory file \ dir-block# is the physical block number of the first directory block \ diroff @ and totoff @ are 0 \ On successful exit: \ dir-block# is the physical block number of the current directory block \ diroff @ is the within-block offset of the directory entry that matches name$ \ totoff @ is the overall offset of the directory entry that matches name$ -: lookup ( name$ -- not-found? ) - begin - dirent-inode@ if \ inode=0 for a deleted dirent at the beginning of a block - 2dup file-name $= if 2drop false exit then + +: $find-name ( name$ dir-inum -- error? ) + first-dirent ( end? ) + begin 0= while ( name$ ) + \ dirent-inode@ = 0 means a deleted dirent at the beginning + \ of a block; skip those + dirent-inode@ if ( name$ ) + 2dup file-name ( name$ name$ this-name$ ) + $= if + dirent-inode@ to wf-inum ( name$ ) + dirent-type@ to wf-type ( name$ ) + 2drop false exit + then ( name$ ) then - next-dirent - until - 2drop true + next-dirent ( name$ end? ) + repeat ( name$ ) + + 2drop ( ) + true ;
-defer init-dir - -: $chdir ( path$ -- error? ) - begin dup while ( path$ ) - [char] \ left-parse-string ( tail$ head$ ) - dup 0= if ( tail$ head$ ) \ Begins with \ - 2drop ( tail$ ) - root-dir# init-dir if 2drop true exit then - else ( tail$ head$ ) - lookup if 2drop true exit then - dir? 0= if 2drop true exit then - file-handle init-dir if 2drop true exit then - then ( tail$ ) - repeat ( path$ ) - 2drop false +: symlink-resolution$ ( inum -- data$ ) + to inode# + linkpath dup cstrlen ;
-\ replace / with \ in a string -: >OFW-path ( adr len -- ) - bounds do i c@ ascii / = if ascii \ i c! then loop +\ The work file is a symlink. Resolve it to a new dirent +: dir-link ( -- error? ) + delimiter >r [char] / to delimiter ( r: delim ) + + \ Allocate temporary space for the symlink value (new name) + /symlink alloc-mem >r ( r: delim dst ) + + \ Copy the symlink resolution to the temporary buffer + wf-inum symlink-resolution$ ( src len r: delim dst ) + tuck r@ swap move ( len r: delim dst ) + + r@ swap $resolve-path ( error? r: delim dst ) + + r> /symlink free-mem ( error? r: delim ) + r> to delimiter ( error? ) ;
-: linkpath ( -- a ) - file-acl if bsize 9 rshift else 0 then ( #acl-blocks ) - #blks-held <> if \ long symbolic link path - direct0 int@ block - else \ short symbolic link path - direct0 - then +\ On successful exit, wf-inum is the inode# of the last path component, +\ wf-type is its type, and wd-inum is inode# of the last directory encountered + +: ($resolve-path) ( path$ -- error? ) + dir-type to wf-type + \ strip\ sets wd-inum if the path begins with the delimiter + begin strip\ dup while ( path$ ) + wf-type case ( path$ c: type ) + dir-type of ( path$ ) + delimiter left-parse-string ( rem$' head$ ) + \ $find-name sets wf-inum and wf-type to the pathname component + wd-inum $find-name if 2drop true exit then ( rem$ ) + wf-type dir-type = if ( rem$ ) + wf-inum to wd-inum ( rem$ ) + then ( rem$ ) + endof ( rem$ ) + + symlink-type of ( rem$ ) + \ dir-link recursively calls $resolve-path, setting + \ wf-inum and wf-type to the symlink's last component + dir-link if 2drop true exit then ( rem$ ) + endof ( rem$ ) + ( default ) ( rem$ c: type ) + + \ The parent is an ordinary file or something else that + \ can't be treated as a directory + 3drop true exit + endcase ( rem$ ) + repeat ( rem$ ) + 2drop false ( false ) ;
-variable parent-dir +' ($resolve-path) to $resolve-path
-: select-file ( i# -- error? ) - to inode# - symlink? if ( ) - linkpath dup cstrlen 2dup >OFW-path ascii \ split-after ( file$ path$ ) - dup if ( file$ path$ ) - \ Path component is present - parent-dir @ init-dir if 4drop true exit then ( file$ path$ ) - $chdir if 2drop true exit then ( file$ ) - else ( file$ path$ ) - \ Path component is absent - 2drop current-dir @ init-dir if 2drop true exit then ( file$ ) - then ( file$ ) - dup 0= if 2drop false exit then ( file$ ) - lookup if true exit then ( ) - - file-handle recurse - else ( ) - 0 to lblk# false ( ) - then ( ) +: $find-file ( name$ -- error? ) + $resolve-path if true exit then ( ) + + begin + \ We now have the dirent for the file at the end of the string + wf-type case + dir-type of wf-inum to wd-inum false exit endof \ Directory + regular-type of false exit endof \ Regular file + symlink-type of dir-link if true exit then endof \ Link + ( default ) \ Anything else (special file) is error + drop true exit + endcase + again ; +\ --
-\ **** Select the directory file -: (init-dir) ( i# -- error? ) - \ Save the current directory because we will need to return to it - \ in case we encounter a relative symlink. - current-dir @ parent-dir ! ( i# ) - dup current-dir ! ( i# ) - select-file if true exit then ( ) - get-dirblk if true exit then ( ) - 0 diroff ! 0 totoff ! ( ) - false ( ) +: $chdir ( path$ -- error? ) + $find-file if true exit then + wf-type dir-type <> if true exit then + wd-inum first-dirent ; -' (init-dir) to init-dir
\ Delete a file, given its inode. Does not affect the directory entry, if any. : idelete ( inode# -- ) @@ -286,7 +365,7 @@ file-handle 0= if true exit then
inode# >r - file-handle select-file if r> drop true exit then + file-handle set-inode if r> drop true exit then file? 0= if r> drop true exit then \ XXX handle symlinks
\ is this the only link? @@ -297,7 +376,6 @@ 1- link-count! then
- r> to inode# \ delete directory entry del-dirent ( error? ) @@ -331,11 +409,12 @@ ;
: $readlink ( name$ -- true | link$ false ) - lookup if true exit then - - inode# >r file-handle to inode# - linkpath dup cstrlen false - r> to inode# + dirent-vars 2>r 2>r + $resolve-path if 2r> 2r> restore-dirent true exit then + wf-type symlink-type <> if 2r> 2r> restore-dirent true exit then + + wf-inum symlink-resolution$ false + 2r> 2r> restore-dirent ;
headers
Modified: ofw/fs/ext2fs/methods.fth =================================================================== --- ofw/fs/ext2fs/methods.fth 2009-07-20 21:39:07 UTC (rev 1246) +++ ofw/fs/ext2fs/methods.fth 2009-07-22 07:12:17 UTC (rev 1247) @@ -13,7 +13,7 @@ o# 100666 ($create) ; \ XXX note: increment link count in parent -: $mkdir ( name$ -- ) +: $mkdir ( name$ -- error? ) o# 40777 ($create) if true exit then
file-handle to inode# @@ -21,17 +21,17 @@ file-size h# 400 + file-size! dup direct0 int! update ( block# ) block bsize erase update \ flush - current-dir @ >r - inode# init-dir + wd-inum >r + inode# first-dirent if r> drop true exit then " ." d# 12 inode# set-dirent d# 12 diroff ! - " .." bsize d# 12 - r> set-dirent + " .." bsize d# 12 - r> set-dirent false ( error? ) diroff off ;
: $delete ( name$ -- error? ) - lookup if true exit then ( ) + $find-file if true exit then ( )
(delete-file) ; @@ -39,10 +39,11 @@
\ XXX note: decrement link count in parent : $rmdir ( name$ -- error? ) \ XXX UNTESTED - lookup if true exit then ( ) + $find-file if true exit then ( ) + wf-type dir-type <> if true exit then ( )
inode# >r \ save parent directory - file-handle select-file if r> drop true exit then + file-handle set-inode if r> drop true exit then dir? 0= if r> drop true exit then
(delete-files) file-handle if r> drop true exit then \ still some left @@ -102,16 +103,17 @@ then ( actual addr ) lblk# write-file-block ( actual )
- \ XXX I am sceptical about this line. + \ XXX I am skeptical about this line. dup 0> if lblk#++ then ( actual ) true to modified? \ flush \ XXX kludge for tests ;
: $ext2fsopen ( adr len mode -- false | fid fmode size align close seek write read true ) - -rot lookup if drop false exit then ( mode adr len ) + -rot $find-file if drop false exit then ( mode ) + wf-type regular-type <> if drop false exit then ( mode )
- file-handle select-file if drop false exit then ( mode ) + file-handle set-inode ( mode ) false to modified?
>r @@ -134,7 +136,7 @@ my-args " <NoFile>" $= if true exit then
\ Start out in the root directory - root-dir# init-dir if release-buffers false exit then + set-root
my-args ascii \ split-after ( file$ path$ ) $chdir if 2drop release-buffers false exit then ( file$ )
