Author: wmb Date: Wed Oct 10 21:20:29 2012 New Revision: 3356 URL: http://tracker.coreboot.org/trac/openfirmware/changeset/3356
Log: OLPC ARM - add DMA mux to IRQ device tree nodes and refer to it in the audio driver.
Modified: cpu/arm/mmp2/irq.fth cpu/arm/olpc/sound.fth
Modified: cpu/arm/mmp2/irq.fth ============================================================================== --- cpu/arm/mmp2/irq.fth Wed Oct 10 08:12:31 2012 (r3355) +++ cpu/arm/mmp2/irq.fth Wed Oct 10 21:20:29 2012 (r3356) @@ -95,6 +95,7 @@ h# 160 h# 178 d# 51 2 make-mux-node \ intcmux51 - HSI_CAWAKE(1?), MIPI_HSI_INT1 h# 188 h# 184 d# 55 2 make-mux-node \ intcmux55 - HSA_CAWAKE(0?), MIPI_HSI_INT0 [then] + h# 128 h# 11c d# 48 d# 24 make-mux-node \ DMA mux - 16 PDMA, 4 ADMA, 2 VDMA channels
0 [if] new-device
Modified: cpu/arm/olpc/sound.fth ============================================================================== --- cpu/arm/olpc/sound.fth Wed Oct 10 08:12:31 2012 (r3355) +++ cpu/arm/olpc/sound.fth Wed Oct 10 21:20:29 2012 (r3356) @@ -39,6 +39,10 @@ h# 900 +audio h# 100 reg 5 encode-int 4 encode-int encode+ " mmp-mav-dma-channels" property " marvell,mmp-audio-dma" +compatible + + " /interrupt-controller@128" encode-phandle " interrupt-parent" property + d# 20 encode-int d# 21 encode-int encode+ " interrupts" property + " disabled" " status" string-property current-device ( adma1-ph ) finish-device @@ -61,6 +65,10 @@ h# 800 +audio h# 100 reg 3 encode-int 2 encode-int encode+ " mmp-mav-dma-channels" property " marvell,mmp-audio-dma" +compatible + + " /interrupt-controller@128" encode-phandle " interrupt-parent" property + d# 18 encode-int d# 19 encode-int encode+ " interrupts" property + current-device ( adma0-ph ) finish-device
